Old 12-05-2014, 05:11 PM   #376
Originally Posted by Josh-n-ya View Post
I checked my puller and its like yours. I used it for trinity motors as well. Mine will not fit inside endbell to safely press up against outer bearing. Maybe using a smaller spacer might work but might damage bearing. I see no problem installing bearings though.
Thanks for checking. Maybe we will eventually get the answer.
napolean is offline   Reply With Quote
Old 12-10-2014, 05:04 AM   #377
Benzaah's Avatar
Trader Rating: 21 (96%+)
After some gearing advice on this motor in 13.5. Running blinky tourer on a twisty track with a 60ft straight. I've been gearing my HW v10 with timing at 40 at 3.8 and my d4 with timing at 35 at 4.2. I hear these motor like to rev. Should I consider starting around the 4.8 range? I've also heard there is a lot of timing built into this motor. Anyone's thoughts on turning up the can?
I picked one of these up as a I guy know was raving about the 21.5 version. Can't wait to hit the track.
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 12-10-2014, 03:56 PM   #378
EDWARD2003's Avatar
Check my video out for timing settings on the R1. Please use this video as a reference.
https://www.youtube.com/watch?v=MzE39EdYvnc
I would first start out with the timing set around 15-20 degrees on the can. Then go from there.
EDWARD2003 is offline   Reply With Quote
Old 12-10-2014, 05:56 PM   #379
benny I used a 21.5 and race with 17.5. your gearing sounds about right for hobby habbit. I don't over 38. timing. don't be afraid to drop a tooth. they like to rev.
trevor waye is offline   Reply With Quote
Old 12-11-2014, 08:53 AM   #380
Rugspin's Avatar
In 1/12th scale many of us run the R1-Ultra Premium in 17.5 Motor Timing set to 0 with around a 105 rollout. My current gearing is 72spur 57pinion.
Steve Burgess
Rugspin Graphix http://www.rugspingraphix.com
FB http://facebook.com/rugspingraphix
Email rugspinner@aol.com
Rugspin is offline   Reply With Quote
Old 12-11-2014, 10:40 AM   #381
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Originally Posted by torg View Post
After having a closer look inside the R1 and a killshot (and from talking to Mr R1 in person this weekend - I finally get what you were trying to explain ). "Timing" is not "built in" at all. In fact it is retarded in the classical "timing" sense and there is something non-electronic that is occurring, throwing the motolyser algorithm off completely. How, I don't know, writing the motolyser guys now to see their take on it.
Posted my findings here.
As I said... still learning... learned even more over the weekend.
I'm going to keep my comments very brief.
I'm a recovering oval racer. When it comes to gear and timing, amps don't lie.
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 12-11-2014, 06:27 PM   #382
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
So basically the $140 is a waste of $ compared to the 90 one?
jlfx car audio is offline   Reply With Quote
Old 12-11-2014, 06:55 PM   #383
Madulla's Avatar
Where can I find a new sensor board? My new motor came with a sensor board DOA. No wonder it was so slow. I put it on my new motor tester and it would not even light up the sensor lights for ABC.
Hobbywing North America Team Driver
hobbywingdirect.com
Madulla is offline   Reply With Quote
Old 12-11-2014, 07:22 PM   #384
Josh-n-ya's Avatar
Trader Rating: 72 (100%+)
I will try and find that out for you.
Josh-n-ya is offline   Reply With Quote
Old 12-11-2014, 07:33 PM   #385
Josh-n-ya's Avatar
So actually he said he just added it to the R1 website. Under motor lab then click on motor parts. $16
Old 12-11-2014, 07:36 PM   #386
Madulla's Avatar
I checked and it wasn't there 5 min ago and now it is, thanks. Will another companies sensor work or does it have to be a R1?
hobbywingdirect.com
Old 12-15-2014, 11:43 AM   #387
Professor's Avatar
this may have been asked & answered previously, but can someone tell me the difference between the 21.5 r1 & the 21.5 r1 ultimate version (apart from price)
thanks in advance
VBC RACING AUS--HOBBYWING--MAD GRAPHICS--BITTY DESIGN
Professor is offline   Reply With Quote
Old 12-18-2014, 01:12 AM   #388
NOFX's Avatar
Trader Rating: 23 (100%+)
When are 17.5s going to be back in stock please?
Castle Hill - The Home of Vintage Racing in NSW
2017 Vintage Festival 11th & 12th of November 2017
2018 Vintage Enduro (Return of the Dukes) - start planning!!
@cassovintage www.hillsoffroadrc.com
Look out for the St Ives vintage event coming up soon!
NOFX is offline   Reply With Quote
Old 12-18-2014, 05:04 AM   #389
Trader Rating: 20 (100%+)
thanks in advance
originally from R1Works...
ULTRA PREMUIM is basically an updated version of the previous motor.(updated version approved by Roar & has passed tech at Roar events)
same parts:
rotor
endbells
bearing
sensor
updated:
-Stator-
New stator has two front rings (makes your motor power more consistent throughout the run)
End wind (wire) is bonded in place to reduce vibration (improves initial acceleration & top end)
(no change in dimension,just improved performance) We also applied improved manufacturing techniques (proprietary) on both the same stator material & same wires (made in USA)
Compared to the previous motor based on beta user feedback, the motor improved acceleration,top end & power consistency throughout a race even at extreme temperatures (extreme temperatures not recommended,this will shorten the life of the stator).
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 12-18-2014, 08:38 AM   #390
What kind of Rings have been added? Plastic ? Anyone got a picture to show the differences... Don't see how plastic parts would change performance. Being sensor and stator are still same
