Like Tree11Likes
Old 07-09-2016, 07:16 AM   #2056
theproffesor's Avatar
Trader Rating: 56 (100%+)
To fo along with that, something I had to do on my VBC to get 5mm ride hight in VTA was to cut 2 or 3 mm off the top of the lower shock eyelet. It does the sa me thing the -1mm spring retainers do.
You actually have to measure the eyelet, not the amount you cut. You want to make sure all 4 are the same length.
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 07-09-2016, 04:43 PM   #2057
Dyingslow's Avatar
The part number for the 1mm down spring retainer is 53876. It is for the standard diameter spring.
Dyingslow is offline   Reply With Quote
Old 07-12-2016, 07:50 AM   #2058
anyone selling a lower tamiya carbon deck (13408014)?
I'll probably start assembling my kit this week, what extra size shims do I need?
jessele is offline   Reply With Quote
Old 07-12-2016, 09:12 AM   #2059
B. Santos's Avatar
3mm shims for steering (Item# 53585)
5mm shims for the internal input shafts (Item# 53587)
10mm shims for the differential and spool outdrives (Item# 53588)
The kit comes with some of these shims already, but having various thicknesses (0.1mm, 0.2mm, and 0.3mm) on hand will allow you to shim the gears more precisely.
Use the kit shim settings as a base, then check for feel from there. The key is getting the proper backlash between all the internal gears, the same as you would a pinion and spur.
The gear boxes should be free spinning and without bind once the upper covers are in place and screwed down.
As mentioned in the TB04 thread and elsewhere in this one, shimming the gearboxes properly takes patience, but is definitely worth it.
For steering, my TB04-R required a few extras to take out slop, but my Evo was perfect per the manual, it could be different on your build.
B. Santos is offline   Reply With Quote
Old 07-12-2016, 11:19 AM   #2060
Trader Rating: 18 (100%+)
I'm selling a NIP tb04-R. Great for the Exotek conversion. Check it out in the for sale section!
TamiyaMatt84 is offline   Reply With Quote
Old 07-12-2016, 06:13 PM   #2061
I have a few dollars burning a hole in my pocket just waiting for that new lightweight front spool.....
I'd love to have it before the 8/1 weight reduction for USGT takes effect!
RollingChicane2 is offline   Reply With Quote
Old 07-12-2016, 06:47 PM   #2062
It will be a big help in USVTA as well.
Old 07-13-2016, 11:54 AM   #2063
nubs's Avatar
Anyone know if these are the dampers that come with the evo 6?
http://www.stellamodels.com.hk/42287...cs-p-8891.html
Tamiya TRF419X | Tamiya TA07 Pro | Tamiya TB04 / Exo Six | AE B5 Converted to B5M
nubs is offline   Reply With Quote
Old 07-13-2016, 03:12 PM   #2064
B. Santos's Avatar
https://www.tamiyausa.com/items/radi...e-damper-42291
These are the ones that came with my Black Version kit
This kentech post implies that 42291 are 4mm shorter overall than the 42287, but otherwise the same.
Old 07-13-2016, 03:40 PM   #2065
nubs's Avatar
Oh that makes sense as the part for the piston is the M model.
Old 07-13-2016, 08:13 PM   #2066
nubs's Avatar
Default Too much?
Too much?
Old 07-15-2016, 02:11 PM   #2067
tandman's Avatar
Send a message via Yahoo to tandman
I'm currently running a 419x and really liking it a lot-I still have my bd7 2015 car but I am looking at running mod with the 419x and thinking about the exo6 for stock. Does this make sense or should I just get a second 419x???
Dwayne Flodell
Team Mad Scientist
-When you need mad rip.....call the Mad Scientist
Team Sweepracing-R1 Wurks
tandman is offline   Reply With Quote
Old 07-15-2016, 02:38 PM   #2068
aracefan's Avatar
Trader Rating: 38 (100%+)
Too much?
Yep, definitely too much. Box it up and send it to me!!
[PM me for address]
That's awesome. Love to see that, someone taking their hobby serious.
All give some, but some give all - thank you veterans for my freedom.
VBC is my new addiction - have Alex Pate at GripworksRC to thank for that!
aracefan is offline   Reply With Quote
Old 07-15-2016, 03:16 PM   #2069
nubs's Avatar
I was thinking of the exact same thing but in opposite order. I have a ExoSix that I run for stock and want to get a 419x for running mod.
Old 07-15-2016, 11:58 PM   #2070
Tom1977's Avatar
Same here. 419x for mod, 6MS for stock.
Tom1977 is offline   Reply With Quote
