Old 07-03-2014, 06:31 AM   #226
o2 designs is offline   Reply With Quote
Old 07-09-2014, 02:06 PM   #227
Originally Posted by vivo quevas View Post
John at what point (timing) does the amp draw and rpm gain cancel each other out?
hard to tell from the dyno, but your batteries and race length will be factors. i'm still traveling, but I'll check my data when I get home tomorrow but I recall the amp draw at ~68 degrees was comparable to other motors I've raced in 12 minute mains (with much less timing). I was really responding to a comment about RPM & power dropping off after 60 Degrees and I saw none of that up to at least 70 degrees timing.
John Wallace2 is offline   Reply With Quote
Old 07-09-2014, 05:57 PM   #228
vivo quevas's Avatar
Trader Rating: 17 (100%+)
Thank John
Tamiya/Exotek EXO6 USGT, Tamiya TB03 GT3, Exotek FR1V2
Roche Rapid 1/12, XRay Speed Merchant WGT
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
"Take an early lead and extend it".(Fast Eddie Janis)
vivo quevas is offline   Reply With Quote
Old 07-14-2014, 04:35 PM   #229
Originally Posted by ThrottleKing View Post
I love these motors in my USGT and my 17.5TC but I can't get anywhere with the 17.5 in my 1/12. I have been everywhere with the gearing and timing and it is decent at best in 1 cell. I ended up running the best at 30* and a 3.2 roll out on our track tonight with a very open layout and a 60' strait. I spent an entire day over at Access in Ohio working with it since I had the track to myself. I could put my ORCA back in and beat it by 2-3 tenths a lap no matter what I was doing to the R1 in 1/12. Maybe I got a dud but the numbers on my MMS say it is good. I did have to resolder the sensor board since it came lop sided as in one side of the sensor plate was 1mm higher than the otherside and I couldn't gap the rotor correctly with out it hitting one side and being 1mm higher on the other. I have had to do that with all three R1's I have but the others were not as bad as this one. I don't know but the ORCA is going back in the 1/12 for now until I get a new board to test to see if that is the problem.
Jeremiah
My sensor board was lop sided too. One side was reeeally close to hitting the rotor. Was able to re-solder the pins down to make it even.
redbones is offline   Reply With Quote
Old 07-16-2014, 11:52 PM   #230
Hi guys,
So here is my feedback after running my TC (with R1 Wurks 17.5T). It Rocketed!!!
In the qualifying rounds, had the #1 guy in that class ask what I was running and joked to want the race director check my car to see if I was actually running in blinky mode!
Motor setting & gearing:
Class: 17.5T Blinky.
FDR: 3.5 (36/70).
End bell timing: 30 deg.
Temp: 60-70*C (after each 6min. round)
Pity I couldn't keep the car running in consistent laps. Fastest lap was just 0.1sec/lap behind him. He was running a Killshot i think.
SUMMARY
I think the determining factors on why I didn't beat him came back to consistency, my tyre choice and car set up. On the straight I'd creep back up to him 2-3m. I also think I ran too tall an FDR ratio. Was running 3.50. I would have been better running 3.7 or even 3.8 and letting the motor rev up, potentially tweak the timing.
The #1 guy did ask to test drive my car and he thought i didn't have as much bottom end pull as his, which most likely explains my gear ratio was too tall.
Anyway, the R1 Wurks still ROCKED! Think it's time to sell off all my other motors.
Yokomo
Sanwa / Orca / Thunder Power / Trinity / R1 Wurks
Stray monkey is offline   Reply With Quote
Old 07-17-2014, 05:39 AM   #231
Who are you? Brian?
You need to let this motor rev more!
I've been using the 13.5 at AA, but I'm on 40 deg timing.
Fdr is at 5.0.
I'd say try around the 4- 4.2 with 40deg and you'll really see this motor come alive!!
Andrew S is offline   Reply With Quote
Old 07-17-2014, 07:26 PM   #232
Re: Andrew. LOL...No not Brian.
Will gear down as you mention and work the timing up. I'm excited to see what results it yields!
Thanks!
Yokomo
Old 07-22-2014, 12:50 PM   #233
Carl Giordano's Avatar
Trader Rating: 18 (100%+)
hey guys, just a quick note to praise Steve, importer of the R1 Brushless Motors. I purchased an R1 21.5 when they first came out. Used it for TCS Mini Cooper racing and loved the fact that the motor was built heavier then some other brands and allowed me to meet the minimum weight requirement. IMO, since the motor was being used in a Mini Cooper, it didn't need all the machining to lighten the motor and aid in cooling. The R1 21.5 motor was fantastic, but I fried a sensor and the car went up in smoke when the diff grease leaked and bogged down the drive train. I thought I fried the motor so once the next batches were available I ordered a new 21.5 to ready for the July 27 TCS race.
Since I assumed the original motor was toast (I should have tested it), I sent it back to Steve for repair. He quickly emailed me as he was not sure why I sent it back the sensor board was fine and so was the motor. (so now i have a back-up)
But I wanted to share a great customer experience in using the R1 motor and the customer service. I'm convinced the additional weight of the motor (i.e.: extra materials) aided in the motor's durability. I've witnessed many Trinity Killshots overheat and become paper weights.
Therefore, buy the R1 with confidence. I know my first choice will be the R1 for all my brushless needs. Thanks Steve for making a great product. The motors looks great, performs well and is beefy. All I would change is the solder tabs. I prefer the flat tabs similar to the reedy motors or perhaps bullet holes in the end bell to avoid soldering. Either way I'll be back for more.
PS: I run the R1 8.4v fan in all my Mini Cooper's - a must have! Its hard wired to the battery pack so its constantly blowing. Sounds like a ducted fan!!!
Mugen Racing / OS Engines / KO Propo / Byron Fuels / TOP Racing / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho RB6
Carl Giordano is offline   Reply With Quote
Old 07-22-2014, 01:39 PM   #234
Josh-n-ya's Avatar
Trader Rating: 72 (100%+)
Sure you got the right Steve? Lol. Just kidding!
Josh-n-ya is offline   Reply With Quote
Old 07-26-2014, 01:08 AM   #235
Gridworks Racing's Avatar
Anybody looking for a 17.5?
☆★☆The Holidays are here, Be Merry and stock up on the stuff you want☆★☆
☆★☆ Gridworks Racing ☆★☆ Your Source for G-Daub, Blitz Racing Bodies, DryFluid, Epic 1 Designs, Hobbywing, LRP, R1 Wurks, Solaris Tires, Sorex, Team Powers, Tuning Haus, VBC Racing and More!
Gridworks Racing is offline   Reply With Quote
Old 07-26-2014, 09:56 AM   #236
CraigMBA's Avatar
Trader Rating: 22 (100%+)
I am.
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 07-26-2014, 10:12 AM   #237
Originally Posted by CraigMBA View Post
I am.
We have one 17.5 available through our Web site.
Old 07-26-2014, 04:12 PM   #238
CraigMBA's Avatar
We HAD one 17.5 available through our Web site.
FIXED THAT, thx!
Old 07-26-2014, 07:08 PM   #239
FIXED THAT, thx!
Haha, thanks. You'll have it on Monday.
Old 07-26-2014, 08:07 PM   #240
We also have R1wurks motors in stock. 3 flavors to choose from, 13.5, 17.5 and 21.5
www.apexrcproshop.com
HawaiiBob is offline   Reply With Quote
