Like Tree23Likes
Old 09-30-2016, 10:23 AM   #2251
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by ErikO View Post
On the subject of gear diffs, has anyone broken the plastic internal gears or shafts? I put the metal ones in my TB04/EXO6 but the weight savings of the plastic parts is tempting.
I understand on an offroad car you'd want metal to withstand the shock loads, but are onroad cars as demanding?
I've only ran the plastic gears in my 06- so far so good but just running 17.5/21.5 lately.
I think if you run heavier oil (3k and up) the plastic will have no issues. Lighter oils may need need more attention.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 09-30-2016, 10:40 AM   #2252
snopro31's Avatar
Trader Rating: 36 (100%+)
Has anyone ran the car on the new black crc carpet and the old grey stuff?
looking to see if the alloy chassis was needed on the black carpet and if you felt it was needed on the old grey carpet.
snopro31 is offline   Reply With Quote
Old 09-30-2016, 10:45 AM   #2253
Good to know. Might switch them out for the weight savings!
:: Tamiya TA05 MS :: Tamiya TB04 Pro II/Exotek EXO6 :: Tamiya M05V2 :: Losi XX :: Tamiya TB01 :: Tamiya XV-01 Rally ::
ErikO is offline   Reply With Quote
Old 09-30-2016, 11:25 AM   #2254
mac853's Avatar
Originally Posted by RedBullFiXX View Post
Used an 88t at the Reedy Race
I think that's about as large as one should go
Originally Posted by WagwanBumba View Post
I'm using 88T 64DP spur. Wouldn't go any larger than that really as it will get really close!
Thanks!
mac853 is offline   Reply With Quote
Old 10-02-2016, 10:35 PM   #2255
mac853's Avatar
Sorry, i want also to ask the biggest pinion could use on Exotek chassis?
Best regards
Old 10-02-2016, 11:02 PM   #2256
vivo quevas's Avatar
Trader Rating: 18 (100%+)
Best regards
It depends on the spur but I run a 81t spur with a 66t pinion and there is still room for a bigger gear then that.
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 10-03-2016, 02:50 AM   #2257
mac853's Avatar
Yep, in fact i saw somebody ream upper deck to use a 6+t pinion.
In fact i wonder also to run 70t spur with 63t to 65t pinion, but i guess has some issue to fix.
Thanks!
Old 10-03-2016, 03:25 AM   #2258
Hey Guys, do you use the Reinforced Gear set (54593) or the standard one (51547)?
Brinni is offline   Reply With Quote
Old 10-03-2016, 01:19 PM   #2259
HornyToad's Avatar
Trader Rating: 26 (100%+)
Thanks!
Right now im using 70t spur with 62 pinion with no issues. Now, if the motor screws were a little bit easier to get at.... 🙄🙄🙄
Good Times Racing
Sponsors: Visa, AmEx, My Wife, My Children's College Fund...
In God we trust.... All others must bring data.
HornyToad is offline   Reply With Quote
Old 10-03-2016, 06:44 PM   #2260
theproffesor's Avatar
Trader Rating: 57 (100%+)
To get at the motor screws I use a 2mm hex ball driver and I lossen the rear top deck screws. Get to them no problem.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 10-04-2016, 09:28 AM   #2261
mac853's Avatar
Thanks!
Old 10-04-2016, 11:24 AM   #2262
snopro31's Avatar
ill try again hopefully someone has ran the car on either carpet with the alloy chassis
Old 10-05-2016, 10:22 AM   #2263
nubs's Avatar
FYI the Alu C hubs and the light weight spools are in stock at exotek.
Tamiya TRF419X | Tamiya TA07 Pro | Tamiya TB04 / Exo Six | AE B5 Converted to B5M
nubs is offline   Reply With Quote
Old 10-05-2016, 02:38 PM   #2264
Yup, hope I didn't buy them out. Got a set for all three of my cars!!!
Old 10-06-2016, 11:26 AM   #2265
aracefan's Avatar
Trader Rating: 40 (100%+)
My Exo-6, haven't had the chance to put gear in this yet, but wanted to show it off.
She's never even been set on the ground. Beaut of a kit, I love the Exotek conversion.
Contemplating letting her go, as it seems it will just be on my shelf for awhile longer. . .
Also, have a stock TB Evo6 (also never run) that will be in the for sale section tonight.
All give some, but some give all - thank you veterans for my freedom.
VBC is my new addiction - have Alex Pate at GripworksRC to thank for that!
aracefan is offline   Reply With Quote
