Like Tree11Likes
Old 12-27-2015, 07:44 PM   #1501
theproffesor's Avatar
Trader Rating: 56 (100%+)
I haven't run mine yet, but I did have an issue with binding when the plastic "shoe" was in the vertical position. It kept the arm from having needed up travel.
I removed about 3mm deep with of material to correct the issue. I don't think it will be a problem as I only run USGT and USVTA.
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 12-28-2015, 11:02 AM   #1502
Thanks proffesor. I've just always wondered why other manufacturers haven't used swing shaft caps with their spools. I assumed the plastic cap would be a weak point
speed_dmon is offline   Reply With Quote
Old 12-29-2015, 11:51 AM   #1503
tonyv2382's Avatar
Trader Rating: 64 (100%+)
Send a message via Yahoo to tonyv2382
Just installed the Exotek conversion and I need some suggestions for gearing. I believe I will be running 64 pitch gears but if you guys have recommendations for 48 I'll take those as well. I realized that I have some spur gears that are too big to clear the top deck.
tonyv2382 is offline   Reply With Quote
Old 12-29-2015, 11:57 AM   #1504
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
You didn't mention which wind of motor ?
For 17.5 I run 64p
73x52
3.51:1 ratio
Old 12-29-2015, 12:15 PM   #1505
tonyv2382's Avatar
For 17.5 I run 64p
73x52
3.55:1 ratio
Yes I'm sorry 17.5
Old 12-29-2015, 02:35 PM   #1506
For 17.5 I run 64p
73x52
3.55:1 ratio
Did you alter your internal ratio?
Old 12-29-2015, 03:50 PM   #1507
Correction
3.51:1
Internal 2.5
Old 12-30-2015, 08:27 PM   #1508
I'd like to see some pics of esc/motor wiring for the evo/exo's out there if possible. I'm struggling a bit with the esc orientation on my new Evo as it is a diff esc/wiring orientation from my existing one.
Looking for ideas
RollingChicane2 is offline   Reply With Quote
Old 12-30-2015, 09:32 PM   #1509
maxepower's Avatar
Talking TB-03 Internal
76spur/53pinion = 3.495 FDR
Using TB-03 gears instead of EVO 6 gears 2.438 instead of 2.5
I would like to try 48 pitch 60/42= 3.48
17.5 R1 motor
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 12-30-2015, 11:20 PM   #1510
Looking for ideas
Here's my rookie setup
Old 12-31-2015, 12:25 AM   #1511
Looking for ideas
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 12-31-2015, 10:46 AM   #1512
CL
CL's Avatar
Trader Rating: 32 (100%+)
Correction
3.51:1
Internal 2.5
What brand motor are you running? Is this for the TQ carpet track?
CL is offline   Reply With Quote
Old 12-31-2015, 10:59 AM   #1513
SchuurSpeed
Yes TQ
Old 12-31-2015, 12:20 PM   #1514
I'm encountering the same exact issue. Where are you shaving off the 3mm?
Old 01-01-2016, 05:53 AM   #1515
vlad_sa's Avatar
Here is my freshly done Exo 6
Tamiya TRF 419X / Tamiya TB EVO 5 Exotek v1 / Tamiya TB EVO 5 Raceberry Edition / Tamiya TB EXO 6 / Tamiya TB EXO 5 Raceberry Edition / Tamiya TA05 v2 Exotek / Tamiya FF04 EVO / Tamiya FF04 EVO Black Edition / Tamiya FF03 EVO / Spice Yokomo BD7 FF / VBC FF17 / Sabre FD Mini
vlad_sa is offline   Reply With Quote
