Like Tree23Likes
Old 01-16-2016, 02:21 PM   #1591
vlad_sa's Avatar
Originally Posted by theproffesor View Post
Flat out speed won't have anything to do with carbon vs aluminum. The aluminum is only 20ish grams heavier. That little bit won't affect straight away speed. But if it is stiffer, it will affect corner speed. And that could make you faster per lap.
Wasn't even referring to straight speed.
I still believe that carbon is faster in the corners, tested it back to back.
Aluminium is more constant to drive tho.
Tamiya TRF 419X / Tamiya TB EVO 5 Exotek v1 / Tamiya TB EVO 5 Raceberry Edition / Tamiya TB EXO 6 / Tamiya TB EXO 5 Raceberry Edition / Tamiya TA05 v2 Exotek / Tamiya FF04 EVO / Tamiya FF04 EVO Black Edition / Tamiya FF03 EVO / Spice Yokomo BD7 FF / VBC FF17 / Sabre FD Mini
vlad_sa is offline   Reply With Quote
Old 01-16-2016, 03:05 PM   #1592
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
Does it feel less flexy than the carbon?
Yes, it has less flex than the carbon piece.
madjack is offline   Reply With Quote
Old 01-16-2016, 03:07 PM   #1593
madjack's Avatar
Originally Posted by vlad_sa View Post
Does alu make any sense in 17.5 class?
Carbon will yell faster speed for sure.
I'm speculating because it hasn't been tested. The carbon chassis is great in 17.5 on asphalt, but I've been looking for more steering on carpet hence the aluminum purchase. Time will tell!
Old 01-16-2016, 03:17 PM   #1594
theproffesor's Avatar
Trader Rating: 57 (100%+)
That's odd, I'm looking at the aluminum chassis to help take away front traction. This car turns in ridiculously hard.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 01-16-2016, 08:55 PM   #1595
vlad_sa's Avatar
My Exo turns rather well on carpet, I like aggressive corner entry. I am running softer springs at the front tho and Spec R diff filled with 1mil oil. I have my steering set at 23 degrees on both sides.
Old 01-16-2016, 09:57 PM   #1596
Josh-n-ya's Avatar
Trader Rating: 75 (100%+)
Tq'd and won in my 17.5 class. Car was good all night. I did however go down to 2k in the specR diff. 5k feels smooth but after testing it allows the rear to break loose at times. In my USGT class I did the same with 2k diff oil. The USGT has been tricky trying to set up. It must be the tires. Two same cars and tried same setups but USGT doesn't stick like I would like. I decided to just go ahead and widen the car with some wide wheel hexes. Trying to fill out the wheel wells. It really worked. I even was able to use some stiffer springs to get some faster rotation through the turns. Did a bunch of practice laps before the main and pulled in to change battery's. Did another couple of laps and lined up. Stripped a spur!!! Oh well. Just glad to finally get some time with these cars today.
Josh-n-ya is offline   Reply With Quote
Old 01-16-2016, 10:01 PM   #1597
Josh-n-ya's Avatar
Yeah I'm not going to get the aluminum chassis. My cars are doing just fine.
Old 01-16-2016, 10:29 PM   #1598
Leester's Avatar
Trader Rating: 21 (96%+)
From all of the testing I've done with the prototype chassis, the aluminum chassis will definitely take away front steering. I haven't had a chance to run on carpet yet, but on asphalt I've gone all the way down to an A block in the rear (XA front rear)! That's 1* rear toe...on asphalt EXO6 rotates very well midcorner in and out with excellent steering on corner entry. Sometimes you've got to go way outside the box to make things work
Leester is offline   Reply With Quote
Old 01-17-2016, 07:48 AM   #1599
madjack's Avatar
Sounds like I have some other areas to sort out first, still running a spool up front. I may have jumped the gun on the new chassis, oh well.
Old 01-19-2016, 09:08 PM   #1600
Hi guys, my exo 6 is running noisier than my belt drive car. Is this normal?
N15M0 is offline   Reply With Quote
Old 01-19-2016, 10:23 PM   #1601
vlad_sa's Avatar
Very normal unless you have grinding noise?
It's shaft powered chassis they are always louder.
Old 01-19-2016, 10:27 PM   #1602
What do you mean by grinding noise?
Old 01-20-2016, 02:53 AM   #1603
Trader Rating: 8 (90%+)
if you place your car on a stand, remove your pinion, and spin your wheels. It should be smooth, no notches and some people are able to get it free spinning for a while too.
TenzoR is offline   Reply With Quote
Old 01-20-2016, 07:24 AM   #1604
I see. But mine is not exactly smooth. What should I do? Thanks.
Old 01-20-2016, 10:43 AM   #1605
Josh-n-ya's Avatar
Mine spins freely. Way more than any belt car I've had. You have to start with one gear box at a time. Make sure a gears mesh properly. You might have to add shims to get everything smooth. Then when both gear boxes are free flowing is when you install the shaft. Very important to lube the plastic gears. It helps.
