Like Tree11Likes
Old 02-06-2016, 10:21 AM   #1666
Ivan Dickson's Avatar
Trader Rating: 11 (92%+)
Post EVO 6 for sale black version (EXO conversion)
Just listed my Black version EVO 6 EXO conversion, click here to see.
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is online now   Reply With Quote
Old 02-06-2016, 08:58 PM   #1667
Josh-n-ya's Avatar
Trader Rating: 73 (100%+)
Tried the ball tb04 ball diff today. Was super easy to tune once diff was broke in. Had TQ but lost it. Qualified third but managed to pull off a win in the main. In usgt I also qualified 3rd but broke a pin or something in the dog bone and DNF. I used 7mm wheel hexes and stock hard springs that came with black kit. My usgt was hooked up. Got to wait a couple more weeks for next run.
Josh-n-ya is offline   Reply With Quote
Old 02-06-2016, 08:59 PM   #1668
Josh-n-ya's Avatar
Day late and dollar short!
Old 02-08-2016, 09:31 AM   #1669
Josh-n-ya's Avatar
Originally Posted by N15M0 View Post
Anyone tried running their Evo 6 on the trf419 dampers? Are they the same? Thanks..
I tried using the Trf dampers this weekend and it wouldn't work with the stiff springs I wanted to use. Lowest ride height I could get was like 6mm. Something to do with the shock caps being longer pushing the spring down just a bit more than stock evo shocks. Maybe with soft springs it could work.
Old 02-08-2016, 09:39 AM   #1670
I tried a slightly different set up this past weekend with very good results. I wanted to try the suspension shims so I added 0.5mm under each suspension mount (on the chassis) and reset my droop. I normally run a typical spring package with the rear springs being one step softer than the front springs.
In this configuration, the car was fairly good. I then went one additional step softer and the rear of the car was terrible. I had anticipated the softer springs would stick the rear end just a touch more but it did the opposite.
If softer made it worse, I though might as well try one step harder than normal (which was the same spring as the front). The rear was indeed stuck better and I wasn't lacking for rear traction anywhere.
I wanted to keep the testing going so I went one step harder (now the rear is actually one step harder than the front spring). The rear was stuck in all aspects and now the car had more initial turn in as well as mid-exit steering.
This was in USGT and after the first heat I nabbed TQ only to give it up the in the second heat and finish second in the Amain, 3 seconds behind the leader who is the current USGT points leader. At the end of the day, the car was the best it has ever been using a set up that I have never used (regarding springs) for any TC with 0.1 variation from my fast 5 lap to my top 20 lap avg.
The Exo 6 is by far the best car I have ever owned.
Awesomatix A800 x2, VBC D08 / D07, CRC WTF16 F1
National Points Member 201
RollingChicane2 is offline   Reply With Quote
Old 02-08-2016, 10:45 AM   #1671
Too bad Awesome car!
Old 02-08-2016, 11:18 AM   #1672
Josh-n-ya's Avatar
For sure! I have three now!😬
Old 02-08-2016, 11:24 AM   #1673
Josh-n-ya's Avatar
I went to the hardest springs I could find in my spring box which was the stock springs that came with the black evo Kit. I don't have a clue on how those are rated! I went from 37.5 shock oil to 40wt and my car was planted. My droop is 5 front and 4 rear. Going to try 6 in front and 5 rear next time for fun. This car really responds to changes well. Both usgt and 17.5 car have same setup on them. Couldn't do that with other cars I've ran.
Old 02-09-2016, 05:48 AM   #1674
I have always run ~30-35WT oil but I keep increasing the WT and it keeps getting better. I am now running 50WT all the way around.
Car just keeps getting better and responds to changes really well.
Old 02-11-2016, 10:53 AM   #1675
theproffesor's Avatar
Trader Rating: 56 (100%+)
So I did something today I never could have thought would happen. I cracked a diff case. And by diff case I mean the actual diff.
I want to try a front diff with 1m fluid. I've run them before in other cars and liked them. Filled it as normally as I could with the clear snot, let it sit for several hours to get the bubbles out and slowly tighten the screws on the cap in a cross pattern.
Before any of the screws were tight, I heard a pop, and saw fluid oozing put of a crack that ran the length of the screw hole. Damnit man.
I know that it wasn't over filled, I think it was actually slightly under filled. I think that some fluid made its way into the screw holes as I was filling the diff. As I tighten the screws, the 1m fluid being so thick, built hydraulic pressure that could not escape past the screw threads, so it found the weakest point as thw cased popped like a piņata.
I have a couple of new diff cases on order, just be careful if you want to try heavyweight front diffs and not get fluid in the screw holes.
I am also going to try the TB03 rear tower. It looks to have the same overall geometry, but fewer holes that the EVO 6 tower. I like want to try it because the body mounts are so much lower than stock. I'm wanting the run the Mazda Furia body and the rear is super low.
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 02-11-2016, 12:41 PM   #1676
Josh-n-ya's Avatar
Just to add to this I ordered a set of spring retainers that are supposed to be 1mm longer from TQ! Hopefully it will allow me to use the springs I want to use with the taller shocks. Will let you know if it works.
Old 02-11-2016, 12:42 PM   #1677
Josh-n-ya's Avatar
You don't like the spool?
Old 02-11-2016, 01:34 PM   #1678
I do. I just want to try something different. I am looking for a more controllable corner entry with more mid to exit corner speed and I think having a diff with 1m fluild would help with that.
Some of the changed I made last time out greatly reduced my corner entry speed. I was trying to accplish that as I felt the car was too twitchy. Now trying g to gain some back, but keep it smooth.
Old 02-11-2016, 03:00 PM   #1679
Josh-n-ya's Avatar
Have you tried the tb04 ball diff yet? Is this your usgt your talking about? I will pm you a my setup tonight so you can compare. My cars are dialed.
Old 02-11-2016, 04:58 PM   #1680
I'm not a big fan of ball diffs. I have run them for years. I can build one to be ad smooth as silk and last a good while. I am just a while lot happier with gear diffs. It makes consistent set up easier and gear diff are less likely to fail at the wrong moment.
Post up that set up. I'd like to see it. I'll post up some of mine as well in the next couple days. I have one that is pretty dialed, and a couple that good starting set-ups but need fine tuning.
