New vbc f-1 lightingf
#256
#258
I hope VBC adopts a similar design to the X-1 but adds their usual tricks and flare. Then at least there would something else on the market worth considering. Add a floating servo mount to the X-1 design (super easy with this design) which would eliminate chassis twist due to servo torque.
#261
Looks awesome though.
#262
I just had a quite successful weekend at the ETS in Mattsee, Austria. Made it into the A-Mains at ETS for the first time, started 8th and finished 7th out of around 70 drivers. Usually I don't make the A-Mains, but rather the B-Mains or sometimes even C. But the car ran just fantastic, so I thought I'd share my setup.
Christian
BTW, videos can be seen on http://ets.redrc.net/
Christian
#263
Hi
I still have a problem with my Lighning.
When breacking from an long straight, the rear doesnt "hold"
In fast corners erverytime, the rear are always instable.
So in all situation the rear is not stable.
My Setup:
Camber 1,5°
Caster 5°
Side link: inner position
Spring Front: Tamiya Gold
Spring Side: Tamiya Silver (Testing Cupper to Black)
Side Damping: 60k (Testing 60k - 100k)
Main Damping: 800 Oil ; 2 Hole ; Tamiya Red Spring.
Motor: LRP 21.5
Tyre: Ride R1
I was testing the Front from the Flash 04 but nothing changed.
Now i changed the link position but the weather is not so fine to test (Rain today)
Anyone an idea ?
Thanks a lot
My Setup:
Camber 1,5°
Caster 5°
Motor: LRP 21.5
Tyre: Ride R1
Anyone an idea ?
Thanks a lot
#264
Hi
My Setup:
Camber 1,5°
Caster 5°
Motor: LRP 21.5
Tyre: Ride R1
Anyone an idea ?
Thanks a lot
My Setup:
Camber 1,5°
Caster 5°
Motor: LRP 21.5
Tyre: Ride R1
Anyone an idea ?
Thanks a lot
#265
Thanks a lot
Break is at 50 % it maybe will be better at the break point, but not at full speed in an long corner
#266
What kind of surface are you running on. And possibly check the glue on your tires. Also is your car tweaked? That would give instability under braking. Lift the nose from the center and spin the front wheels. Lower the car back down and of one wheel hits the ground before the other them the car is tweaked. You would adjust this with your side springs. Be careful
I had rear pod tweaked and when the tires hit the ground evenly there was 1mm difference in left to right ride height
#267
Regional Moderator
Found a new (better) track with a separate track for F1, FF cars or any newbies that wants to play. At least I wont get rear ended again.
Tossed the mangled body and painted up a new scheme
#268
I like the body and wings better than what I am running? What brand are they?
Bad driving, a few somersaults/barrel rolls and a rear end from a much faster TC tends to break the toughest things.
#269
Be careful most rules in North America say no lexan front wings
#270
The differnt between left and right i found out this weekend, and checked, that there are differnts between the Alu mounts.
Ride high is ok on the pod 6mm and the front 6mm, in the center (under the Accu) 6 mm. Everything looks fine.
Bearings are all ok, running fine (front Wheels about 5 min free run).
A good friend from my club drive STM (Austria) in Formel class and this week he finsh in 2th posision and he can not find out why my lighning is so tricky to drive.
We drive on Asphalt.
When we take a look on the stable by accelerating:
With Tamiya cupper (silver) side springs , it was not possible to accelerate very fast (out of Conner). When i mount VBC Black the Car was stabe und there was no oversteer, but in other situation the car was very very tricky to drive.
