Like Tree11Likes
Old 02-06-2017, 01:10 PM   #2446
gigaplex's Avatar
Originally Posted by aracefan View Post
Okay TB Evo6 experts, I need some help/advice.
I picked up a used TB Evo 6 MS w/Exo6 conversion off of here, used obviously. I got the car in and unfortunately it was in worse shape than described - and such is the risk of buying something used. I'm having an issue with the gear diffs/drive line... The car is "notchy" when rotating the spur gear. There are gear diffs in the front and rear of car, which is fine, I actually run my TC6.1 that way in USGT.
Here is what I've done:
Removed the gear diffs and rebuilt them both, both were not shimmed correctly.
Inspected all the internal metal gears (under magnifier) and they all look clean and straight.
Replaced incorrect shims with new and also shimmed it per instructions.
Replaced green diff seals. Replaced copper bushings with rubber shielded 5x8x2.5 bearings.
Inspected both front and rear gear cases and they look fine.
The screws holding the top deck were too long and didn't cinch down the top deck, so replaced those with the correct screws.
Cleaned, re-greased everything and reassembled the driveline, and low and behold it is doing the same thing...
It's not near as "clicky" as it was but it is still happening.
Now though, I can rotate the spur about 80% the way around and then it "notches" a few times, and then is free. Then does it again... I have no idea what is the issue. I checked the attachment of the stock gear to the Exotek drive shaft at the rear and also the attachment of the front drive gear and they are correct. Wasn't sure if there was a shimming issue there, but as much as I can tell all is correct.
I'm just at a loss on this thing - I have spent about 4 hours working on this car and while it's a little better it still isn't "right". I definitely don't want to run it with this notching issue.
Any tips or suggestions would hugely appreciated.
Thanks in advance,
-Barry
Try isolating each gearbox to see whether the notching is coming from the front or rear. You may need to adjust the shimming away from the manual settings if it's too tight. Just make sure you have a tiny amount of play in the gears, not too much. Also check your bearings if you haven't already.
gigaplex is offline   Reply With Quote
Old 02-06-2017, 02:43 PM   #2447
nubs's Avatar
This is good advice. By the way I had the same problem until I shimmed the rear gear box correctly. I had it too tight.
nubs is offline   Reply With Quote
Old 02-06-2017, 03:04 PM   #2448
B. Santos's Avatar
Thanks in advance,
-Barry
Sounds like it could be a runout issue with the center motor mount/driveshaft bearing.
This is the piece I am refering to:
http://www.exotekracing.com/exo-five...t-replacement/
Loosen the three attachment screws on the bottom of the chassis and align the mount so that it is perpendicular to the driveshaft. This should ensure that the inner wall of the bearing isn't contacting the driveshaft at an angle and is spinning freely.
In addition, check that the motor mount bearing is not seized and that the M2x4 screw attaching the drivecup is tightened down.
B. Santos is offline   Reply With Quote
Old 02-06-2017, 03:42 PM   #2449
nubs's Avatar
Loosen the three attachment screws on the bottom of the chassis and align the mount so that it is perpendicular to the driveshaft. This should ensure that the inner wall of the bearing isn't contacting the driveshaft at angle and is spinning freely.
Hey Brian,
Did you do TCS with your TA07?
Tamiya TRF419X | Tamiya TA07 Pro | Tamiya TB04 / Exo Six | AE B5 Converted to B5M
Old 02-06-2017, 04:08 PM   #2450
B. Santos's Avatar
Originally Posted by nubs View Post
Hey Brian,
I missed the Fresno TCS race entirely. I've just been bench and forum racing since November.
I'm hoping I can make it out to Stockton this weekend and run my Evo6 in 17.5.
Old 02-06-2017, 06:40 PM   #2451
aracefan's Avatar
Trader Rating: 38 (100%+)
Thanks for all the suggestions guys. Can't wait to try these out. Need to do some repair work to my Associated 6.1 (got nailed in the last race at our track), but will give all these a try. I didn't want to spend the $$ getting all new internals if I didn't need to.
Hopefully I can find the issue and this will save me from having to order all new stuff.
All give some, but some give all - thank you veterans for my freedom.
VBC is my new addiction - have Alex Pate at GripworksRC to thank for that!
aracefan is offline   Reply With Quote
Old 02-07-2017, 07:12 PM   #2452
aracefan's Avatar
Thanks for all the suggestions guys! Found that is was the input gear in the front of the drive shaft. Removed the front gear diff and put the gear cover back on and it was smooth, so knew it was something at the front. Before taking the gear diff apart (again) I decided to check the play at the front input gear. Shimmed it per the instructions and added a 0.2 shim at the back of the rear bearing, and voila! Thing is spinning free now. Electronics are going in tomorrow!
Thanks again for the help. Course, I thought I had checked that already, but I guess not.
Old 02-07-2017, 09:07 PM   #2453
I will get even looser after a few racedays....
bertrandsv87 is offline   Reply With Quote
Old 02-07-2017, 09:43 PM   #2454
aracefan's Avatar
You will??
Old 02-11-2017, 11:32 AM   #2455
If anyone is interested in a new lower aluminum ms chassis and lower aluminum gearboxes - shoot me a pm.
jessele is offline   Reply With Quote
Old 02-17-2017, 05:09 PM   #2456
Dusttt's Avatar
Trader Rating: 123 (100%+)
screaming deal if anyone needs one
Tamiya EVO 6 w Exo 6
"Whiskey Tango Foxtrot"
Dusttt is offline   Reply With Quote
Old 02-21-2017, 08:43 PM   #2457
vlad_sa's Avatar
Mike, any news on the aluminum bulkheads?
aracefan likes this.
Tamiya TRF 419X / Tamiya TB EVO 5 Exotek v1 / Tamiya TB EVO 5 Raceberry Edition / Tamiya TB EXO 6 / Tamiya TB EXO 5 Raceberry Edition / Tamiya TA05 v2 Exotek / Tamiya FF04 EVO / Tamiya FF04 EVO Black Edition / Tamiya FF03 EVO / Spice Yokomo BD7 FF / VBC FF17 / Sabre FD Mini
vlad_sa is offline   Reply With Quote
Old 02-22-2017, 01:30 PM   #2458
Anybody experiment with zero rear toe ???
Old 02-22-2017, 05:33 PM   #2459
Leester's Avatar
Trader Rating: 21 (96%+)
Not quite, but on high grip carpet or asphalt .5 degrees rear toe works great. Never tried 0 degrees but will do so just to see how it feels compared to .5 degrees.
If conditions change and the car loosens up a bit I first experiment with different rear wings. This is on a GT10 or USGT body where a low or high down force wing can give just the right amount of rear stability and maintain that nice rotation through the turns that shaft drive cars seem to deliver. I usually keep around 4-5 different wings of varying DF. I also run a ball diff which allows for a wide variety of tightness to get that rear end working to perfection.
Leester is offline   Reply With Quote
Old 02-22-2017, 06:56 PM   #2460
MikeR's Avatar
Trader Rating: 15 (100%+)
Yes, progress but slow going due to production demands for our off road parts taking all the machine time. Waiting for some revised samples to try hopefully soon...
rtypec likes this.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
