Like Tree23Likes
Old 09-27-2016, 05:27 AM   #2236
Originally Posted by Sjim View Post
I can check if the sound comes from the motor. It is a 17,5 LRP X12 Vector Stock Spec.
So what kind of spur or pinion do you prefer? Is it possible to change the brand from Tamiya to, for example, Arrowmax spur gear?
And I checked the car again and it has a 66T spurgear that came with the car and a 33T pinion. Both from Tamiya.
So you might have a 04-module pinion and 06-module spur. Tamiya uses both. The biggest 06-module pinion I have seen is 29 or 30 teeth, which indicates that your pinion is not 06-module.
The spur I have is RW Racing Supa-Lite spur gear 48P.
I think XRay spurs fit too, not sure about others
Rudie is offline   Reply With Quote
Old 09-27-2016, 05:36 AM   #2237
Ok thanx!
And if I use the RW Racing Supa-Lite. Can I use the 04-module to fit the spurgear?
Sjim is offline   Reply With Quote
Old 09-27-2016, 06:17 AM   #2238
Ok thanx!
Probably not. Make sure the pinion is 48dp too. I would advice you to get rid of the 06 or 04 modules and go for all 48dp (or 64dp) gearing. Gives more gearing options.
Old 09-27-2016, 06:36 AM   #2239
Thanx for all the help. I will try different things and I will get back to you guys with the result.
Old 09-27-2016, 02:28 PM   #2240
theproffesor's Avatar
Trader Rating: 57 (100%+)
If I switch to the spec r diff, I know I would need to switch to the 39 tooth gear on the front spool, but do I also need to change the input gears, or do the sock ones work?
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 09-27-2016, 02:44 PM   #2241
MikeR's Avatar
Trader Rating: 15 (100%+)
SpecR must use both Tb03 gears.
The TB03 and Tb04 gears are matched sets, different ratios and cannot intermix. They have a different thickness (off set) so different spools as well unfortunately...
I have switched from SPec R to the TB04 gear diff. After putting in alum m2 screws and alloy outdrives the weight is now within 1-2 grams of my spec r gears. And now I can use the more durable white outdrive pucks. The black pucks that you use with the spec r seems to wear out after every race day
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 09-27-2016, 05:50 PM   #2242
Thanks for the info. I'll stick with the Tamiya diffs so I can still run the EXO spool.
Old 09-28-2016, 11:40 AM   #2243
nubs's Avatar
Any particular reason not to use the ball diff?
Tamiya TRF419X | Tamiya TA07 Pro | Tamiya TB04 / Exo Six | AE B5 Converted to B5M
nubs is offline   Reply With Quote
Old 09-28-2016, 02:17 PM   #2244
vivo quevas's Avatar
Trader Rating: 18 (100%+)
Nubs there is no reason not to use a ball diff they are lighter and my car has never performed better. Since the ball diff is in a housing that protects it from dirt the maintenance is very low I grease the ball after every 3 race days after a few rebuilds you know a how much to tighten the diff to get the car
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 09-28-2016, 02:29 PM   #2245
I waited for this car as I wanted a modern shaft drive TC with a gear diff that wasn't almost a grand. I know lots of people like the ball diff and that's fine, I just prefer the gear. Set it and forget it.
I have been doing this for 25 years and can build a butter smooth ball diff, I just don't want to deal,with it anymore.
Old 09-28-2016, 06:44 PM   #2246
On the subject of gear diffs, has anyone broken the plastic internal gears or shafts? I put the metal ones in my TB04/EXO6 but the weight savings of the plastic parts is tempting.
I understand on an offroad car you'd want metal to withstand the shock loads, but are onroad cars as demanding?
:: Tamiya TA05 MS :: Tamiya TB04 Pro II/Exotek EXO6 :: Tamiya M05V2 :: Losi XX :: Tamiya TB01 :: Tamiya XV-01 Rally ::
ErikO is offline   Reply With Quote
Old 09-29-2016, 09:07 AM   #2247
mac853's Avatar
Could somebody tell me the biggest spur gear could use with exo-six chassis, please?
mac853 is offline   Reply With Quote
Old 09-29-2016, 12:51 PM   #2248
nubs's Avatar
MikeR recommended a 55T 48P spur gear. I believe that a 60-61 will fit though. I'm not sure about 64P.
Old 09-29-2016, 01:09 PM   #2249
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Used an 88t at the Reedy Race
I think that's about as large as one should go
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 09-29-2016, 08:29 PM   #2250
I'm using 88T 64DP spur. Wouldn't go any larger than that really as it will get really close!
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P12 & F1 / Schumacher Mi6Evo / Awesomatix A800 / Xpress XQ1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
WagwanBumba is offline   Reply With Quote
