Old 09-28-2014, 11:37 AM   #121
AlexPate's Avatar
Trader Rating: 19 (100%+)
Tuning haus f104 rims also don't work very well. The spokes on the inside of the front rims have to be trimmed or it rubs
Stick with Tamiya or exotek
Alex Pate. www.gripworksrc.com
Motiv Rc, Hobbywing, ORCA, Protoform,
VBC RACING, XRAY, ROCHE, AWESOMATIX, TEAM ASSOCIATED,
ARC,CRC,AVID,MCKUNE DESIGN, PROLINE, JCONCEPTS, GFORCE, MACLAN, R1WURKS
AlexPate is offline   Reply With Quote
Old 09-28-2014, 12:03 PM   #122
Ph3nyx's Avatar
you'll have to modify the king ping as described here : New vbc f-1 lightingf
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is online now   Reply With Quote
Old 10-04-2014, 11:39 AM   #123
EricPF's Avatar
It's been really run shaking down this car and learning to drive a 2WD car after only ever driving a TC. It's been challenging for sure!
I amazingly went the first month without breaking a single kingpin, and then all the sudden I broke 3 within 3 battery packs. Traction rolling just murders them.
I found these Tamiya TRF201 pins at the local hobby shop that are a perfect sized replacement for the modification described earlier in the thread: http://www.tqrcracing.com/shop/produ....asp?p_id=4179
I threw these in and it's been clear sailing ever since. Pumped to run this car in Vegas!
Eric Epp
PROTOform // racepf.com
EricPF is offline   Reply With Quote
Old 10-09-2014, 01:57 PM   #124
Ph3nyx's Avatar
Video review of the lightningf in french (i will add english version or subtitles soon)
carpet and asphalt track footage included
+ YouTube Video
Old 10-15-2014, 03:21 PM   #125
tommy911t's Avatar
Trader Rating: 50 (100%+)
The word on the street was that VBC(or thier supplier) cut the originals too deep at the e-clip.
Solution:
http://www.tqrcracing.com/shop/produ....asp?p_id=8825
"Tuning Haus delivers a durable alternative to the stock Lightning F kingpin with a precisely ground, polished and TiCN coated front kingpin. Particular attention has been paid toward improving e-clip fit compared to the original part, and includes Tuning Haus 2mm circlips for the best possible front spring alignment."
Northwest Racing Calendar
My Bicycle Sales and Service Shop in PDX: Tuite Bicycle Repair
RC Blog:OnTheTone
tommy911t is offline   Reply With Quote
Old 11-10-2014, 06:39 PM   #126
slicendice's Avatar
Trader Rating: 23 (100%+)
Anybody have links to good Carpet setups ?/???? thanks...
Drew
slicendice is offline   Reply With Quote
Old 11-12-2014, 11:31 PM   #127
skyball's Avatar
Default New parts available
...everyone has probably seen this, but if somebody missed it: VBC has introduced some new parts fpr the LightningF, mostly coated pins and rods, but also a nice center shock + antenna mount:
new-vbc-lightning-series-option-parts
[Sanwa M12][Awesomatix A800][Ronalds Yoke BD-7 2014][Roche P12 2016][Asso RC12R5.2][VBC LightningFXM]
skyball is offline   Reply With Quote
Old 11-25-2014, 04:06 PM   #128
Hello,
I recently purchased a LightingF but ran into an issue. While I was putting in the set screw into the Rear chassis brace, the carbon piece started to split and delaminate. Has anyone had this issue? It seems maybe the hole is too small?
Thanks!
rootz0r is offline   Reply With Quote
Old 11-25-2014, 04:16 PM   #129
Ph3nyx's Avatar
yes , you must CA the sides of the carbon piece before and use a plier to hold it tight while you put the set screw. if you have a 3mm threading tap , it's beter !
Old 11-25-2014, 04:25 PM   #130
AlexPate's Avatar
Solution:
Worse than the stock parts. Avoid this untill they fix it. One broke in a traction roll the other when someone else driving my car tapped the wall 2 times in a row.
Old 11-25-2014, 04:29 PM   #131
Photocycler's Avatar
Trader Rating: 34 (100%+)
Pretty simple fix, Me and a buddy are using the Flash king pins, running the e-clip on top f the carbon plate, spring under the plate with no problems
[evan b]
Timezone I & II | RoseCityScaleRacing | Premier RC Raceway
Photocycler is offline   Reply With Quote
Old 11-25-2014, 04:33 PM   #132
AlexPate's Avatar
I was running the flash kingpins. One was bent a little so I figured I would try the tuning haus ones. Wrote them about it. No reply yet.
Old 11-25-2014, 05:02 PM   #133
Thanks, I'll do that. Do you have to seal all carbon pieces? Or just the main chassis and rear chassis brace?
Old 11-25-2014, 05:37 PM   #134
Ph3nyx's Avatar
i personaly didn't seal anything else (to keep the flex of the chassis). No problems so far
Old 11-26-2014, 04:27 AM   #135
haura415's Avatar
haura415 is offline   Reply With Quote
