Old 07-08-2014, 10:52 PM   #76
skyball's Avatar
Originally Posted by robert s View Post
I used a 3mm shock shaft and cut it down to 35mms. By using the shock shaft, I am able to still run the spring on the bottom like the original kingpin and adjust the ride height of the car with the shims under the steering knuckle...
Robert
I think there's a disadvantage to the method you describe. Depending on how deep you push the pin in, at the moment when you fix the screw in the steering block, you introduce more or less spring preload or play above the spring. I imagine this is difficult to do in an exact way.
Christian
[Sanwa M12][Awesomatix A800][Ronalds Yoke BD-7 2014][Roche P12 2016][Asso RC12R5.2][VBC LightningFXM]
skyball is offline   Reply With Quote
Old 07-09-2014, 09:20 AM   #77
Default Tires
Hi guys,
which tires fit on the Lightning. Tamiya-style or Formula Ten Wheels?
Thanks for your help.
Michael
Fantipilot is offline   Reply With Quote
Old 07-09-2014, 09:23 AM   #78
JayL's Avatar
Originally Posted by Fantipilot View Post
Hi guys,
Michael
Tamiya
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 07-09-2014, 11:42 PM   #79
Default Thanks
Perfect, thanks a lot
Old 07-10-2014, 03:01 PM   #80
Originally Posted by whityboy View Post
This is the only way to go not to get frustrated with this f1.
Don't spend your money on new ones, even not the titanium coated.
At the ETS eveybody that was using kingpins broke them and at the end nobody was using them anymore.
once you used this mod you will love this car and end you heats
Are you making fun of me, brother
At the ETS didn't finished my runs, after 4 kingpins i place a suspension pin, no problems anymore
This is the only weak point off the lightning, with this mod no more problems, and much easier to change the spring and ride height. No more c-clips
DW Hobbyshop
Serpent, VBC racing, muchmore racing, skyrc, nosram,...
Driving a ERYX3.0
stofke is offline   Reply With Quote
Old 07-11-2014, 08:27 AM   #81
tommy911t's Avatar
Trader Rating: 50 (100%+)
Put down many laps last night with the new car. My kingpins held up great to my eager driving.
One note, I'm using the Exotek +3 rims because my other none +3 don't clear the kingpin/carbon brace up front.
Car is awesome!
Northwest Racing Calendar
My Bicycle Sales and Service Shop in PDX: Tuite Bicycle Repair
RC Blog:OnTheTone
tommy911t is offline   Reply With Quote
Old 07-18-2014, 03:52 AM   #82
Ph3nyx's Avatar
Hello
for the first video dedicated to the lightningF at RCF1, i did an unboxing video (in french)
Build and review will come soon
+ YouTube Video
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Old 07-25-2014, 05:05 AM   #83
Ph3nyx's Avatar
New pics of the VBC lightningF actualy on test for www.rcf1.fr
the body is a TRG , flamming decals tamiya 53840
Old 07-29-2014, 06:26 AM   #84
Default Kingpins
Hello everyone,
wanted to let everyone know that VBC is aware of the issue with the kingpins on the car breaking and is working on a fix for this issue according to VBC Racing USA
robert s is offline   Reply With Quote
Old 07-29-2014, 07:35 AM   #85
Ph3nyx's Avatar
Excellent news ! i did the mod too cause i bent a king pin on a hit
I have cut 1mm on the top of the uprights to put 4mm of shims under it and to free the springs. I can now put the ride tires with 5mm of ride height !
Old 07-29-2014, 11:42 AM   #86
AlexPate's Avatar
Trader Rating: 16 (100%+)
hi guys, looking into moving on from Tamiya and into a vbc, the new lightningf looks interesting, im curious why it is still priced cheaper than the flash04, is it a lower entry model or an upgrade over the flash, would like to know if anyone can tell me the differences between the two
Thanks for your input
Alex Pate. www.GRIPWORKSRC.com
Motiv Rc, Hobbywing, ORCA, Protoform,
Team VBC Racing
Lightning FX, Wildfire D07, Ghost Evo, Lightning 12 v2
AlexPate is offline   Reply With Quote
Old 07-29-2014, 11:54 AM   #87
JayL's Avatar
the lightningf is a new design, much simplified from the overcomplicated Flash. For example the steering and the alum pod plate, the wierd rear axle ride height plate and the upper arm mounts.
it is not a budget version, it has every part you need stock and all carbon fiber. It takes all the best from other F1's and combines it into a quality kit.
I own all the current F1's and keep going back to running the LightningF
look at my sig if you are looking for a place to buy one and feel free to ask me any questions.
Old 07-29-2014, 12:33 PM   #88
AlexPate's Avatar
Is there any reccomended updates other than custom king pins?
Team VBC Racing
Old 07-29-2014, 12:33 PM   #89
AlexPate's Avatar
Will the diff fit kimbrough spurs?
Team VBC Racing
Old 07-29-2014, 12:53 PM   #90
JayL's Avatar
do kingpins like this:
New vbc f-1 lightingf
and use these as kingpins:
Tamiya #54241
super slick setup, thats what I run.
I reccommend you run a spur like the stock one that has 16 holes, the diff works much better and has more adjustment range. Xenon makes some.
