Old 07-16-2014, 07:01 PM   #421
Just wait for the Maezumi - it will be next for sure.
cplus is offline   Reply With Quote
Old 07-17-2014, 05:50 AM   #422
Originally Posted by Mini35 View Post
Never say never but after speaking to HobbyCo I know there are 2 sides to every story so I'm not p****d off now. It's just one of those things. I would say 99.9999% there will be no more coming unless Tamiya do another run before they pack away the tooling. And as we've seen with other Evos - most lately with the FF03 Evo - it's unlikely they'd do that. Of course you can't rule out Tamiya doing a fresh run next year in a slightly amended spec like they've done with the TB04 Pro/Pro II but I wouldn't hold my breath.
Different topic but do you think there's a market in the UK for the 05v2? No one at our club is getting one, the majority of us have switched to the M06 since earlier in the year. Those who have indicated an interest are biding their time for the chassis and arms to be released as spare parts and will just convert existing (and unloved) v1s.
Oh well, it would have been great to have had another UK racer using an Evo. As to the m05v2, I dont know. I am tempted to get an m06 as we run superstox at my club (only a few) so I was tempted to race that with those guys.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 07-19-2014, 06:32 PM   #423
transplantlife's Avatar
Trader Rating: 43 (98%+)
EVO 6 FOR SALE
BNIB TAMIYA TB EVO 6
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 07-20-2014, 06:53 PM   #424
anybody can take picture and give the right shim for the smoothness drivetrain please ?
Xray T4 2017
Awesomatix A700 L2
Yokomo BD7 2015 Spice FWD
12th scale Roche 2016
Quinny45 is offline   Reply With Quote
Old 07-21-2014, 06:22 AM   #425
Aitutaki's Avatar
Originally Posted by JimmyMac View Post
Hi There,
will the TRF 416X blocks fit on the TB Evo 6 chassis ?
thanks
Aitutaki is offline   Reply With Quote
Old 07-21-2014, 06:25 AM   #426
Aitutaki's Avatar
as posted one or two pages before:
pictures with poor quality can be seen here: http://takatakanokkey.blogspot.co.at...6jp135ttb.html
shims seems to be 0,2mm
Old 07-21-2014, 06:41 AM   #427
Originally Posted by Aitutaki View Post
Hi There,
thanks
Yep. Comes with 1 piece blocks fore and aft at both ends, but I understand the chassis has the ability to take split style blocks as well.
Old 07-21-2014, 07:09 AM   #428
Aitutaki's Avatar
thanks !
that saves money
Old 07-21-2014, 09:36 AM   #429
mac853's Avatar
So that's mean could i use split ones from 416 or tb03 match with car's original long ones?
mac853 is offline   Reply With Quote
Old 07-21-2014, 09:42 AM   #430
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Tb03 uses one piece blocks, but yes, split blocks fit fine in FR and RF positions.
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 07-21-2014, 10:19 AM   #431
mac853's Avatar
Sorry i meant, if i want use split suspension mounts(54173 for FR and RF) of TB03, then can keep using those original long ones (13458124 for FF and 13458125 for RR) of tb evo6 without need also to buy old long ones of Tb03?
Old 07-21-2014, 02:08 PM   #432
Yep, all tamiya blocks are pretty much interchangeable
Old 07-21-2014, 04:03 PM   #433
Trader Rating: 23 (100%+)
Hi guys,
Sorry to interrupt, but got a brand new in the box EVO6 for sale if anyone is interested. Please PM with offer.
Steve
Steve Wang
ST Racing Concepts: www(dot)teamstrc(dot)com
teamstrc is offline   Reply With Quote
Old 07-21-2014, 05:18 PM   #434
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by teamstrc View Post
Hi guys,
Steve
i assume you bought this in hopes of running GT1 at TCS Nats this year?
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 07-23-2014, 01:02 AM   #435
CraigMBA's Avatar
Started building my Evo6 a couple days ago. This is my sixth shaft drive Tamiya build I've done in the past year. They are all kind of the same, but there are some differences between parts and gear sets. A couple of things I did in addition to what the manual calls for:
1. I affixed the 20t gear that is on the spur adaptor to the adaptor with the smallest smear of Shoe Goo. I tried using a piece of plastic to shim it, but the gear to gear clearance was too tight IMO and I needed another solution else it was going to be noisy.
2. The pinion gear on the transmissions need to be shimmed tighter. I added 0.3mm of shims between the outer bearing and the outside part of the shaft, giving the pinion less plunge.
3. Remember when I said the side to side clearance is different between the carbon rein and the kit plastic gear cases? Because it is...
4. I used some joint grease between the input shaft and the main shaft. Use something here. This shaft needs to move slightly as the chassis flexes. If it was solid, it wouldn't flex at all like the tb03.
I'm dissatisfied with the main shaft that attaches transmissions to the motor. IMO, that shaft would be better served if you could shim the plunge depth, rather than rely on the spring (inside the front transmission outdrive) and the driveshaft to keep preload on it. The tb04 suffers from this as well. I'm pretty sure I know why they engineered it this way, but I still don't like it. No big deal.
Do I think it will be as quiet as my TB03? No. Am I confident it will be acceptably quiet? Absolutely. About the same as the tb04.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
aracefan
