Old 07-09-2016, 08:18 PM   #601
antivert's Avatar
Originally Posted by outlandr91 View Post
Hope somone can help:
I have an Xray 2015 T4 that seems to turn tighter to the left than the right. The servo arm is set straight up and the turn buckles set to factory dimensions, the EPA is equal, sub trim is at zero.
When I put the car on a set up board the front wheels weren't pointed straight, to get them straight I had to add sub trim and adjust the steering turnbuckles. Now one turnbuckle is .020 longr than the other.
Chassis tweaked? Loosen the top deck screws and push flat on setup board, tighten top deck screws?
LRPAmerica | TKO | RugspinGraphix
antivert is offline   Reply With Quote
Old 07-10-2016, 08:35 AM   #602
I tried that and it didn't help.I also checked the A-Arms for binding and they were fine.
QUOTE=antivert;14596156]Chassis tweaked? Loosen the top deck screws and push flat on setup board, tighten top deck screws?[/QUOTE]
outlandr91 is offline   Reply With Quote
Old 07-10-2016, 08:47 AM   #603
heretic's Avatar
Sub trim and servo link are the first things to start with. You should adjust them so that the servo horn and the link form a straight angle when the bellcranks are centered.
Once this is done you adjust your two steering links to get the desired toe-out value (like 1 degree per wheel).
Only then do you adjust your EPA. With the Dual Rate at 100%, adjust your EPA on each side, just so that the servo doesn't growl at full throw. You left and right EPA values should be separated by less than 10 "clicks" if everything above has been done right.
I love wedge bodies. I love dish wheels.
heretic is offline   Reply With Quote
Old 07-26-2016, 11:42 AM   #604
Default Esc stock 17.5
Hello
I have hobby wing stock. And would like to know what the pro's use for there esc settings? Punch&drag ect.
TeamThibault is offline   Reply With Quote
Old 07-26-2016, 01:14 PM   #605
Originally Posted by TeamThibault View Post
Hello
Is that the Just Stock ESC? If so, here is what I use. FW mode only but keep reverse set at 100%. Max punch, max brake, drag brake 10-30 (depends on track), initial brake: drag brake, rest of the settings are default. When the Forward and Reverse mode is selected, the ESC tends to have a lag that the forward only mode (combined with full reverse) eliminates. Later software releases may have fixed that problem.
John Wallace2 is offline   Reply With Quote
Old 09-03-2016, 08:21 PM   #606
porsche928gs's Avatar
Hi Martin,
I recently changed phones from my Samsung Galaxy s4 to an s7. How do I transfer my workbench application I bought?
porsche928gs is offline   Reply With Quote
Old 09-04-2016, 08:51 PM   #607
How does one reduce inner front tire wear?
Thanks for all the great information in this thread!
4roller is offline   Reply With Quote
Old 09-04-2016, 09:39 PM   #608
Less front camber.
~Xray~RCAmerica~Motiv~Gravity RC~ORCA~
Swift Racing Services, LLC.
JDC Motorsports
Boostinswifty38 is offline   Reply With Quote
Old 09-10-2016, 10:01 PM   #609
Hmm, well, I do have a question - shock oil weight for a new build (and a new racer). I realize I could ask the pro's and such what they run in their...car... I didn't do that exactly, instead I lurked around to see what others where using in my car - why ask a question I'm sure has been asked a million billion times, and I know there are a billion answers for. What I've seen it seems the recommendations for spring rates are all over the place, and even more crazy when it comes to shock oil weights... So for the moment, I had decided to chose my shock oil weight based on comparing the natural spring frequency of the suspended wheel to the approximate CPS of the oil as a place to begin (using the piston with the most hole's). I figured by doing that, I could more quickly hone in on the oil weight or easily adjust shock pack from there. Currently my car feels pretty good to me - damping actually seems about dead on actually - although my racing experience is obviously lacking. Was this a wise place to begin, or is there another way to find a starting place for shock oil weight?
RCReggie is offline   Reply With Quote
Old 09-11-2016, 10:21 AM   #610
how do i get more steering . doesnot turn sharp enough (sakura xi sport)
it seems that we run on small track and my set up is for larger tracks
on and off power
Old 09-12-2016, 09:21 AM   #611
skater-deez1's Avatar
Trader Rating: 60 (100%+)
Exclamation
on and off power
I would try -2 degrees front camber and -1.5 rear, softer front springs, and if you still need more try a rear swaybar.
Going nowhere fast since 1973!
skater-deez1 is offline   Reply With Quote
Old 09-27-2016, 08:25 PM   #612
b20btec's Avatar
Just FYI apps works again on iOS 10.0.1
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 09-28-2016, 05:42 AM   #613
How can I unsubscribe LearnSetup?
andy3000 is offline   Reply With Quote
Old 09-28-2016, 12:48 PM   #614
hey martin been fighting off power push very slugish lack rotation tight in door track black carpet i have it made better getting killed corner entry
to slow for you is offline   Reply With Quote
Old 09-28-2016, 02:24 PM   #615
on and off power
There are a few things you can do: less rear toe, less ackermann/more steering angle on outer wheel, shorter wheelbase.
ixlr8nz is offline   Reply With Quote
