Old 03-16-2014, 09:06 PM   #31
Trader Rating: 20 (100%+)
Think of the way foam tires wear, particularly in the front of the car. They wear into a pattern from the car settings and track with the fronts often developing a cone shape. But, you wouldn't leave a coned front foam time on the car, you would cut it flat again so that the suspension works as intended with the tire. Why wouldn't you treat rubber tires the same and rotate them (closest thing to cutting them we have)?
Thinking about it, if you feel that you need your tires to be worn into each corner of the car you may also want to tune each corner differently. More or less camber/caster/toe at each corner then, to suit the track and the un-rotated tires.
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 03-17-2014, 03:59 PM   #32
Chaz955i's Avatar
Originally Posted by dragonracing View Post
i rotated mine front to back and totally made my car worse. switched them back and it was back to where it was. car still handles like crap (to me) but its fast.
Same. Front to rear undrivable and left to right just weird. Lot of tire wear theory getting dropped but I will go with what works vs. what should work.
Chaz955i is offline   Reply With Quote
Old 03-17-2014, 07:53 PM   #33
DesertRat's Avatar
I would suspect that if you full sauce tires every run, rotation doesn't affect them as much. I rotated front to back, side to side, who knows. I got home, took the tires off, and tossed them in the bag!
Maybe if the car is working good, I will refrain from rotating that race day. It justifies laziness.
I race toy cars for fun. If I need to explain, you'll never understand.
If everything is under control... go faster.
WTB: Carpet racing in Arizona.
It is obvious and intuitive to the most casual of observers that RC racing is better than golf.
DesertRat is offline   Reply With Quote
SEO by vBSEO 3.5.0
