Old 09-12-2014, 12:05 AM   #316
R1wurks's Avatar
Toby, Yes 13.5 Ultra Premium will be available.
Originally Posted by tobyzhang View Post
Will you have certified 13.5 in stock also?
r1wurks.com
r1wurks at gmail.com
R1wurks is offline   Reply With Quote
Old 09-13-2014, 12:39 AM   #317
tobyzhang's Avatar
Originally Posted by purple haze View Post
I just ordered my R1 21.5 , for our VTA , blinky class . Does 4.0 FDR and 30 degrees of timing for a 80x36 foot carpet track , sound like a reasonable starting point ? thanks .
Agreed, 3.5 is a good starting point. But also try 20 timing or lower first. My experience in tamiya gt3 says r1 21.5 do not like very high timing.
tobyzhang is offline   Reply With Quote
Old 09-15-2014, 09:21 PM   #318
Default cogging
this is my first R1. I bought a 17.5 with premium 1500++ rotor. Timing is set at 20 degree. Tekin RS esc. I was adviced to increase the throttle min at my speedo. Increased at diff minimum level and now I am at Max but it still cogs. Am I getting a bad motor? Please help
www.ActivRc.com ARC
fx35rc is offline   Reply With Quote
Old 09-15-2014, 10:18 PM   #319
jdawg81's Avatar
Both of my R1 motors cog a bit with my Tekin RS ESC. Once it gets going it's fine so I'm not sure what causes it because I don't have this issue with any of my other motors.
jdawg81 is offline   Reply With Quote
Old 09-16-2014, 08:14 AM   #320
I change sensor wire twice. All my buddies' R1 are fine too. The motor is fast. My motor cogs and the car wont get going. When I hold it in my hand the motor will go, before I max out the throttle min on my esc it won't even run if I held it up in my hand.
www.ActivRc.com ARC
Old 09-16-2014, 08:16 AM   #321
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
I've had similar cogging issues with a Tekin RS as well, not just with R1 motors
LRP, same motor, no cogging
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 09-16-2014, 08:18 AM   #322
Thanks Dave, time to switch esc then.
www.ActivRc.com ARC
Old 09-16-2014, 10:12 AM   #323
Josh-n-ya's Avatar
Trader Rating: 72 (100%+)
Had major issues with tekin esc's in past. Cogging, settings getting wiped out. Getting a 21.5 for usgt now so I can play around and give better feedback after testing.
Josh-n-ya is offline   Reply With Quote
Old 09-16-2014, 10:46 AM   #324
Time to sell my tekins then...LOL
www.ActivRc.com ARC
Old 09-21-2014, 11:12 PM   #325
Josh-n-ya's Avatar
Great run today with both 17.5 and 21.5. First outing with the 21.5 in USGT I was geared at 3.45 using a 88 spur. Started timing at 20* and was ok but went to 25* and was money. Plenty of infield speed and straight. My 17.5 was geared at 3.75 and I was timed at 35*. I was passing people on the outside in the infield and straight. These are the PREMIUM motors.
Old 09-22-2014, 10:27 AM   #326
Thanks for the feedback
www.ActivRc.com ARC
Old 09-22-2014, 08:24 PM   #327
Default R1 17.5 with premium rotor
Help Please,
I am using a Hobbywing V 3.1 speedo for an R1 17.5 with premium rotor. The motor ran slow. Its set up on blinky mode. I switch motor to Thunder power 13.5, Orca 17.5 TX and the ran fine.
Before a hobbywing I had a tekin RS pro. The motor ran fine fine for 3 batteries, then the motor cog very bad that it wont run.
I wonder if I got a bad motor.
www.ActivRc.com ARC
Old 09-22-2014, 11:28 PM   #328
Josh-n-ya's Avatar
Help Please,
Did you put the rotor in? When the motor is out of the car does it feel smooth when you turn it? Your best bet is to spend $6 bucks and send it back to R1 and have him look it over for you. Then you will know if its the problem.
Old 09-23-2014, 09:25 AM   #329
Yup, Steve said I might have a bad sensor board. He asked me to send it in. Fast respond from Steve. I can't wait to run it again. Its freakin fast...LOL
www.ActivRc.com ARC
Old 09-23-2014, 12:56 PM   #330
mtveten's Avatar
Trader Rating: 27 (100%+)
so how does an ultra premium motor differ from the r1 I bought last winter?
mtveten is offline   Reply With Quote
SEO by vBSEO 3.5.0
