Like Tree23Likes
Old 07-16-2016, 04:13 AM   #2071
theproffesor's Avatar
Trader Rating: 57 (100%+)
Does the 6ms come with the new 419x arms and rear hubs? Or any other 419x parts?
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 07-16-2016, 04:35 AM   #2072
Tom1977's Avatar
6MS comes with the 418 arms because the kit has the old short type dampers. But you can hop up the new 419x 0.5 key locked separate suspension blocks and the new 419x battery holder, which both i've installed.
Regards.
Tom1977 is offline   Reply With Quote
Old 07-16-2016, 11:59 PM   #2073
just a few a questions on the 6ms...
what size pinion gear should i run with a 13.5 brushless motor for just cruising around the parking lot?
whats the advantage of using the separate suspension blocks vs the kit supplies one piece?
also, where did can you get the 419x battery holder?
jessele is offline   Reply With Quote
Old 07-17-2016, 02:51 AM   #2074
Tom1977's Avatar
For 13.5 blinky I would suggest a fdr of 5.0 as a starting point. Depends on your motor.
With seperate suspension blocks you can fine tune flex characteristics as the 6ms with his aluminium lowerdeck is stiff as hell.
419x battery holders you can get here: http://www.modellbau-seidel.de/index.php?firma=Tamiya&best=9804950
But they are on backorder at the moment...
Old 07-17-2016, 08:05 PM   #2075
Hey folks
I'm looking to pick up a black edition Evo6. Can someone help explain to me what the issue is with the drive train in terms of efficiency? And is it really worth getting the Exo6 conversion? Looking to run it with 10.5
I read somewhere about the L/R balance issues but Kentech's build on to the 4 corner weights seems alright.
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P12 & F1 / Schumacher Mi6Evo / Awesomatix A800 / Xpress XQ1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
WagwanBumba is offline   Reply With Quote
Old 07-18-2016, 12:41 PM   #2076
OSherman's Avatar
Ran EVO6 with new 'MS' motormount this weekend.. Was nice and consistent during the early stages of the day then slowly petered out as the day went on.. was the fastest car on track at one time...
upon inspection at home after the practice day it was nice to find that the inconsistency and loss of performance was NOT due to the new MS motormount.. it was some other voodoo that I do.. crown gears at motormount showed minimal wear.
next weekend I predict better/more consistent results with this car.
...to be continued
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 07-19-2016, 01:18 AM   #2077
Originally Posted by WagwanBumba View Post
Hey folks
Evo 6 Black is in my hands!!!
So I've read all 139 pages and have come to these conclusions if I want to run 10.5
SHIM SHIM SHIM - especially the gearbox bevel pinion. Seems 0.3mm is the way to go on the drive shaft side to get rid of the gear plunge.
Tap the diff case threads - stop the screw from expanding and perhaps distorting the gearbox case
I'm half and half on whether to get the Exo6 conversion ... worried as I'm planning to run 10.5 that the main axle drive cups will constantly spread.
Saw a sneaky note from MikeR about Exotek making an alu upper with 419 style camber mounts. Will be eagerly waiting!
And will post some pictures up when the build is done
Old 07-19-2016, 01:51 AM   #2078
Hope that rumor is true... along with some nice aluminum lowers too. I've got plenty of time to wait until late ocover rolls around and I can get racing again.
Old 07-19-2016, 05:46 AM   #2079
RX7FC3S's Avatar
...to be continued
What type of track did you ran? Carpet or asphalt?
I don't like the MS because of the aluminium chassis and I can go to an asphalt track much easier than a carpet one...
RX7FC3S is offline   Reply With Quote
Old 07-19-2016, 08:28 AM   #2080
MikeR's Avatar
Trader Rating: 15 (100%+)
Hi All,
Great results with the Tamiya/EXO-SIX! TQ'd and won USGT class at the packed 8th annual Time Zone Grand Prix.
On the big open track the EXO SIX drive shaft really shown through as it out powered the belted cars quite visibly. The only car that could match the top speeds were a carbon fiber TC4 car but thats where the Tamiyas infield handling took over. Really loving this car even if I say so myself lol
Note, alloy chassis was used simply because of the 1450gr weight rule. I still had to add many blocks of lead.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 07-19-2016, 09:35 AM   #2081
OSherman's Avatar
I play at Tamiya America Raceway.. outdoor, asphalt. I'm currently running the original CarbonFibre chassis.. I don't totally believe in any Aluminum Chassis strategy personally. (long story, wont get into that)..
Only thing I'm using from the MS kit on my car are the Motomount and the new 'lighter' Alum Shocktower Stays. (you save about 2.5g per)
•KO Propo America
•EXOTEK
Old 07-19-2016, 09:44 AM   #2082
JimmyMac's Avatar
Originally Posted by MikeR View Post
Hi All,
Nice! Are those new chubs? Are they for sale??!!
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 07-19-2016, 09:46 AM   #2083
OSherman's Avatar
Thumbs up
I like!!
•KO Propo America
•EXOTEK
Old 07-19-2016, 10:36 AM   #2084
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default awesome track
that track is awesome....wish i could be there.
Chubs more awesomenesssss
if anyone is interested....bought 1 to many Evo 6's v2
Tamiya Tb Evo 6 MS vii
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 07-19-2016, 03:26 PM   #2085
MikeR's Avatar
Yes, likely eta Aug 16.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
