Like Tree23Likes
Old 05-27-2016, 05:56 PM   #1861
JS
JS's Avatar
Trader Rating: 70 (100%+)
Are the short big bore dampers from the Evo.6 MS the same as the older Evo6?
I checked the shock shaft part numbers from both manuals and they are the same. Not sure about the shock body. Thanks
ActivRC.com
JS is offline   Reply With Quote
Old 05-28-2016, 11:51 AM   #1862
MikeR's Avatar
Trader Rating: 15 (100%+)
2nd round TQ 17.5 class at Reedy! Max Valles driving Exo6. He's all smiles right now 😃
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 05-28-2016, 02:12 PM   #1863
JD Skyline's Avatar
Congrats!!! Well done!!!
JD Skyline is offline   Reply With Quote
Old 05-28-2016, 09:38 PM   #1864
MikeR's Avatar
Default Making shaft drive great again
Qualifiers are wrapped up and we head to mains tomorrow.
Final tally: Out of over 70 stock racers, there were only 5 exoteks but 3 of them made the A main!
3rd ExoPro4
4th Exo6- also set single fastest lap
9th Exo6
Excited for the mains
Old 05-28-2016, 09:40 PM   #1865
MikeR's Avatar
Redbulfixx's a-main ride
Old 05-28-2016, 10:11 PM   #1866
Wow..... I hate to say it again, but I told you so ! Yeah I only run tc4's and Awesomatix A700ex, but they are all the same basic drivetrain design.... How many other shaftdrive (Awesomatix or other brands) cars made the top 20 ??? No tc4's ???...lol....
You can still get more speed out of your car if you use a ewhippler carbon driveshaft, aluminum screws/ turnbuckles/diff outdrives, blitz 0.5mm bodies, and remove all your bearing seals+ gear two teeth higher......Good luck....
3rd ExoPro4
9th Exo6
bertrandsv87 is offline   Reply With Quote
Old 05-29-2016, 01:07 AM   #1867
JD Skyline's Avatar
3rd ExoPro4
9th Exo6
Please let us know if the exo-cars kicked some... during the mains...haha
Old 05-30-2016, 02:20 PM   #1868
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Thumbs up
Setup sheet from my evil-six entry
Car was money in the Mains
Starting from Q9 grid position to 5th OA
Had to earn those spots
Tamiya TB Evo 6-rroc16-17.5.jpg   Tamiya TB Evo 6-evil-six-rroc16.jpg   Tamiya TB Evo 6-dsc00224s.jpg   Tamiya TB Evo 6-rroc16-17.5-results.jpg
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 05-30-2016, 05:16 PM   #1869
theproffesor's Avatar
Trader Rating: 57 (100%+)
Congratulations on the the finishing positions guys!
Redbull, what front cupling are you using for the main drive shaft to the front gearbox?
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 05-30-2016, 05:20 PM   #1870
racer x 1's Avatar
Trader Rating: 27 (100%+)
Way to go Berger!!
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 05-30-2016, 08:10 PM   #1871
JD Skyline's Avatar
Right oncongrats with the results...well done...
Old 05-30-2016, 08:38 PM   #1872
Johnn27's Avatar
Trader Rating: 71 (100%+)
Questions?? Exotic Roller
Anyone want to sell a Race ready Exotek roller????
Johnn27 is offline   Reply With Quote
Old 05-30-2016, 09:23 PM   #1873
Good eye Professor
TB04 aluminum pilot shaft, use the long shaft in the set, but it needs to be cut down to length of Evo 6 front shaft
https://www.tqrcracing.com/shop/prod....asp?p_id=7961
This and other weight shaving without compromising durability, put my car at 1380g with 15g of weights added to meet minimum at Reedy tech
Old 05-31-2016, 09:17 AM   #1874
Thanks for the info. Saving weight is good, but not at the expense of durabilty. Do you run any alumnum or ti screws? I also see you don't run the bearings on the battery tabs. Curious as to why? Also what Mah battery are you running?
Just trying to get all the puzzle pieces together to duplicate weight savings.
Old 05-31-2016, 09:45 AM   #1875
Steel screws on the bottom of the chassis, combination of aluminum and ti on top
Don't see the need for added bearings and screws on the battery holders
Have Yokomo rubber pad underneath so the lipo doesn't slip, and double layered tape for added insurance
298g
