Like Tree23Likes
Old 01-03-2016, 04:15 PM   #1531
theproffesor's Avatar
Trader Rating: 57 (100%+)
Darksidedesigns.net
He does good work. I've been using him for the last 4 years.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 01-03-2016, 05:19 PM   #1532
I want to widen the front end just a tad. I ordered some C blocks. Does anyone know how much each letter block is wider than the previous?
Old 01-03-2016, 08:16 PM   #1533
Josh-n-ya's Avatar
Trader Rating: 75 (100%+)
Professor, that gt40 body is with stock blocks? Nothing widened? I got rid of my gt40 bodys when I had my ARC. The wheels where way to tucked in for my liking. Looked kind of funny. Looks good tho on the Exo.
Josh-n-ya is offline   Reply With Quote
Old 01-04-2016, 01:29 AM   #1534
tonyv2382's Avatar
Trader Rating: 64 (100%+)
Send a message via Yahoo to tonyv2382
Originally Posted by TenzoR View Post
Really depends on what you are after. I think default EVO6 has XB and D blocks, which is 3 degree toe. You can achieve the same thing with XA and E blocks, but that increase the width by 1mm. Here's a nice chart.
https://www.tamiyausa.com/articles/s...?category_id=7
Perfect. Exactly what I need. Thanks
tonyv2382 is offline   Reply With Quote
Old 01-04-2016, 04:14 AM   #1535
I'm not trying to widen to fit the wheel wells. This car has a lot of initial turn in. I am trying to slow the reaction down and I know widening the trek width from the hindg episode blocks is one way of doing that. I just wants to know how much I was widening by. I found a chart on exoteks website. I just need to wait until they have some d blocks available. C blocks only widen track witch by .75mm total. It might be enough. But d blocks will widen the car by .75mm each side.
Old 01-04-2016, 06:26 AM   #1536
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Have you considered softer front springs ?
I found that calmed this car down considerably at our track
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 01-04-2016, 07:13 AM   #1537
vlad_sa's Avatar
I'm driving the C at the front in all of my cars.
Still need to work on the setup of my EXO 6 as it was a bit lazy on the turn in.
But drove it for the first time last weekend.
Tamiya TRF 419X / Tamiya TB EVO 5 Exotek v1 / Tamiya TB EVO 5 Raceberry Edition / Tamiya TB EXO 6 / Tamiya TB EXO 5 Raceberry Edition / Tamiya TA05 v2 Exotek / Tamiya FF04 EVO / Tamiya FF04 EVO Black Edition / Tamiya FF03 EVO / Spice Yokomo BD7 FF / VBC FF17 / Sabre FD Mini
vlad_sa is offline   Reply With Quote
Old 01-04-2016, 07:32 AM   #1538
Softer front springs? I thought that would cause more weight transfer to front on braking causing the front to dig harder?
I have gone to a heavier weight front shock fluid to try next time out, I'm also going to try saucing only the inside half of the front tires. I know this is a tuning option, but I really don't like doing it as I'm not consistent enough with saucing just "half." I am also going to play with droop some more. But don't want to go too far with it.
Old 01-04-2016, 08:39 AM   #1539
Wade....'s Avatar
+2 on softer springs. I just went softer in front from Pink to Silver and it was money. Turn in was much more controllable. Running C Blocks. Silver HPI's all around.
Wade Huesman, TCORC Secretary/Pencil Pusher
Wade.... is offline   Reply With Quote
Old 01-04-2016, 09:00 AM   #1540
vlad_sa's Avatar
Already have few setups in mind for the next training.
We're driving indoor in this time of the year, high grip carpet.
Old 01-04-2016, 09:55 AM   #1541
That will increase the track width by 0.5mm not 1mm
Each block is 0.5mm different. As you have just gone up 1 block higher for front and rear blocks you have kept the same toe in value, but just increased track width by 0.5mm
For 1 mm you would need to go from (XB : D) to (X : F).
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 01-04-2016, 10:31 AM   #1542
tonyv2382's Avatar
You guys liking the Exo 6 in general?
Old 01-04-2016, 11:27 AM   #1543
I cannot speak for the Box version of the Evo but the Evo 6 with Exotek conversion is the best car I have ever owned (and believe me, I have owned a ton!)
It is very responsive to tuning changes and produces a TON of grip.
Are you looking at a box stock Evo or are you considering the Exotek conversion as well?
Awesomatix A800 x2, VBC D08 / D07, CRC WTF16 F1
National Points Member 201
RollingChicane2 is offline   Reply With Quote
Old 01-04-2016, 01:08 PM   #1544
tonyv2382's Avatar
I just got the exo conversion and got it together. The Evo was good as well. Can only imagine with the conversion. I'm coming from off-road and have been through 2 touring platforms that I wasn't thrilled with. This one looks promising I just wish it had the adjustable suspension brackets with the inserts like some other cars.
Old 01-04-2016, 02:14 PM   #1545
Actually from letter A to letter B is .5mm difference A to C is 1mm difference. Or B to C is .5mm difference. It's always been this way
Juan Aveytia is offline   Reply With Quote
