Like Tree11Likes
Old 06-21-2016, 08:56 PM   #1966
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
R1 wurks refunded my money. They said they don't make the 40mm fan and mount any more.
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 06-22-2016, 03:29 AM   #1967
Tom1977's Avatar
Default Setup question
I've a setup-question with my 6MS:
When the wheelbase on the chassis for example is shortened against the basic setup, do the dampers have to stay perpendicular to the arms? I mean perpendicular if you look sideways on the chassis.
I can use washers under the damperscrews but i don't know if it has generally any effect with light angeled or perpendicular mounted dampers.
Tom1977 is offline   Reply With Quote
Old 06-22-2016, 09:06 AM   #1968
MikeR's Avatar
Trader Rating: 15 (100%+)
Yes definitely add spacing as needed.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 06-22-2016, 09:08 AM   #1969
MikeR's Avatar
Originally Posted by nubs View Post
Related question, how do you get them to fit? My 66t spur rubs up against the top deck. ��
For 17.5 exo-six you would want about a 58t 48p spur.
Old 06-22-2016, 01:54 PM   #1970
Leester's Avatar
Trader Rating: 21 (96%+)
TQ Racing has a Robinson Racing 60T 48P spur gear that I use that fits nicely. PN# 1860. The 48P gears are much easier to set the mesh with as the spur and pinion aren't the easiest things to see from the rear of the car if your using the Exotek conversion chassis. I use 36 thru 40 pinions to pretty much cover the full range of gearing on a 17.5T motor. Adjust pinion choice for 21.5T accordingly.
Leester is offline   Reply With Quote
Old 06-22-2016, 04:46 PM   #1971
What's the lowest turn motors you can run without tearing through the gears?
jessele is offline   Reply With Quote
Old 06-22-2016, 07:11 PM   #1972
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Faster you go, the harder you hit things, that's the main culprit in gear duration reduction with Tamiya shaft cars
Would not recommend more than 17.5, heard of some fast guys running 13.5, but that's the edge imo
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 06-23-2016, 08:34 PM   #1973
nubs's Avatar
Are you guys using anything to protect the CF body from the suspension arm set screws?
nubs is offline   Reply With Quote
Old 06-24-2016, 05:33 AM   #1974
maxepower's Avatar
Talking set screws?
You can put a drop of CA glue, so it doesn't wear the carbon fiber as fast.
I was thinking McMaster Carr sells set screws with a Nylon tip, that would not dig into the lower deck. I checked on McMaster-Carr website and it's $10.46 for a set of 4 of the nylon tip steel 4mm set screws 10mm long, not counting shipping! That's a little pricey maybe you can find some cheaper somewhere else?
Just my 2$
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 06-24-2016, 11:58 AM   #1975
I have emailed them recently too about a few things and have not received any reply. I see a lot of their items "out of stock" on most online websites as well.
Are they still actively in business?
Awesomatix A800 x2, VBC D08 / D07, CRC WTF16 F1
National Points Member 201
RollingChicane2 is offline   Reply With Quote
Old 06-24-2016, 02:37 PM   #1976
Mcmastercarr sells full nylon 10-32 droop screws that can make your car two to three grams lighter... Just add a bit of ofna diff lock lube or sticky silicone so they can hold better...
Just my 2$
bertrandsv87 is offline   Reply With Quote
Old 06-27-2016, 09:46 AM   #1977
nubs's Avatar
Raced this weekend. It was my first actual race, and my second time on a track. Some of the locals are suggesting that I move from 17.5 to USGT (21.5). They think it will help to slow me down. I'm not so sure.
Personally I like the speed of 17.5
Anyway, most of the locals were somewhere in the range of about 15-16 seconds per a lap. By the end of the night I was around 18 seconds per a lap, I flipped my car 3 times in a 8 hour period, so I don't think I'm doing that bad. What do you guys think... should I stick with 17.5 like I want or go down to 21.5 like others are suggesting?
Tamiya TRF419X | Tamiya TA07 Pro | Tamiya TB04 / Exo Six | AE B5 Converted to B5M
Old 06-27-2016, 09:56 AM   #1978
I like to pick the class with the most entries, whichever that is, this way you should have more racers close to your pace
2 - 3 secs a lap off pace is quite significant
Can the locals help you tune that car, or check it over ?
Crashing and such is what practice days are for, nothing to be concerned with, also a good way to find the limits of your settings under race pace
Never practice at 90%
Old 06-27-2016, 10:07 AM   #1979
Tom1977's Avatar
I'm using SpecR Chassis Down Stop Protection Spacer (4pc) - #SPR035-DSP for both, aluminium and cf.
TQrcracing has them in stock.
Old 06-27-2016, 11:44 AM   #1980
OSherman's Avatar
same here.. lightweight and easy to install, just stick them on.
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
