Like Tree11Likes
Old 02-22-2017, 07:00 PM   #2461
theproffesor's Avatar
Trader Rating: 56 (100%+)
Well damn those look good. Might have jump the shaft drive ship too soon.
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 02-22-2017, 07:21 PM   #2462
Thanks..... I feel that the high grip surfaces slow my car down to a crawl at three degree rear toe....
Originally Posted by Leester View Post
Not quite, but on high grip carpet or asphalt .5 degrees rear toe works great. Never tried 0 degrees but will do so just to see how it feels compared to .5 degrees.
If conditions change and the car loosens up a bit I first experiment with different rear wings. This is on a GT10 or USGT body where a low or high down force wing can give just the right amount of rear stability and maintain that nice rotation through the turns that shaft drive cars seem to deliver. I usually keep around 4-5 different wings of varying DF. I also run a ball diff which allows for a wide variety of tightness to get that rear end working to perfection.
bertrandsv87 is offline   Reply With Quote
Old 02-24-2017, 06:33 PM   #2463
olhipster1's Avatar
Trader Rating: 97 (100%+)
Send a message via Yahoo to olhipster1
Default Hurry
Originally Posted by MikeR View Post
Yes, progress but slow going due to production demands for our off road parts taking all the machine time. Waiting for some revised samples to try hopefully soon...
Mine...Mine.... Mine.
olhipster1 is offline   Reply With Quote
Old 03-01-2017, 10:07 AM   #2464
Default Help please.
Want to convert an Exo6 from 64 to 48 pitch gearing, who makes a 48 pitch spur for the evo6, and where to start on spur pinion for 17.5 blinky, For Tamiya track.
Slashripper is offline   Reply With Quote
Old 03-01-2017, 11:48 AM   #2465
I use 66 or 60 teeth Robinson Racing for small tracks. FDR really depends of track and rules. On small ones I use 4.5-5.0 FDR on big one less than 4. In our blinky mode timing on the motor could be changed.
Macio4ever is offline   Reply With Quote
Old 03-01-2017, 02:04 PM   #2466
So like a 66 25 for a medium track in 48 pitch?
Old 03-01-2017, 02:09 PM   #2467
nubs's Avatar
Go with a 60, I think a 66 might be too big.
Tamiya TRF419X | Tamiya TA07 Pro | Tamiya TB04 / Exo Six | AE B5 Converted to B5M
nubs is offline   Reply With Quote
Old 03-01-2017, 02:32 PM   #2468
66 and 25 would give you 6.6FDR which is by far to low.
Formula is Spur/Pinion and than * internal ratio (2.5 for Evo 6)
I would start witch something closer to 4/4.5
Old 03-01-2017, 09:44 PM   #2469
MikeR's Avatar
Trader Rating: 15 (100%+)
Use this spur;
ARC R104161 CNC Spur 58T (48dp)
Pinions- motor dependent so stock up on 38-42 teeth.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 03-18-2017, 08:26 AM   #2470
nubs's Avatar
I just purchased the trf419x shocks for this bad boy, any advice on the brand of springs to use? Xray? Yokomo? Tamiya?
Old 03-18-2017, 09:38 PM   #2471
Like I suspected, the suspension always added another 0.5 to 1 degree toe in the rear even with the same arm mounts front and rear... Most stock setups with 2 degrees were actually 3 degrees or more, scrubbing speed, etc....
Old 03-19-2017, 10:06 AM   #2472
nubs's Avatar
Where did this come from. When I use the setup tools it shows the exact correct toe in.
Old 03-19-2017, 10:11 PM   #2473
Leester's Avatar
Trader Rating: 21 (96%+)
Originally Posted by nubs View Post
I just purchased the trf419x shocks for this bad boy, any advice on the brand o.f springs to use? Xray? Yokomo? Tamiya?
You can use either the SMJ short springs, progressive, or the Xray springs, both the linear and progressive. I use progressives in the front and linear in the back. I play around with both kinds and sometimes run both brands on the car (SMJ front/ Xray rear) All depends on grip levels of the track.
What shock towers are you using with them?
Rick Vessell likes this.
Leester is offline   Reply With Quote
Old 03-20-2017, 09:10 AM   #2474
nubs's Avatar
I purchased the CF towers they just released for the tb04
Old 03-20-2017, 05:47 PM   #2475
Sorry nubs, but that measurement was not on an evo6... It was on another car....
