Like Tree7Likes
Old 07-02-2014, 09:44 PM   #346
hanzo3's Avatar
Trader Rating: 55 (100%+)
Originally Posted by CW22 View Post
Is a 64p, if you can get RW brand at AU that is a perfect size of spur.
If you never seen a 50T pinion, I don't know what to say.
Chris, you are funny. I need to visit tamiya soon.
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 07-03-2014, 06:14 PM   #347
CW22's Avatar
Trader Rating: 93 (100%+)
Yeah, I see you next time @ Tamiya.
CHRIS
Tamiya cars.
TRF, Muchmore racing.
CW22 is offline   Reply With Quote
Old 07-03-2014, 07:24 PM   #348
Dusttt's Avatar
Trader Rating: 118 (100%+)
Will Robinson spurs fit the car?
"Whiskey Tango Foxtrot"
Dusttt is offline   Reply With Quote
Old 07-04-2014, 12:17 AM   #349
mac853's Avatar
Default Gear for 17.t blinky
Dear anyone:
Could somebody tell me what gears(48p or 64p) and fdr should use to run on 17.5 blinky class, please?
Best regards
mac853 is offline   Reply With Quote
Old 07-04-2014, 12:31 AM   #350
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Originally Posted by mac853 View Post
Dear anyone:
Best regards
What motor, how big a track?
CraigMBA is offline   Reply With Quote
Old 07-04-2014, 01:07 AM   #351
mac853's Avatar
Hi, not quite sure size, i never be there, but i could should the picture.http://rc-evo.com/xbbs/data/attachme...r9z6bfs1w0.jpg
In fact i didn't have yet car on hands.
About the motor, didn't buy yet, due homologation matter
But could you tell me which maximum spur could reach without touching motor mount, please?
best regards
Old 07-04-2014, 04:53 AM   #352
Mines in transit, anyone run this chassis in 13.5? If so would appreciate gearing suggestions
Adsmotron is offline   Reply With Quote
Old 07-04-2014, 06:57 AM   #353
d16dcoe45's Avatar
This car looks very very tempting, but what's with the Tamiya obsession to have a transverse mounted motor in a shaft drive car? I know torque steer reduction will be mentioned but don't most of the Awsomatix drivers use a longitudinal motor mounting and do great with them? Seems to me that adding another 90 deg angle to power transmission negates some of the efficiency advantage that shaft drive offers.
It also pushes the motor mount/motor quite a bit towards the side of the chassit which is the opposite of where TC design has been heading.
Jay Lestingi
Tamiya 419x/Associated TC7.1/Sanwa M12s/Xpert servos
d16dcoe45 is offline   Reply With Quote
Old 07-04-2014, 07:41 AM   #354
Aim for low 4's with most motors, assuming blinky. High 3's if the track is big. I run a 418 in 13.5T blinky on a rather larger track and run at 3.91 - and the car is no slouch.
Say, 66 spur, 40 pinion as a starter. Just realised the stock spur is also 66! Don't use it with a 48p pinion though, it will eat itself, it's tamiya metric 06 pitch, which is close, but not equal to 48p.
Tamiya don't make an 06 module pinion that is large enough from memory.
cplus is offline   Reply With Quote
Old 07-04-2014, 08:41 AM   #355
rtypec's Avatar
Default 13.5 Gearing
The Evo6 uses normal inner width spurs. An overall thin spur would be ideal. 418/BD7 inner width spurs will need a spacer. For 13.5 on a medium sized track, an 84 spur and 52 pinion will give you a starting point of 4.038 with plenty of room to adjust.
But hey...what do I know
PRS 84 with CRC 52
rtypec is offline   Reply With Quote
Old 07-04-2014, 09:04 AM   #356
mac853's Avatar
PRS 84 with CRC 52
How maximum pinion gear could use it?
Best regards
Old 07-04-2014, 09:10 AM   #357
rtypec's Avatar
Best regards
Don't know, but I'd imagine that with the design of the mount, anything fits with the right pinion/spur combo. I choose an 84 spur for a range that'll let me use a 17.5 and 13.5. In the picture, you can see there is room in the motor screw slot for bigger pinions.
Old 07-04-2014, 03:47 PM   #358
Obviously plenty about soldering.
That's a very pretty joint to the battery plug
Old 07-05-2014, 07:48 PM   #359
CW22's Avatar
Today my Evo 6 ran very smoothly.
Thank you for all the help from my Tamiya fanatic friends to do the set up.
CHRIS
Tamiya cars.
Old 07-05-2014, 08:28 PM   #360
Trader Rating: 26 (100%+)
Do you still have that Muchmore Legend for sale? Software 1.23D correct? email me at suradajj@gmail.com
Awesome paint btw.
JoeyE is offline   Reply With Quote
