Like Tree11Likes
Old 06-20-2016, 09:15 AM   #1951
This might be an ignorant question but I want to send it out there for advice:
Is everyone running the steel DCJ's or are there lightweight options for the DCJ's? Is it as simple as running lightweight swing shafts and Exotek axles and combine them with the DCJ parts?
I'm able to find what I need for the rear axles but unclear for the front (and I do not want to go back to single joints in the front)
Just needing a sanity check and advice....
Awesomatix A800 x2, VBC D08 / D07, CRC WTF16 F1
National Points Member 201
RollingChicane2 is offline   Reply With Quote
Old 06-20-2016, 09:26 AM   #1952
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
With front DCJ's you always want to use Steel for durability, not even sure if there are any other options
Aluminum dog bones are good for rear axles
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 06-20-2016, 09:57 AM   #1953
Thanks for the quick reply RedBull. I'm pretty much ready to wrap up all my light-weight transformation (until that new light weight spool comes out in another few weeks!)
Old 06-20-2016, 12:55 PM   #1954
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
Which fan mounts fit the exo6 to where he fan is on top of motor?
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 06-20-2016, 01:09 PM   #1955
Originally Posted by Tom1977 View Post
I would recommend the EVO6 MS. It has the better center bulkhead for better center gear alignment and if you want to change from aluminium to cf, the lower deck from the old EVO6 is an option part.
I drive mine with aluminum on asphalt. Weight is about 1378g with electronics.
Thanks for the recommendation. Ordered the MS and lower aluminum bulkheads. Can't wait to get it.
jessele is offline   Reply With Quote
Old 06-20-2016, 02:04 PM   #1956
Josh-n-ya's Avatar
Trader Rating: 73 (100%+)
R1 fan mount. TQ has them in stock at the moment.
Josh-n-ya is offline   Reply With Quote
Old 06-20-2016, 02:31 PM   #1957
teeforb's Avatar
I just checked. Says out of stock
Old 06-20-2016, 03:55 PM   #1958
R1wurks.com has them in stock....
flybyublue is offline   Reply With Quote
Old 06-20-2016, 05:22 PM   #1959
teeforb's Avatar
I ordered from there. Thx
Old 06-21-2016, 08:50 AM   #1960
teeforb's Avatar
Looking at the exo6 setup sheet on exotek site. The sheet calls for 3000 # diff oil. Is this cst or wt?
Old 06-21-2016, 10:25 AM   #1961
nubs's Avatar
cst.
nubs is offline   Reply With Quote
Old 06-21-2016, 11:17 AM   #1962
teeforb's Avatar
Originally Posted by nubs View Post
cst.
thanks bud!
Old 06-21-2016, 04:49 PM   #1963
MikeR's Avatar
Trader Rating: 15 (100%+)
Quick question for the EXO-SIX owners- what size 48p spur are you using for 21.5 USGT?
TIA
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 06-21-2016, 05:32 PM   #1964
nubs's Avatar
TIA
Related question, how do you get them to fit? My 66t spur rubs up against the top deck. 😞
Old 06-21-2016, 05:58 PM   #1965
65t 48p is probably the max size
That's approx 35.5mm dia
Close to the 88t 64p I use
