Like Tree23Likes
Old 05-31-2016, 01:15 PM   #1876
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
Looking at getting one for club racing around my area. Any issues with them out the box? Think I read that the TRF419 has issues with leaking diffs, is there any issues with the diffs in this kit?
Drift_Buggy is offline   Reply With Quote
Old 05-31-2016, 01:50 PM   #1877
theproffesor's Avatar
Trader Rating: 57 (100%+)
I would recommend replacing the Cubs with the ones from the TA05. The factory ones are very brittle. The diffs have been pretty good for me. I use the plastic gears to save weight since I'm running 25.5 and 21.5 motors. If you sand the back if the bevels, sand be careful not to remove much material. I did on one if mine and it finally stripped out the internals. But totally user error. Rebuilt it track side with spare parts and have had zero issues since.
After a few runs, I don't see any leakage. What is there is just the residual fluid from the build.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 05-31-2016, 02:23 PM   #1878
Awesome info, thanks for sharing.
RollingChicane2 is offline   Reply With Quote
Old 05-31-2016, 08:50 PM   #1879
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by RedBullFiXX View Post
Setup sheet from my evil-six entry
Car was money in the Mains
Starting from Q9 grid position to 5th OA
Had to earn those spots
Well done Dave! Some epic racing in the A-mains at Reedy.
In the end, half of the top 6 cars in the Amain were shaft drive Exotek packaged cars!
Thanks to everyone with their cheers and support! We had a good group of privateers, putting in a top effort and so- I plan to keep on developing more speed secrets for the Evo6 in order to maximize it potential
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 05-31-2016, 09:02 PM   #1880
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Cool
Thanks Mike
Running a shafty at the RROC brought back some good memories
Privateers for sure, only free thing we had was advice, should have listened to Max sooner on that front
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 06-02-2016, 03:11 PM   #1881
nubs's Avatar
Good eye Professor
TB04 aluminum pilot shaft, use the long shaft in the set, but it needs to be cut down to length of Evo 6 front shaft
https://www.tqrcracing.com/shop/prod....asp?p_id=7961
This and other weight shaving without compromising durability, put my car at 1380g with 15g of weights added to meet minimum at Reedy tech
Do you use a front direct coupling or a front one way? I am considering using a gear diff with 1M cst, that way I can use these:
http://www.tqrcracing.com/shop/produ....asp?p_id=7270
Why do you think this is not as popular?
nubs is offline   Reply With Quote
Old 06-02-2016, 03:30 PM   #1882
A spool, One-Ways are not legal for the REEDY Race
Tried a diff with 2.5m cst
Spool front Ball-Diff rear was the best setup for my driving
Old 06-02-2016, 03:36 PM   #1883
MikeR's Avatar
Thanks Mike
Oh yes, the venerable 'Cuda, and back when we were teammates for Alex Racing. Car was ahead of its time!
Old 06-02-2016, 03:47 PM   #1884
These are the types of upgrades that manufacturers will never do that can turn your tb-EVO 6 into a real contender in all classes... Bravo, and I hope you keep finding more of these heavy parts and chop them down accordingly....
You can call your car the EVO 6.2(like my tc4.2) after that....lol....
Good eye Professor
bertrandsv87 is offline   Reply With Quote
Old 06-02-2016, 06:47 PM   #1885
So when can we expect bulkhead/gear cases designed like this for the EXO6? I'm sure you can come up with something better than just the outrageously priced Tamiya lower gearboxes.
Old 06-03-2016, 05:02 PM   #1886
maxepower's Avatar
Talking
Thanks Mike
Don't know why tires work best 2nd to 3rd run, new tires even after taking the seam off didn't make it any easier. I really liked the gear diff in front 2.5 million car went 3 tents faster. Ran 13.3's each round. Hard not to go back after that result. The EXO aluminum lower deck was part of the reason why I'm sure!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 06-03-2016, 05:04 PM   #1887
Everyone drives with a different style for sure
Old 06-06-2016, 10:02 AM   #1888
RedBull - I have never had luck with ball diff's but I ordered on to try out in the rear of the USGT car for weight savings related to the rotating mass (as well as the ARC outdrives, lightweight swing shafts, etc.)
Would you mind sharing build tips as well as diff setting techniques that you use for the rear diff?
Awesomatix A800 x2, VBC D08 / D07, CRC WTF16 F1
National Points Member 201
Old 06-06-2016, 10:56 AM   #1889
vivo quevas's Avatar
Trader Rating: 18 (100%+)
Need part# for a ball diff for evo 6
Thanks.
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 06-06-2016, 11:12 AM   #1890
ARC outdrives? The tamiya ones are aluminum and pretty light.
