Like Tree23Likes
Old 01-27-2016, 11:00 AM   #1636
Location: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
Trader Rating: 30 (100%+)
Why would Tamiya decide to continue using a transverse motor mount when these inline ones like the Exotek are so much better?
lagcisco is offline   Reply With Quote
Old 01-27-2016, 11:01 AM   #1637
Josh-n-ya's Avatar
Trader Rating: 75 (100%+)
I had high hopes for an exo inline motor chassis! Not fond of all the gears involved in the evo chassis.
Josh-n-ya is offline   Reply With Quote
Old 01-27-2016, 11:02 AM   #1638
Makes no sense. I would have purchased it had it been an inline motor.
Old 01-27-2016, 11:05 AM   #1639
theproffesor's Avatar
Trader Rating: 57 (100%+)
It would be nice if they include the aluminum lower gearbox in the 6ms kit. It will be interesting to see how they look and how much they weigh compared to stock. I like at least having an aluminum lower gearbox to not worry about stripping the gear box during maintenance. Yes an aluminum upper would be nice, but only if it incorporated the shock tower mounts as well.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 01-27-2016, 11:15 AM   #1640
Josh-n-ya's Avatar
Lol! Have to buy two kits. The evo6 and exo6! Good luck trying to order both at the same time. One kit is usually out when you want to buy. Almost cheaper to piece out a complete car vs. buying the two kits. I will be using my exo for now!
Old 01-28-2016, 07:06 PM   #1641
vlad_sa's Avatar
Meh, not interested in EVO 6 MS.
Why is everyone so disappointed? EXO 6 took all the problem away from the EVO 6.
Btw, has anyone driven the EXO 6 Aluminium chassis? Any reports?
I'm thinking to snap one only because they're cheap!
Tamiya TRF 419X / Tamiya TB EVO 5 Exotek v1 / Tamiya TB EVO 5 Raceberry Edition / Tamiya TB EXO 6 / Tamiya TB EXO 5 Raceberry Edition / Tamiya TA05 v2 Exotek / Tamiya FF04 EVO / Tamiya FF04 EVO Black Edition / Tamiya FF03 EVO / Spice Yokomo BD7 FF / VBC FF17 / Sabre FD Mini
vlad_sa is offline   Reply With Quote
Old 01-29-2016, 04:04 AM   #1642
Anyone tried running front gear diff?
N15M0 is offline   Reply With Quote
Old 01-29-2016, 07:34 AM   #1643
What is the part number for the spec r gear diff? Or does Tamiya sell a gear diff kit vs buying all the parts separate?
Alright found the spec r diff for the TB03. For those guys running it, are you running the stock pinion gear in the gear box? Or a different one. Is anyone running a spec r front diff and a stock rear diff.
Running the 39 tooth Spec r diff in front with a 40t stock rear diff would give the car front over drive. I remember this as a tuning option on the old Losi JRXS. Can't remember what it was supposed to do though? Thoughts?
Old 01-29-2016, 09:20 AM   #1644
OSherman's Avatar
https://www.youtube.com/watch?v=CAUCdasUZmU
Show-n-tell
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 01-29-2016, 09:58 AM   #1645
maxepower's Avatar
Exclamation Toy Fair in Nuremburg
Originally Posted by OSherman View Post
On the Evo 6 MS they changed the spur gear mount like the TA-05 V2. and the bottom deck is different and it has the sway bar stabilizers. Interesting! The Nissan GT-R looks similar to the Acura NSX Concept and the Raikei GT looks a lot like the 2003 or 2005 NSX. I'm getting a warm and fuzzy feeling about these bodies!
I need to try them both!!!!!!!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 01-29-2016, 10:18 AM   #1646
The original evo6 has sway bars. They just put a large one piece collar instead of the two smaller ones.
Old 01-29-2016, 10:39 AM   #1647
OSherman's Avatar
...you two are talking about the same thing
i think im most geek'd about the MAN bodyset
•KO Propo America
•EXOTEK
Old 01-29-2016, 10:57 AM   #1648
CL
CL's Avatar
Trader Rating: 32 (100%+)
Max,
The bottom chassis is aluminum.
CL is offline   Reply With Quote
Old 01-29-2016, 02:11 PM   #1649
vlad_sa's Avatar
I'm using spec r diffs on all of my EVO's front and rear.
I personally find them smoother to run.
But I don't use the spec r out drives, all of my diffs are molded to use Tamiya out drives with 3.5mm blades.
Old 02-01-2016, 06:11 PM   #1650
Just tossed my spare chassis on the for sale forum.
