Like Tree11Likes
Old 06-06-2016, 11:13 AM   #1891
CL
CL's Avatar
Trader Rating: 32 (100%+)
Originally Posted by vivo quevas View Post
Need part# for a ball diff for evo 6
Thanks.
http://www.tqrcracing.com/shop/produ....asp?p_id=6983
More racing and less typing!
CL is offline   Reply With Quote
Old 06-06-2016, 12:28 PM   #1892
Hey everyone, I just ordered the EXO6 and the TB04 conversion for my TB04 Pro II. Does anyone have a good USGT medium-high grip carpet baseline setup? If not, I might start with RedbullFXXs' Reedy setup and go from there unless that's a bad idea.
Thanks!
:: Tamiya TA05 MS :: Tamiya TB04 Pro II/Exotek EXO6 :: Tamiya M05V2 :: Losi XX :: Tamiya TB01 :: Tamiya XV-01 Rally ::
ErikO is offline   Reply With Quote
Old 06-06-2016, 12:56 PM   #1893
theproffesor's Avatar
Trader Rating: 56 (100%+)
I have a really good USGT set up on mine right now for medium traction carpet. I will upload it later tonight. But it has parts not in the kit on it.
Off the top of my head it's blue yokomo springs all the way around. Front diff with 2.5mil, both front hinge pin carriers are C block, and I think I have 6mm hexes all the way around.
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 06-06-2016, 01:17 PM   #1894
Thanks.
I'm running 500k in the front diff currently, and using Tamiya springs. Hopefully I can make it work!
Old 06-06-2016, 01:42 PM   #1895
Well was able to get it earlier than expected. I had to add 55g of weight to get to 1450g. And I have all steel screws a heavy front diff, amd a 6500mah batt. Getting down to 1380 for the new USGT rules or TC will be no problem.
The car is a beast for me. Very controlable. As traction changes though out the day I really only mess with camber, shock angle, and maybe small droop or RC changes (+/- .5mm)
Old 06-06-2016, 10:20 PM   #1896
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Cool
Originally Posted by RollingChicane2 View Post
RedBull - I have never had luck with ball diff's but I ordered on to try out in the rear of the USGT car for weight savings related to the rotating mass (as well as the ARC outdrives, lightweight swing shafts, etc.)
Would you mind sharing build tips as well as diff setting techniques that you use for the rear diff?
Use high quality diff grease, good 3/32 steel or ceramic diff balls
Initial setting on diff should be a little loose, it will break in, and tighten up after a few runs
Race setting: For carpet, or higher grip
Hold both wheels, spur gear will just slip with your thumb pressing on it
Race setting for asphalt, or lower grip, should slip a bit on acceleration from dead stop
My setup is close to Rtype setup, you may want to run that, or the Proffesors', my setup is such that the car never slows down in corners, more of a pan car style of driving is required to tame that setup
No need for modified ARC pieces on this car
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 06-06-2016, 11:12 PM   #1897
nubs's Avatar
Default Exo 6
Well guys I was hoping to be one of the few who actually has an exo 6. Unfortunately, the two kits I bought for the conversion both had problems. The tb04 parts kit had problems with the steering cranks not being machined to the size of the bearings. The main conversion kit was missing 5 screws and two bearings. I sent them an email, let's see how good their support is.
nubs is offline   Reply With Quote
Old 06-07-2016, 05:47 AM   #1898
Thanks for the setup tips, guys!
Old 06-07-2016, 08:31 AM   #1899
Thanks for the tips. I'll get the diff built and test it out this weekend. I didn't realize that Tamiya had lightweight outdrives or I would have ordered them. Looks like I'll be placing another order with TQ in the near future.
Awesomatix A800 x2, VBC D08 / D07, CRC WTF16 F1
National Points Member 201
RollingChicane2 is offline   Reply With Quote
Old 06-07-2016, 10:26 AM   #1900
nubs's Avatar
Mike just replied to me,wow that was fast! I went from being upset to being happy and excited again. Awesome!
Old 06-07-2016, 11:14 AM   #1901
Thumbs up
In my experience, he stands behind his products 100%
speed_dmon is offline   Reply With Quote
Old 06-07-2016, 12:23 PM   #1902
Always
Old 06-07-2016, 12:23 PM   #1903
RAL
RAL's Avatar
Trader Rating: 59 (100%+)
Yes sirrrr
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 06-07-2016, 01:28 PM   #1904
robk's Avatar
Trader Rating: 22 (100%+)
Anytime I have ever had a problem, Mike is super on customer service.
Old 06-10-2016, 07:16 AM   #1905
Hi all, I've made an editable excel based setup sheet for the EX06 for those who have a laptop with them at the track. Feel free to download it at the link below. If the link doesn't work, please let me know!
https://www.dropbox.com/s/c0yx9knl7u...R%5D.xlsx?dl=0
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
