Tamiya TB Evo 6
#2477
Usually 2mm to 3mm downstop is the maximum needed...
#2480
Check hinge pins, arm mounts, etc..... It might be that some holes were not perfectly centered, or that the extra right sidde suspension play allowed for the difference .....
#2486
With the crown gear shields in place there have been no issues at all so far.
On a busted up surface or street there could be issues but same goes for the open pinion and spur of any sedan.
But we hope to design something and put it on shapeways so that someone can print a plastic top shield if they wish. For now I just attached lexan shields that covers the crown gears. Same thing you have to do on the Evo5 when you run the larger gear diffs because the plastic covers dont fit.
