Old 08-12-2005, 10:58 AM   #16
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
Yup, it's fine, the voltage rating is only the maximum it can take. Lower voltages make a smaller and lighter cap, that's all.
If you can find 6.3v ones, get them. I use them with my solar robots, and are nice and compact. Just make sure it's used for the receiver . The 1000uF I use is 3/8" diameter, 1/2" long. Otherwise, a 10V will do just fine. The 4700's will be much bigger, but not too bad, at 5/8" diameter, 1-1/4" long or so.
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 08-12-2005, 05:48 PM   #17
Regional Moderator
daniz24's Avatar
Try to connect the Personal Transponder to the 3rd Channel slot of your receiver instead of the battery slot. My friend have similar problem before but now the problem is history. Maybe it'll work with you too...
daniz24 is offline   Reply With Quote
SERVO PROBLEM lancerevo22194 Micro and Mini Scales 11 07-23-2008 03:17 PM
ESC or SERVO Problem kimbalion7 Electric On-Road 4 02-02-2006 03:27 AM
servo problem. Please help! cars.cars.cars Nitro On-Road 4 08-22-2005 12:02 AM
servo problem wothrottle Electric On-Road 0 09-29-2004 05:24 AM
servo problem wahturi Nitro On-Road 7 12-25-2002 09:48 AM
