Like Tree11Likes
Old 02-20-2016, 09:52 AM   #1696
Josh-n-ya's Avatar
Trader Rating: 73 (100%+)
Originally Posted by Kakaru View Post
Hi Guys
Based on your experience with Evo 6 (with internal gear ratio of 2.5), what is your recommendation of the Final Gear Ratio ("FRD") or rather the pinion gear's teeth number of Evo 6, given a spur gear size 68T and a non-turbo stock motor of 17.5T. The car will run usually on a medium size track with about 40 x 30 meters area.
Thank you.
All depends on what motor you run and that motors recommendations. In 17.5 I use a 78t 64pitch spur. 3.6 to 3.8 fdr!
Josh-n-ya is offline   Reply With Quote
Old 02-20-2016, 06:51 PM   #1697
I see... Thank you.
Kakaru is offline   Reply With Quote
Old 02-21-2016, 05:12 PM   #1698
theproffesor's Avatar
Trader Rating: 56 (100%+)
My day in USGT ended before it even started. Got nailed a it the right rear tire by amother car at the end of the straight. Bulkhead was the only broken part. Not too upset, I have spares... but they were all at home... oh well. Still had the USVTA car that with the new Yoke springs is dailed in.
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 02-23-2016, 11:46 AM   #1699
Does anyone know where I can find replacement aluminum parts for the Evo6 Black edition, specifically the 1XB suspension mount?
B44.3|T5M|Rev8
bcooper is offline   Reply With Quote
Old 02-23-2016, 11:57 AM   #1700
OSherman's Avatar
i believe the BLACK is a Limited Edition kit... cannot get black bits separately.
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 02-23-2016, 01:00 PM   #1701
They are split type but are black.
http://www.exotekracing.com/hinge-bl...-for-trf-xb-b/
It will allow the chassis to flex just a bit more. But they will work.
Old 02-23-2016, 07:19 PM   #1702
Thanks, that will work as I'm going to try the aluminum chassis as well.
B44.3|T5M|Rev8
Old 02-23-2016, 07:55 PM   #1703
Josh-n-ya's Avatar
I got two carbon fiber drive shafts coming! Also got some aluminum outdrives I'm going to use from ARC to try. Making the drive train light as possible for spec racing hopefully will give me an edge.
Old 02-23-2016, 07:56 PM   #1704
Josh-n-ya's Avatar
Oh no! Better get Maaco! Lol
Old 02-24-2016, 07:59 AM   #1705
Aluminum out drives for the spool?
Old 02-24-2016, 09:42 AM   #1706
vivo quevas's Avatar
Trader Rating: 18 (100%+)
Exotek makes all the suspension block for an Exo 6
http://www.exotekracing.com/hinge-blocks-for-trf-c/
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 02-24-2016, 10:12 AM   #1707
OSherman's Avatar
The EXOTEK parts are very nice. I run them on my non-TCS cars.. Very nice alternative. They are quite stronger and less prone to bend in a hard crash.
•KO Propo America
•EXOTEK
Old 02-24-2016, 10:31 AM   #1708
Josh-n-ya's Avatar
Yes! ARC aluminum is quite strong. It will take a slight modification of cutting off like 1/16 off the backside of the outdrive to allow the pin to slide through to hold it on the spool. They are sold out pretty much everywhere in the states which lets me know people are using them. I had to buy from HK. I will let you know how it works. I wish I could post picks. I used too a long time ago. Now I have issues once they changed this site around.
Old 02-24-2016, 11:14 AM   #1709
Upload photos to photobucket, then post the link. That's what I do
Old 02-24-2016, 06:45 PM   #1710
clint's Avatar
Trader Rating: 24 (100%+)
Send a message via MSN to clint
I know its a long shot but does anyone have a spare set of the Blue BB EVO6 dampers they would sell??
www.rcottawa.com TRF EVO 5.5 Exotek V2, TRF 419X, RSD RR12 V2
PR/HP PRS1 V1,V2,V3 FM, PR/HP PRSB401
http://hobbyauthority-dist.com
http://www.maclan-racing.com
http://www.pr-rc.com/
clint is offline   Reply With Quote
