Like Tree11Likes
Old 05-15-2014, 12:48 PM   #166
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
The good thing with the servo mount on the Evo 6 is it looks like the main mounting points are exactly centered under the shaft, so flex characteristics will not be compromised.
The servo is moved out farther a little but servos are not too heavy. Plus when balancing out my TC cars, the front left (servo area) needs weight added to balance out the battery side.
Also have a Pro4, wasn't a huge fan of shaving a part of the ear to clear the shaft. (BTW, has anyone seen the new Awesomatix servo with built in mount?)
I still don't like how the motor is far out as it is. On my Xray T4 where the motor is closer to the center, I still had to add weight on the right rear battery side to balance out the motor side. This was with a battery that weighed 330 grams, so it was a bit on the porky side. The Evo 6 will require even more weight to balance out.
Dan is offline   Reply With Quote
Old 05-15-2014, 04:28 PM   #167
You could run a shorter motor, someone makes one (trinity I think).
Personally it looks like the same layout as the tb04 http://www.thercracer.com/2013/11/ta...nd-review.html
Other than the motor mount the layout and shafts are the same. The TB04 is very good and the more high end elements featured on this, along with lighter chassis will really help it be potentially the new darling of stock classes.
As to gearing, I was able to get a low FDR with the tb04 (3.7) this noes mount will let you go lower.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 05-15-2014, 05:18 PM   #168
2-Bad's Avatar
Trader Rating: 24 (100%+)
Yeah but to cover yourself for all spec classes and all tracks lengths fdr needs to reach 3.0 to be safe, yes? Assuming you can fit the largest pinion (40t/48p) and the smallest spur (65t/48p) with the gearbox ratio of 2.5:1 the maximum fdr is 4.06, is that correct???
Are the facts right that it only has a 2.5 internal ratio? That sound awfully high!!!
No front swing shaft protectors for the front outdrives either... Probably a good thing as on the 418 many people found they wear badly.
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 05-15-2014, 05:58 PM   #169
So interestingly it comes with 1 piece front and rear suspension blocks at both ends. Mounting holes are there for 2 piece though.
I wonder what drove that decision?
Originally Posted by Chaz955i View Post
Must have!!
Anyone know if this will share suspension plastics with the TB04 that is coming out? This car sounds like it is using 418 parts but I couldn't find anything saying what the new TB04 is using.
The TB04 pro II is using 418 style arms and uprights etc. but will have 6deg hub carriers. Highly likely they will be standard plastics as opposed to the CF reinforced ones on the 418 and as the EVO6 would appear to have.
cplus is offline   Reply With Quote
Old 05-15-2014, 06:25 PM   #170
I'm pretty sure you are way off on this size pinion that would fit with a spur that size.
Juan Aveytia is offline   Reply With Quote
Old 05-15-2014, 08:50 PM   #171
2-Bad's Avatar
That's not my point ! Whether or not I have a accurate pinion or spur that will fit is irrelevant, it's the fdr that matters and the internal ratio of 2.5 is high when trying to achieve a desired fdr of 3.0 to 4.0 for some spec racing on medium to large tracks!
Old 05-15-2014, 08:57 PM   #172
JimmyMac's Avatar
I don't see it as a problem with this layout. The topdeck is not in the way of a large pinion like it would be on an Evo 5.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 05-15-2014, 10:05 PM   #173
Dyingslow's Avatar
With the Exotec motor spacer I have been running an fdr of 3.5 on my tb04. Considering then Evo6 new motor mount it will be very easy to get a lower fdr.
Dyingslow is offline   Reply With Quote
Old 05-15-2014, 10:36 PM   #174
2-Bad's Avatar
Okay let me try and explain this another way...
To get low fdr (final drive ratio's) you have to put on a small spur and a large pinion, yes?
What is the smallest spur on the market at the moment that is readily available? Lets say it's 65 tooth.
What is the largest pinion on the market at the moment that is readily available? Lets say it's 40 tooth.
With an internal gearbox ratio of 2.5:1 (info from Qatmix, thank-you), that means you'll only ever get down to 4.06 fdr (assuming there is room to fit both in the motor slide adjustment)!
final drive ratio = (Spur / pinion) x internal gearbox ratio
4.06 = (65 / 40) x 2.5
The TB 04 has an internal ratio of 2.294, yes? Using the same spur and pinion as above that means you're only getting 3.73 fdr.
The only way to get lower fdr is to get either smaller spur or larger pinion (or both), which can be difficult...
This is my point! If the TB Evo 6 is actually 2.5:1 that makes it hard (not impossible) to get proper fdr for all tracks/spec classes... geezz!!! lol
Old 05-15-2014, 11:17 PM   #175
JimmyMac's Avatar
Then how do the TC3 and TC4 guys do it with a 2.5 internal ratio? If you had a 65 spur, then you need a 54 pinion to get 3.0 final drive. Not sure what you run over there but I use a 54 pinion often with my BD7. It's not a problem using a pinion that size or bigger.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 05-15-2014, 11:26 PM   #176
2-bad is using 48p gears for his example and I don't think I have seen anything larger than a 45t pinion in 48p - 54t would be massive. I have however run a 55t 48p spur (on an awesomatix) so allowing for a 45t pinion and a 55t spur you could get to a fdr of 3.05. This is pretty much bang on for the 21.5s we run at our medium sized outdoor track.
Please note that I am not actually claiming you could get this gearing to actually mesh on the new car - just that the maths says it's possible.
Simon
Team_Krusty is offline   Reply With Quote
Old 05-16-2014, 12:28 AM   #177
CL
CL's Avatar
Trader Rating: 32 (100%+)
FYI: If you guys use 64p gears, you can get a spur gear small as a 72T & a pinion big as a 55T which will give a FDR of 3.27.
I have fitted a 72T 64p spur and a 53T pinion on my TC3 a few years ago which gives a FDR of 3.4.
Believe in yourself!
CL is offline   Reply With Quote
Old 05-16-2014, 03:02 AM   #178
2-Bad's Avatar
And they are readily available everywhere eh?
All I was trying to point out is that with this gearbox, one would also have to consider ensuring they could secure these special spurs/pinions as those sizes are outside the normal sizes from most supplies.
I give up....haha
Old 05-16-2014, 03:11 AM   #179
All I was trying to point out is that with this gearbox, one would also have to consider ensuring they could secure these special spurs/pinions as those sizes are outside the normal for most supplies.
I give up....haha
I have a 70t spur and a 55t pinion. With the I.R of 2.5 (the same as the TB04) I will get a FDR of 3.1 the biggest pinion I have seen is 58t (64dp)
Old 05-16-2014, 06:24 AM   #180
TB03Racer09's Avatar
I give up....haha
I know what your trying to say, however at least in Australia, getting pinions up to 70t isn't too hard.
I believe the reason for such a high internal drive ratio is due to ring/pinion gears only being durable in certain pitches/tooth counts but maybe someone well versed on this topic can step in...
TB03Racer09 is offline   Reply With Quote
