Like Tree23Likes
Old 08-20-2016, 12:07 PM   #2176
Originally Posted by MikeR View Post
Hi!
That's a little vague sorry. Slow because of pushing, loose, entry or exit and carpet or sphalt?
It's pushing, mainly at the corner entry but through the whole corner.
The track is a 300 Meter asphalt Track. In the curves marked green I have the most problems.
Greetings
Brinni is offline   Reply With Quote
Old 08-20-2016, 03:25 PM   #2177
MikeR's Avatar
Trader Rating: 15 (100%+)
Greetings
Ok Thanks-
First I would make sure I have plenty of steering end point. Full steering lock stops just before touching knuckles and after that try moving front shock to hole 4 and rear shocks to 5.
Is your motor 17.5 or 7.5?
If 17.5 then I would reduce the rear toe by a lot. I am running RF=D RR=F. Makes the rear wider as well for better weight transfer to front tires.
Lastly I would try 1mm spacers under both rear hinge blocks (higher rear roll center). The rear will then have less side bite (less side roll but more front to back weight transfer).
Let us know how it goes. Plenty of things to try still
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 08-20-2016, 04:24 PM   #2178
Thank You! I drive 17,5T.
I will try your Tips tomorrow!
Old 08-20-2016, 08:53 PM   #2179
vivo quevas's Avatar
Trader Rating: 18 (100%+)
Greetings
Less front droop softer front springs more ackerman
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 08-20-2016, 08:55 PM   #2180
Greetings
Less front droop more rear droop softer front springs more ackerman
Old 08-21-2016, 05:06 PM   #2181
What C-hubs work should I be looking for to reduce slop and increase strength?
Thanks,
Dave
dave is offline   Reply With Quote
Old 08-21-2016, 05:48 PM   #2182
theproffesor's Avatar
Trader Rating: 57 (100%+)
I currently use the TA05 hubs, but they are a but too flexible. Haven't broken one since swapping. I am going to get a set of the exotek aluminum c-hubs when they are released.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 08-23-2016, 12:56 AM   #2183
Thanks.
Old 08-23-2016, 08:17 AM   #2184
MikeR's Avatar
Should be Monday after we package them this week
If anyone is looking for a very rare Evo5/Exo5 roller, can be .... oops gone to Lee!
Old 08-23-2016, 02:16 PM   #2185
nubs's Avatar
What about the lightweight spool?
Tamiya TRF419X | Tamiya TA07 Pro | Tamiya TB04 / Exo Six | AE B5 Converted to B5M
nubs is offline   Reply With Quote
Old 08-25-2016, 07:41 AM   #2186
Ok Thanks-
I've tested it and have done some little changes. It's faster, now the rear is a bit light but it feels great and controllable. I'm loving it!
Thanks so far
Old 08-25-2016, 12:45 PM   #2187
MikeR's Avatar
Thanks so far
Great to hear! If the balance feels great then you just adjust tire prep via sauce as needed by way of more or less saucing on the front tires.
Some came in-
http://www.exotekracing.com/
Old 08-25-2016, 01:23 PM   #2188
B. Santos's Avatar
The spool and hubs look great. I just placed my order for both. I didn't want to to get greedy, so I only ordered 1 set of hubs. Thanks Mike!
Some came in-
B. Santos is offline   Reply With Quote
Old 08-31-2016, 11:46 AM   #2189
Trader Rating: 22 (100%+)
I'm considering getting a TB EVO 6 MS to run VTA on my local carpet track and possibly some outdoor asphalt. Should I even consider the EVO 6 MS to run a 25.5T in the box MS configuration or is the EXO 6 conversion pretty much a necessity to run the high turn spec motors? I was all set to pull the trigger on the TB EVO 6 MS but after reading into it I have concerns about the additional gear box that's needed to run the transverse motor negating the efficiency of the shaft drive power train.
Plan B was to get a TA-07 Pro with some extensive option parts but I liked the fact that the TB was shaft drive and came pretty well equipped out of the box.
I'm a regular off-road driver who is looking to get back into on-road for a change of pace, so I won't be able to push either option to its limit. I just want to make sure I don't choose a chassis that is completely wrong for VTA.
AMessy is offline   Reply With Quote
Old 08-31-2016, 11:55 AM   #2190
nubs's Avatar
The spool is out of stock
