Like Tree1Likes
Old 07-05-2014, 09:52 PM   #361
CW22's Avatar
Trader Rating: 86 (100%+)
Originally Posted by JoeyE View Post
Do you still have that Muchmore Legend for sale? Software 1.23D correct? email me at suradajj at gee male .
Awesome paint btw.
Hi Joey, I can't send a pm to you, check your setting please.
Thanks.
CHRIS
Tamiya cars.
TRF, Muchmore racing.
CW22 is offline   Reply With Quote
Old 07-06-2014, 01:46 AM   #362
Simmi's Avatar
My EVO I received from stella models, thank you.
The shaft is in front shorter than the back and only 1,5 shims?
@ CW
Do you have a setup for the EVO?
I drive in Front C-C, droop 6 in front and 5 in back.
Diff I drive 3000 Muchmore oil, drop 2degree around and height 5 around.
Hope this will work
Tamiya Racing Factory: TRF 419X
Team Yokomo YZ2 CA
Simmi is offline   Reply With Quote
Old 07-06-2014, 04:11 AM   #363
Found a vid for those of you that want to see the Evo6 in action. At pole.
+ YouTube Video
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 07-06-2014, 04:36 AM   #364
EVO 6 in stock
http://shop.smokem-racing.com/Tamiya...Kit_p_138.html
Xray T4 2017
Awesomatix A700 L2
Yokomo BD7 2015 Spice FWD
12th scale Roche 2016
Quinny45 is offline   Reply With Quote
Old 07-06-2014, 09:04 AM   #365
CW22's Avatar
@ CW
Hope this will work
The shaft is not shorter, that's the way it is. You need to add those red small foam and follow the manual instruction.
For the set up, just to make sure you build your drive train correctly or it will be loud, I add a 0.1 shim from behind the drive shaft that hold the spur gear.
The other set up is mostly the same like the other car and is a preference. Yes, I also using 3000 oil diff.
CHRIS
Tamiya cars.
Old 07-06-2014, 09:22 AM   #366
rtypec's Avatar
Had the opportunity to put some laps in with the Evo6. So far the car is very promising. Easy to drive and has got some pace.
My setup is basically stock with the exception of the following:
  • Front and rear shocks in one hole on tower
  • Titanium and aluminum screws
  • 1XB/1B split blocks front and rear
  • no spacers under front blocks
  • HPI silver springs
  • Muchmore 450 shock oil no rebound
  • 2 degrees camber front and rear
  • Droop 25mm front / 24.7 rear
There is plenty of space for whatever sized pinion you dare try Attached is a picture with a 60 with lots of extra room.
Also ran the car with a 17.5. Here's a video demonstrating a few laps. Thanks for shooting the video goes to OSherman.
My car is way louder than CW22's. My drivetrain is extremely free but apparently I did something wrong and currently have the chassis stripped completely down to hunt for the coffee grinder culprit
Evo 6 at Tamiya
+ YouTube Video
rtypec is offline   Reply With Quote
Old 07-06-2014, 12:06 PM   #367
Simmi's Avatar
I drove today on our home track with this setup that felt very good.
Camber front 1,5 and rear 2 degree
Droop front 5 and rear 4
Height front 5 and rear 5,4
Spring HPI Blue around
Tire Ride 32
Body Protoform Mazda GX
Panaracer 96 Gear and 51 Pinion
Team Yokomo YZ2 CA
Old 07-06-2014, 12:16 PM   #368
Simmi's Avatar
Sorry, but the front shaft is 43mm and the rear is 46mm
I have made a Video from the TB EVO 6
https://www.youtube.com/watch?v=-iYIgoGduTg
Team Yokomo YZ2 CA
Old 07-06-2014, 01:27 PM   #369
Looks great! How do you find it over the 418?
As to the drive train What did you do wrong? or is there a tip to make it quieter?
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 07-06-2014, 01:40 PM   #370
mac853's Avatar
Angry
Mostly big pinions and tiny spurs is hard to find, most places is out of stock, maybe i need to give up to buy this car
mac853 is offline   Reply With Quote
Old 07-06-2014, 02:38 PM   #371
b20btec's Avatar
They're not that hard to find. Buy a xenon spur same pattern as psnaracer. Reflexracing
b20btec is offline   Reply With Quote
Old 07-06-2014, 03:06 PM   #372
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Spurs:
http://www.teamcrc.com/store/index.php?main_page=index&cPath=1_46_50
Pinions:
http://www.teamcrc.com/store/index.php?main_page=index&cPath=1_46_47&sort=20a&p age=4
What's not to love?
CraigMBA is offline   Reply With Quote
Old 07-06-2014, 04:53 PM   #373
CW22's Avatar
My bad, I thought you are talking about the center shaft.
The drive shaft is true different size for the front and rear.
CHRIS
Tamiya cars.
Old 07-06-2014, 04:55 PM   #374
CW22's Avatar
Craigmba,
How's your EVO 6 ?
CHRIS
Tamiya cars.
Old 07-06-2014, 05:43 PM   #375
CraigMBA's Avatar
Craigmba,
How's your EVO 6 ?
Still sitting in the box(es). I sanded all the graphite, but then company showed up last week and I got "evicted" from my office, aka the spare bedroom. Be a couple more weeks before I can get them built, maybe two months before I can go to TQ and test, and IIC isn't till October
Rod (or, anybody with a Evo6 and a 418 around in the same place and the same time):
Can the 418 servo mount be cross fitted into the EVO as a bolt on?
