Like Tree23Likes
Old 12-24-2016, 09:48 AM   #2416
Leester's Avatar
Trader Rating: 21 (96%+)
Originally Posted by MikeR View Post
Hi! Hope you enjoyed Japan.
Yes to the flex top plate, I have been using them since the CenCal race. No to bulkheads- still waiting for samples.
No plans for the EXO5 at this time so I would slot the stock plates.
Japan was awesome! Got to use my Japanese to meet a bunch of great drivers at the AOC. Made lots of new friends. Had a blast in Tokyo the week following.
It would be fun to get a few drivers together to go again next year. Yatabe Arena is a place where everyone needs to race at a least once in their life
Is the flex top deck the same thickness as the standard deck just with the tabs cut out?
Leester is offline   Reply With Quote
Old 12-28-2016, 09:18 AM   #2417
MikeR's Avatar
Trader Rating: 15 (100%+)
Sounds awesome! I would go if they are racing on asphalt
The new top plate is 2mm vs the stock 2.25mm.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 12-29-2016, 08:01 AM   #2418
nubs's Avatar
Mike have you thought about doing a double cardan joint replacement made of titanium?
Tamiya TRF419X | Tamiya TA07 Pro | Tamiya TB04 / Exo Six | AE B5 Converted to B5M
nubs is offline   Reply With Quote
Old 12-29-2016, 08:54 AM   #2419
I had a few dcj/lcd drives made out of 7075 aluminum for my AE car, and saved 4grams per corner. Titanium would not save as much weight. I would only recommend them for stock racing though...
bertrandsv87 is offline   Reply With Quote
Old 12-29-2016, 03:39 PM   #2420
Anyone interested in a pair of lower aluminum gearboxes (tamiya 84425). Never ran, but were installed on car. Still look new! shoot me a PM if interested.
jessele is offline   Reply With Quote
Old 12-29-2016, 03:43 PM   #2421
nubs's Avatar
I'm thinking reduced rotating mass and same level of resistance to wear.
Old 12-29-2016, 08:19 PM   #2422
MikeR's Avatar
I can look into after I wrap up a bunch of other projects in a few months.
Old 12-30-2016, 08:37 AM   #2423
nubs's Avatar
Awesome.
Old 12-30-2016, 12:50 PM   #2424
Understood, but titanium is so much weaker than steel parts that I prefer aluminum 7075. I've broken alot more titanium screws and parts then aluminum over the years, and aluminum will rather bend than snap like titanium(too costly)....
Old 12-30-2016, 02:57 PM   #2425
gigaplex's Avatar
Titanium is stronger than aluminium, and once aluminium bends, it's junk.
gigaplex is offline   Reply With Quote
Old 12-30-2016, 04:11 PM   #2426
Most of the forces that bent my aluminum parts also snapped the titanium parts I swapped in... I had to go back to steel in these cases: ntc3 lower shock screws, ntc3 arm mount screws, ntc3 pivot balls, etc...
I am sure the bent aluminum parts are junk after bending, but at least you'll be able to finish your main: not the case if you're snapping titanium parts....
Old 12-30-2016, 06:01 PM   #2427
fyrstormer's Avatar
That must've been some exceptionally cheap titanium if it snapped and the aluminum parts didn't. There are lots of titanium alloys, and they have a pretty wide range of strengths. Try to stick to 6Al4V titanium when you can, like what Lunsford sells, or at least stick to titanium alloys that have *some* kind of metallurgical name assigned to them. China is the king of cheap no-name titanium right now.
Check out Fyrstormer's Garage in the Chat Lounge.
fyrstormer is offline   Reply With Quote
Old 01-01-2017, 12:58 PM   #2428
theproffesor's Avatar
Trader Rating: 57 (100%+)
Well car number one is gone to a good home. Car number two is available. Not quite as decked out as the first but still a great car.
Tamiya EVO6 Exotek EXO6 conversion USVTA USGT
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 01-11-2017, 01:53 PM   #2429
ruebiracer's Avatar
Finally finished my Tb03 R with Exo 6 Conversion and some Evo 6 bits!
What I have left is the old reversible suspension arms and the toe blocks.
Now IŽd like to know, how the the new style (Evo6 / Ta 07) blocks are geometrywise compared to the old 416 style?
I did not find an overview of the new ones.
If they are named 05F, is it the same as an old F with raise of 0,5 mm?
And there are even G blocks? Should be really wide, or just a new order?
If you you have any links or toe chart, IŽd really be happy!
DonŽt want to spend a lot of money yet, if I can stay with the old blocks maybe...
Will run 21,5t Fun class end of January, and see how the baby feels. Really curious about the conversion. Changed diff oil to 2k in rear, as in the first training I had some loose rear end on throttle out of the corner, racing on carpet.
Kind regards,
Matthias
www.TTSC-Racing.de
www.mst-estenfeld.de/der-loeffler-cup
ruebiracer is offline   Reply With Quote
Old 01-12-2017, 05:20 AM   #2430
The blocks are the same in width, so an E block is the same width if its 'E' '.5E' or '1E' the only difference is the height. 'E' is the highest, '1E' is 1mm lower than 'E' and '.5E' is 0.5mm lower than 1E.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
