Like Tree22Likes
Old 06-20-2017, 03:17 PM   #2506
theproffesor's Avatar
Trader Rating: 56 (100%+)
I could n bet get the metal gears to build a smooth diff. It was always gritty/nothchy feeling. So I only used the metal gears for the front diff with 2.5mil fluid.
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 06-20-2017, 03:47 PM   #2507
nubs's Avatar
I wonder if you were tightening too much. My diffs are pretty smooth.
Tamiya TRF419X | Tamiya TA07 Pro | Tamiya TB04 / Exo Six | AE B5 Converted to B5M
nubs is offline   Reply With Quote
Old 06-26-2017, 06:46 AM   #2508
Professor, would you mind sharing your vta setup? My new motor is due in today. I would like to get it setup this evening, and hopefully give it a shake down run one day this week.
Thanks.
ncpantherfan is offline   Reply With Quote
Old 06-26-2017, 09:40 AM   #2509
Unfortunately, I no longer have any of those setups around.
From what I can remember, low roll centers (no spacers under toe blocks), yoke pink or blue fronts, blue rears. 3k rear diff, spoil or 2.5mil front diff. E front blocks, think e in rear with whatever blocks give you 2.5 deg Rear toe. This was on get carpet, so keep that in mind.
Hope that helps.
Old 06-26-2017, 06:40 PM   #2510
The TB EVO7
lnline motor layout on the left?
maybe like EXO-SIX
e58105419 is offline   Reply With Quote
Old 07-28-2017, 06:41 AM   #2511
Speed Chaser's Avatar
Originally Posted by e58105419 View Post
The TB EVO7
maybe like EXO-SIX
This car really has my attention. I dont know if its just me but it looks heavier then the tb 6
Speed Chaser is online now   Reply With Quote
Old 08-04-2017, 10:25 AM   #2512
Guys i purchased the Exotek conversion kit for the EVO6 and started running this setup for VTA. I've struggled with the chassis transitioning from left to right in slow speed tight corners. Has anyone played with this combo and what are you doing to help with more steering and quicker transitions?
bdw11 is offline   Reply With Quote
Old 08-04-2017, 12:27 PM   #2513
nubs's Avatar
whats happening when you are on power in turns?
Old 08-04-2017, 12:35 PM   #2514
aracefan's Avatar
Trader Rating: 40 (100%+)
Honestly, I would probably try and get a setup from MikeR from Exotek. Let him know what type of surface and I bet he could get you in the ballpark, at least something workable.
All give some, but some give all - thank you veterans for my freedom.
VBC is my new addiction - have Alex Pate at GripworksRC to thank for that!
aracefan is online now   Reply With Quote
Old 08-04-2017, 05:58 PM   #2515
The front end tends to push when i'm power on
Old 08-04-2017, 10:27 PM   #2516
nubs's Avatar
Increase the downstop on the front end or increase strength of the springs in the back or stand the shocks in the back up or increase the thickness of the shock oil in the back or increase the ride height in the back or reduce the ride height in the front.
Old 09-12-2017, 05:53 AM   #2517
Modify my EXO6 rear CVD for ARC new item R112024 42.5mm CVD +R103005 CVD insert
Leester and aracefan like this.
Old 09-13-2017, 12:25 AM   #2518
nubs's Avatar
Why?
Old 09-13-2017, 07:08 AM   #2519
Originally Posted by nubs View Post
Why?
Cause he needed to spend a few dollars
Juan Aveytia is offline   Reply With Quote
Old 09-13-2017, 09:26 AM   #2520
Why?
The R112024 made from 7075-T6 Alu
