Like Tree24Likes
Old 07-07-2016, 12:22 PM   #2026
Originally Posted by RedBullFiXX View Post
Faster you go, the harder you hit things, that's the main culprit in gear duration reduction with Tamiya shaft cars
Would not recommend more than 17.5, heard of some fast guys running 13.5, but that's the edge imo
Thanks RedBullFixx. When you say 13.5 are you suggesting brushed or brushless? I hope you meant brushless (lol) I ended up purchasing a Muchmore 13.5T. I've never done brushless before! Should it be fast?
jessele is offline   Reply With Quote
Old 07-07-2016, 12:48 PM   #2027
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Yes BL, 13.5 blinky is quick, unless you're running on a large nitro asphalt track
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 07-07-2016, 07:32 PM   #2028
nubs's Avatar
Default Droop
I'm having trouble with droop. I have my ride height at about 5mm in front and back but I have virtually no droop. The only way I can get since droop is to loosen up on the ride height to about 6 or 7mm and then I'll have about 2mm of droop. How do I get that 2mm droop with 5mm ride height? Do I have to use softer springs?
nubs is offline   Reply With Quote
Old 07-07-2016, 07:59 PM   #2029
theproffesor's Avatar
Trader Rating: 57 (100%+)
Unscrew the lower shock eyelets a couple turns. My shocks have about 2.5 threads of the shock shaft showing.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 07-07-2016, 08:41 PM   #2030
patorz31's Avatar
Wha are you using to set Ride height? The set screws in the arm are downstops (used to set droop). The shock collar set ride height.
Northern Alberta Scale Car Auto Racers Pres. and Promotions
SCHUMACHER RACING Canada,TEAM POWERS, Mon-Tech,Sanwa
patorz31 is offline   Reply With Quote
Old 07-07-2016, 09:02 PM   #2031
nubs's Avatar
So if I loosen up the shock collars completely, the closest I can get is 7mm ride height and 2mm droop. The shocks won't let me go lower than 7mm. Is this common?
Old 07-07-2016, 09:34 PM   #2032
nubs's Avatar
I'll try this.
Old 07-07-2016, 10:24 PM   #2033
MikeR's Avatar
Trader Rating: 15 (100%+)
Make sure you don't have spacers inside the shock bodies...
So if you move the collars all the way to the top of the shock body, the lowest ride height you can get is 7mm with all electronics on board?
If so, then wrong parts are on the car? As in wrong springs, towers, shocks or perches.
Post a pic- may be able to see something wrong.
4mm ride height with extra droop should be no problem at all.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 07-08-2016, 05:36 AM   #2034
nubs's Avatar
Ok I'll take a picture when I wake up more.
Old 07-08-2016, 07:48 AM   #2035
This is backwards ^^^^
Turning out shock collars will lower RH and add more droop, if droop screws are not moved
With droop screws out, so they don't touch the chassis, RH set at 5mm, you should have a massive amount of droop
Old 07-08-2016, 08:36 AM   #2036
nubs's Avatar
So I believe I know what the problem is/was. The symptom of the problem was that even with my shocks completely opened up (shock collars all the way to the top) my lowest ride height was 7mm. So I couldn't get to 5mm.
However, i think there were two things causing this.
1) My weight was too low
2) My weight was distributed incorrectly
Here are some pictures of my car right now with the new battery that is significantly heavier than my previous battery.
Tamiya TRF419X | Tamiya TA07 Pro | Tamiya TB04 / Exo Six | AE B5 Converted to B5M
Old 07-08-2016, 08:41 AM   #2037
I see you've converted your early TB04 Pro to the EXO6, which means you're using the 416 style arms. Maybe someone can chime in on whether the 418 style arms have a different lower mounting point for the shocks, which might be a reason for the ride height issues.
:: Tamiya TA05 MS :: Tamiya TB04 Pro II/Exotek EXO6 :: Tamiya M05V2 :: Losi XX :: Tamiya TB01 :: Tamiya XV-01 Rally ::
ErikO is offline   Reply With Quote
Old 07-08-2016, 08:49 AM   #2038
nubs's Avatar
Perhaps I need spacers under the suspension blocks?
Also, I didn't get a TB04 pro, I had the TB04 standard build. I purchased all the hop ups individually. Super expensive and was definitely the wrong way to go. But I live and learn I guess.
Old 07-08-2016, 08:57 AM   #2039
nubs's Avatar
The more I think about it the more I'm coming to the conclusion that the only thing I can do is either add more weight or change the springs for something softer.
Old 07-08-2016, 09:02 AM   #2040
Nothing too do with springs
It is clear from those pics that something with the dampers is preventing the susp arms from dropping fully
Arms with no load should angle down, not up as in your pics
