Old 06-04-2014, 04:40 PM   #226
The set sheet doesn't have a "spot" to capture droop - or am I blind?
cplus is offline   Reply With Quote
Old 06-04-2014, 08:03 PM   #227
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Is that what they refer to as "Rebound Stroke"?
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 06-04-2014, 08:24 PM   #228
2-Bad's Avatar
Trader Rating: 24 (100%+)
No I don't think so... When you push the shock shaft all the way in and let go the shaft can then slowly slide back out. The measurement of how much the shaft slides out is "rebound stroke"
Generally referred to as zero rebound (doesn't slide back out at all), or 50% rebound (slides back out 6mm), etc....
Droop is the measurement of how much the suspension arms free hang when the chassis is sitting on Droop blocks (wheels off the ground).
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 06-04-2014, 11:30 PM   #229
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Yes, it is.
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 06-05-2014, 03:17 AM   #230
Yep, but to be pedantic, the sheet usually refers to the down stop setting (which we TC guys usually call droop) although droop is actually the amount of movement a chassis has from rest until the tyres at that end of the car lift of the ground. But it's much easier with rubber TC racing to use the downstops as a base measurement as our tyres are a very similar size.
And the evo sheet seems to have forgot them although I am surePetitRC will add the field on their editable version. (Maybe Kentech's car is so new they hadn't finished printing the sheet
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 06-05-2014, 03:46 AM   #231
Originally Posted by CraigMBA View Post
Yes, it is.
I don't agree. Look at a 418 setting sheet in comparison. It shows both.
That's what I wrote on his blog - printers forgot
I also find it odd now that the new sheets are showing droop measured from the pin centre, not under the arm. Bit dumb/confusing when every droop block and gauge set (including their own) is designed to measure under.
Old 06-05-2014, 04:21 AM   #232
The 417 sheets changed from under arms / hinge pin but the common language is still under arm as that's what most set-up stations (all) use.
The evo6 one might have dropped it again (the 416 never had it on the form) you just made a note in the memo section.
Old 06-05-2014, 04:34 AM   #233
I've actually seen a 417 sheet with under for front and pin for rear! (Or vice versa)
Old 06-06-2014, 05:28 AM   #234
Looking at the parts list on Kentech's site http://data9.blog.de/media/767/7845767_f40697b9de_d.pdf
Some interesting observations (well, perhaps )
- included are metal gears in the diff (better than 418 gets!) and yet tamiya haven't bothered to include metal cross pins, but give you a complete set of GV parts just for the cross piece....
- different rate springs front and rear - heavy back end perhaps?
- same mistake as the 418 manual, it lists the suspension shafts as part number 53827. Bzzt, wrong. It's 53825. 53827 are roll bar rod stoppers. Proper train spotting that.
- gets the new 4deg hubs that clear DCJs properly. 418's deserve to have these. Probably will come with the X/Worlds Edition (pending if they win or not!)
Looking forward to Ken's build!
Old 06-06-2014, 09:37 AM   #235
kentech's Avatar
Posted some pictures of parts + some comments.
Will soon start building the Evo 6.
I'll post more when built.
http://kentech.blogs.se/
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 06-06-2014, 12:20 PM   #236
CraigMBA's Avatar
I'm inclined to think you are right, and I wasn't.
I assumed it was something lost in translation, but maybe it's so users can identify what length shocks (short or standard) are being used.
Old 06-06-2014, 05:52 PM   #237
Thumbs up
Nice detail photos as always Ken.
Old 06-08-2014, 02:19 PM   #238
Is there a official releasedate for the Evo yet?
<Awesomatix A700 EvoII><Highest><Sanwa><Muchmore><Fantom>
<Awesomatix A800a><Hitec><Sanwa><Muchmore><Fantom>
<VBC LightningF><Hitec><Sanwa><Muchmore><Skyrc>
<=Team Autopartner=>
Gillblade is offline   Reply With Quote
Old 06-09-2014, 05:03 AM   #239
Clawhammers's Avatar
28th June 2014 for Japan domestic market.
Source:
http://www.tamiya.com/japan/news/new...it=72#calendar
Clawhammers is offline   Reply With Quote
Old 06-09-2014, 07:55 AM   #240
d16dcoe45's Avatar
The steel diff gears are nice in that you don't have to sand them but they are quite a bit heavier. I had them and replaced them with stock plastic that I sanded down to equal the width of the steel gears. I also use the 1-piece plastic cross pin--even with 500k in front diff.
Rheinhard runs plastic--I assume for weight savings. If they hold together with a 4.5--they are great for me in 17.5. Never had a single issue with plastic gears.
Jay Lestingi
Tamiya 419x/Associated TC7.1/Sanwa M12s/Xpert servos
d16dcoe45 is offline   Reply With Quote
SEO by vBSEO 3.5.0
