Old 06-19-2014, 12:32 PM   #196
Josh-n-ya's Avatar
Trader Rating: 72 (100%+)
Originally Posted by Indyonroad View Post
40 deg mark on the side or 10 deg on the side (using the 30 deg that is said to be built in) ?
He's talking about 40* mark on the side but in all situations start lower at maybe the 35* mark and go from there.
Josh-n-ya is offline   Reply With Quote
Old 06-19-2014, 12:49 PM   #197
Still wanting to know what a safe temp is whith this motor?
I have been careful not to let it go over 52 deg Celsius (125.6 f)
I want to try 40 deg timing, but what is a safe max temp?
I'm talking about 13.5t
Andrew S is offline   Reply With Quote
Old 06-19-2014, 12:50 PM   #198
Thanks.
Indyonroad is offline   Reply With Quote
Old 06-19-2014, 01:15 PM   #199
Josh-n-ya's Avatar
I don't know Celsius but 170 to 180*f is safe.
Old 06-19-2014, 02:07 PM   #200
Professor's Avatar
65 deg celsius is pretty much the max you want to go to, have see some motors go past 65 but i personally dont like to
VBC RACING AUS--HOBBYWING--MAD GRAPHICS--BITTY DESIGN
Professor is offline   Reply With Quote
Old 06-19-2014, 02:08 PM   #201
Thanks, I thought this motor would not be happy to go that high, but now I know that, ill crank it up! so 125 deg F is very conservative!
Old 06-19-2014, 02:14 PM   #202
rangerjkb's Avatar
Trader Rating: 36 (100%+)
Send a message via MSN to rangerjkb
125*F is safe and still relatively conservative.
Jason Burks
Murfdogg Products~Psycho Cells Racing~Hal's Hobby Warehouse~Avid RC~Kal-Gard~VP Powermaster
rangerjkb is offline   Reply With Quote
Old 06-19-2014, 02:17 PM   #203
65 sounds like a good number! I imagine at that temp, the motor should still last a long time!
Old 06-20-2014, 07:50 PM   #204
ThrottleKing's Avatar
Trader Rating: 16 (100%+)
I love these motors in my USGT and my 17.5TC but I can't get anywhere with the 17.5 in my 1/12. I have been everywhere with the gearing and timing and it is decent at best in 1 cell. I ended up running the best at 30* and a 3.2 roll out on our track tonight with a very open layout and a 60' strait. I spent an entire day over at Access in Ohio working with it since I had the track to myself. I could put my ORCA back in and beat it by 2-3 tenths a lap no matter what I was doing to the R1 in 1/12. Maybe I got a dud but the numbers on my MMS say it is good. I did have to resolder the sensor board since it came lop sided as in one side of the sensor plate was 1mm higher than the otherside and I couldn't gap the rotor correctly with out it hitting one side and being 1mm higher on the other. I have had to do that with all three R1's I have but the others were not as bad as this one. I don't know but the ORCA is going back in the 1/12 for now until I get a new board to test to see if that is the problem.
Jeremiah
Acts 2:21- And it shall come to pass, that whosoever shall call on the name of the Lord shall be saved.
ThrottleKing is offline   Reply With Quote
Old 06-20-2014, 08:31 PM   #205
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Jeremiah
90x45 carpet
I run 28' 101mm roll
That's about 20mm more gear then you have in your setup, and obviously a bit larger track
But it still seems as though you are looking for revs, in a torque motor ?
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 06-20-2014, 09:24 PM   #206
Josh-n-ya's Avatar
Jeremiah
It still seems something could be wrong with it as you described the sensor board being lop sided. Go to R1 web page and contact Steve. Im sure he could help out
Old 06-21-2014, 12:41 AM   #207
Richards Racing's Avatar
A friend and I are getting the R1 21.5 I will be using a Hobbywing Just stock speedie just wandering what timing and FDR would people suggest. We run on low grip painted concrete.
Noel
RC Core - Castlehill Raceway
O/M - VBC Racing - M05 - Sanwa - Hobbywing
Junior - ARC - Killshot - Spektrum DX3R Pro - Hobbywing
Daughter - VBC Racing - Spektrum DX3S - Hobbywing
Richards Racing is offline   Reply With Quote
Old 06-21-2014, 07:01 AM   #208
Originally Posted by RedBullFiXX View Post
90x45 carpet
The 60' is my actual line from coming on to exiting on the strait. I have tried low timing and all gear and high timing an no gear along with everything in between probably 25-30 packs and two sets of foams working on this thing as I said I had 8 hours of track time to myself and I was able to always go faster with my Orca in the 1/12 but in my TC's I have never had a better motor than the R1 so I must conclude that it is either better as a 2 cell motor or I got a bad one. In the TC's they run very good with 4.2-4.6 and 28*-33* of timing according to the lap times up front and out back with little fade probably due to the Sweeps getting hot and the car scrubbing on the backside of the run.
Numbers on the MMS at 73*room temp are: (All motors 12.5mm rotor)
1/12 -17.5: 21.7, 21.8, 21.7 Rotor 1507, -1509
Pretty decent numbers for off the shelf I thought.
My ORCA 17.5 is 22.5,22.5,22.7 Rotor 1555, -1553
Hopefully a sensor board will fix it.
Jeremiah
Old 06-21-2014, 09:41 AM   #209
90x45 carpet
Is your R1 matching or even faster than your D3.5 in 1S 17.5 stock?
LAGuy is offline   Reply With Quote
Old 06-21-2014, 09:48 AM   #210
Cool
I prefer to run "legal" motors
Never tried a D3.5
Compared to LRP, Schuurspeed, Orca, the R1 is on par
