Like Tree23Likes
Old 10-26-2016, 06:15 PM   #2296
gigaplex's Avatar
Originally Posted by Dan View Post
Maybe because the camera person was focusing on driving HIS car....LOL (orange NSX)
Your car was super fast at Q3 Mike!
I didn't realise it was another driver filming, as it's not always following a single car.
gigaplex is offline   Reply With Quote
Old 10-26-2016, 07:06 PM   #2297
MikeR's Avatar
Trader Rating: 15 (100%+)
Was.... lol. Isn't that when I blew my motor?
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 10-26-2016, 07:20 PM   #2298
Trader Rating: 28 (100%+)
Your Actinium blew in rnd2. You were way faster with the R1 in round 3 and 4.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 10-26-2016, 08:24 PM   #2299
MikeR's Avatar
It was all a blur after running 3 classes haha!
Old 10-27-2016, 06:14 AM   #2300
Originally Posted by theVetteman3 View Post
It absolutely fits the MS, I just did a new build converting my MS a few weeks ago. I've been lurking for a while, getting back into touring cars since I raced TC3s in the early 00s. Kit installed great Mike, I'll post up some pics when I have sufficient posts to do so.
Thanks Guys !
much appreciated All
Ralf is offline   Reply With Quote
Old 10-27-2016, 06:57 PM   #2301
The car did look fast in the video. The 6.3gram spool might be helping , but I hope there are more lightening upgrades to follow...
bertrandsv87 is offline   Reply With Quote
Old 10-28-2016, 11:03 AM   #2302
Guys I'm looking for a second gear diff for tuning purposes. Is the only way to get a Tamiya one to spec out the parts? No kit available like there is for the TB04 ball diff? Even from shops in HK the pricing is still kind of steep to build your own.
And secondly if that is the case, it sounds like the Spec R TB03 gear diff is a good alternative. It drops right in, or does with minor modification?
theVetteman3 is offline   Reply With Quote
Old 10-28-2016, 11:21 AM   #2303
theproffesor's Avatar
Trader Rating: 57 (100%+)
I had to piece out a spare diff. No kit available. I don't believe the TB03 is a direct drop in. It will change the gear ratio.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 10-28-2016, 01:13 PM   #2304
Yep spec out bits for a new TB04 gear diff. TB03 will not mesh properly with the TB04 pinion and will affect gear ratio
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P12 & F1 / Schumacher Mi6Evo / Awesomatix A800 / Xpress XQ1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
WagwanBumba is offline   Reply With Quote
Old 10-29-2016, 01:55 PM   #2305
Wow that's good to know that there's a ratio change. I will stick with a Tamiya diff then. Thanks for the info.
Old 10-29-2016, 02:47 PM   #2306
OVA
OVA's Avatar
Trader Rating: 77 (100%+)
Just change the ring gear..TB03 is 39T and the TB04 is 40T
no big deal..just switch them....
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 10-30-2016, 07:02 PM   #2307
First time back on the track in 4 months. Had a good time. But also has some issues... got rear ended while at a stop on the side of a slow part of the track to check some transmitter settings, and WHACK. Someone running a 17.5 found me like a heat sneaking missle at full throttle. Car landed on its wheels, so I drove it and it seemed fine. But... it also seemed really slow, and after a few laps I pulled it off. Motor was very warm. Warmer than it should be. Looked at the car car and the gear mess was too tight. Ahhh easy fix. Nope... that wasn't it. What the heck could be causing the drive train to be bound up. Checked the new evonspool that was a pain the shim. Spinning like it was on ice. Bent shaft... nope. As I get to the rear of the car to check the diff I find this...
Some how the whole rear input shaft/spur holder shifted back and got knocked out of the motor mount. Nothing else was wrong with the car. The lower chassis was just flexing down. Glad it wasn't an aluminum chassis. Would be FUBAR. So a V2 motor mount in the works with more bearing surface area?
Also in my 17.5, I striped my plastic diff internals, and luckily had the metal ones for a quick trackside rebuild. But in order to get it to operate freely, I had to loosen the screws a bit. And of course the fluid slung out. How are you guys building the diffs with the metal gears properly?
Also a starting 17.5 (Grey) carpet setup would be awesome. I was fighting mine all day trying to move it from USGT. The rear tires might have been drift tires. I was running jaco blues like everyone else
Old 10-30-2016, 09:29 PM   #2308
vlad_sa's Avatar
I'm thinking to give Tamiya diffs a try in my Exo 6. I drive Spec-R diffs in all of my EVO's rear and front (RB EVO, Exo 6, Exo 6). They should be easier to maintain.
vlad_sa is offline   Reply With Quote
Old 10-30-2016, 09:37 PM   #2309
vlad_sa's Avatar
Here is my Exo 5. Fantastic car! And with 419X shocks and raceberry low profile towers, low rider. Waiting on my raceberry chassis and top deck. Think we can slide the Exo 5 in EVO 6 thread
Tamiya TB Evo 6-img_5097.jpg   Tamiya TB Evo 6-img_5098.jpg   Tamiya TB Evo 6-img_5100.jpg   Tamiya TB Evo 6-img_5101.jpg   Tamiya TB Evo 6-img_5099.jpg
Tamiya TRF 419X / Tamiya TB EVO 5 Exotek v1 / Tamiya TB EVO 5 Raceberry Edition / Tamiya TB EXO 6 / Tamiya TB EXO 5 Raceberry Edition / Tamiya TA05 v2 Exotek / Tamiya FF04 EVO / Tamiya FF04 EVO Black Edition / Tamiya FF03 EVO / Spice Yokomo BD7 FF / VBC FF17 / Sabre FD Mini
Old 10-31-2016, 08:00 AM   #2310
Josh-n-ya's Avatar
Trader Rating: 75 (100%+)
Back with good results from the weekends CenCal Challenge. USGT was by far the biggest class of the 3 day race and the EXO-SIX represented well!
Had to work from way back in the field (blew a motor in qualifying, cost me a better grid spot) but was able to pick off some very fast cars 1 by 1 and ended up 2nd place and less than 1 second behind first. Have only ran this USGT car at 2 events this year but really loving the drive train and Tamiya handling!
Notes;
Prototype flexy top plate for extra grip on the bumpy asphalt track.
Exotek spool used.
Prototype carbon drive shaft.
Off the shelf (Hobbytown) R1 v11
Exotek C-hubs
Congrats Mike. We never were formally introduced and didn't know who you were till after I got home. I was just hoping to grab a third spot that day but as luck would have it. It turned out much better. I miss my exo6 and I think the new flexy top deck is a huge improvement for asphalt. Your car was hooked up.
Josh-n-ya is offline   Reply With Quote
