Old 06-30-2014, 12:21 PM   #331
Originally Posted by CW22 View Post
First run EVO 6 at Tamiya Raceway today with 17.5T.
Nice car Chris
fx35rc is offline   Reply With Quote
Old 06-30-2014, 02:42 PM   #332
CW22's Avatar
Trader Rating: 86 (100%+)
Originally Posted by fx35rc View Post
Nice car Chris
Thank you
CHRIS
Tamiya cars.
TRF, Muchmore racing.
CW22 is offline   Reply With Quote
Old 06-30-2014, 07:37 PM   #333
How much timing are you putting into the X20?
I saw it only the bit, I found it.
I've also got camber, droop, ride height for sale if you're enough of a full on tamiya/TRF tragic
cplus is offline   Reply With Quote
Old 06-30-2014, 08:04 PM   #334
CW22's Avatar
[QUOTE=cplus;13371382]How much timing are you putting into the X20?
The X20 is different with the X12 using a dot on the insert. On the X20 they have a numbers, the highest timing is 37.5 is on flat position, that what I use for now.
You can go more by flipping the timing insert to the opposite way. To get more timing.
CHRIS
Tamiya cars.
Old 06-30-2014, 10:54 PM   #335
Yeah I've got a 13.5T X20. Running at 37.5 as well.
Being blinky I think that is pretty mild still.
Old 07-01-2014, 05:42 PM   #336
E-clip's Avatar
Trader Rating: 39 (100%+)
Guys what spur and pinion are you using for stock ?
With a 2.5 internal, spur would have to be quite small ?
E-clip is offline   Reply With Quote
Old 07-01-2014, 06:05 PM   #337
Getting close that you would have to under drive it
Old 07-01-2014, 06:08 PM   #338
CW22's Avatar
You need to use a thin spur gear, otherwise it will touched the motor mounting, for 17.5 you can use a 76/50 or 78/51 = FDR 3.8
That's what I have in my car.
CHRIS
Tamiya cars.
Old 07-01-2014, 07:56 PM   #339
E-clip's Avatar
That would be 48p?
What brand spurs and pinion do you use? I've never seen as high as 50t pinions?
Old 07-01-2014, 08:00 PM   #340
b20btec's Avatar
That would be 48p?
I have crc pinions that I use for tc blinky racing that's way over 50.
Also check out panaracer at rsd, beamcat, crc, prs,
Referring to 64 pitch that is.
b20btec is offline   Reply With Quote
Old 07-01-2014, 08:12 PM   #341
CW22's Avatar
That would be 48p?
Is a 64p, if you can get RW brand at AU that is a perfect size of spur.
If you never seen a 50T pinion, I don't know what to say.
CHRIS
Tamiya cars.
Old 07-01-2014, 08:33 PM   #342
Dusttt's Avatar
Trader Rating: 115 (100%+)
I got lucky and got one from tower.
"Whiskey Tango Foxtrot"
Dusttt is offline   Reply With Quote
Old 07-01-2014, 10:59 PM   #343
Mine was delivered yesterday.
Looks sexy :-)
MiniZ racer trying out m-chassis and TC:)
lmlindbo is offline   Reply With Quote
Old 07-02-2014, 07:11 PM   #344
Are there other brands "spur gear holder #13458130" Modified it?
because the spur gear holder inside ball bearing can't to remove
and have a little wobbly
e58105419 is offline   Reply With Quote
Old 07-02-2014, 10:38 PM   #345
Nice to know about this car,its really awesome in technology.i check it out you submitted blog and about a detail sketch of this electric car.I love to see all this and its very helpful to arrange the parts and made a new one.
Durbin is offline   Reply With Quote
SEO by vBSEO 3.5.0
