Old 10-07-2014, 07:44 PM   #466
Nuno Gancho's Avatar
Hi Martin,
When the temperature raised up the car was pushing in and middle of comer and on and off power the car just didn't rotate just keep pushing. But is was very good in cold condition.
Could I just work on the suspension oil or it requires setup changes
Thanks Nuno.
Nuno Gancho is offline   Reply With Quote
Old 10-07-2014, 09:09 PM   #467
Martin Crisp's Avatar
Originally Posted by Nuno Gancho View Post
Hi Martin,
Thanks Nuno.
Hi Nuno,
If you could either post here or email me your setup and I will be better able to help with specific suggestions based on your current setup.
We need to see if there is something that can be done to increase the lateral grip at the front of the car first, and if not then start taking grip away from the rear...or both.
mcrisp@learnsetup.com
Cheers,
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
Old 10-09-2014, 04:36 PM   #468
Default good luck to Andrew and Hugh
Just a shout out to wish Andrew Hardman good luck at the worlds this weekend.
Also another Canadian, Hugh Lawson is racing 1/5th scale at a big race in Italy. Was just chatting with him on facebook about some setup changes to make. Go Hugh!
Martin Crisp
Old 10-15-2014, 09:33 AM   #469
Well done Andrew Hardman and his mechanic Corey Whiteman, at the worlds! It is the hardest race to compete in as everyone is fast. Congrats to Yokomo for there well deserved win.
Martin Crisp
Old 10-15-2014, 09:53 AM   #470
Martin, if I am running my car and I have the rear shock in the second most lower rear upper hole and I move the rear shock position at the inner most setting on the upper shock tower, using a shock with 400 oil, 4 hole piston, yokomo blue spring and it works better. What would be the next logical adjustment so that the shock could be moved up but have that same "feel" with the car. Would I want a softer rear shock setting via oil, holes in the piston or spring?
Rodney Racer is offline   Reply With Quote
Old 10-17-2014, 12:40 PM   #471
Hey Martin,
I noticed some companies sell the DCJ axles for the rear on touring cars. I can understand the fronts, but what benefit will it bring when used at the rear? Thanks.
redbones is offline   Reply With Quote
Old 10-17-2014, 01:14 PM   #472
if you want to stand up the shocks you will need to go down slightly on the spring rate to get a similar same feel, but it still will not be the same feel as the more layed down shock will have a more progressive spring rate meaning it will feel softer at the intial compression and get progressively a little harder as the suspension compresses than a softer spring that is stood up more. The bottom line however is that you really can't the exact same feeling. If you stand up the rear shocks it does tend to give you more rear grip.
Originally Posted by redbones View Post
Hey Martin,
I have never used these double joint axles in the rear, but in theory they would help reduce any sort of binding caused by the axles allowing the suspension to work more freely and be less influenced by any binding in the axles.
cheers
Martin Crisp
Old 10-18-2014, 07:26 AM   #473
Hi Martin: Thank you for all the help you provide! I have your rc set up app and in the helper section under caster you have more or less -VE I am assuming you mean mor or less negative camber is that correct?
AlGio is offline   Reply With Quote
Old 10-18-2014, 07:51 AM   #474
Trader Rating: 77 (100%+)
Martin, I sent you an email for help. Thanks.
TRF 418 - Team Powers 17.5, HobbyWing Stock Spec, Xpert servo
Xray T4 2016 - Trinity D4, HobbyWing Stock Spec, Ko Propo servo and radio
KustomRCGraphics.com (Best looking novice on the track)
goin2drt is offline   Reply With Quote
Old 10-18-2014, 06:58 PM   #475
bigcracing's Avatar
Trader Rating: 32 (100%+)
Is the app going to be updated for Apple ISO 8 soon
bigcracing is offline   Reply With Quote
Old 10-18-2014, 07:14 PM   #476
bigcracing's Avatar
Oops sorry Martin I should have done my research I will get learn setup tomorrow. Thanks for everything
Thanks Chris
Old 10-20-2014, 06:34 AM   #477
Hi,
If it is in the caster section then I was referring to the caster, not the camber if I understand your question correctly. You can send me an email at mcrisp@learsetup.com with a screen shot of what you are referring to so that I can be sure I am answering your question correctly.
Did you get my response?
Thanks Chris
No worries Chris...sorry for all the confusion around the IOS8 support.
Cheers.
Martin.
Martin Crisp
Old 10-20-2014, 06:41 AM   #478
Thanks i did Martin. I am going to get a new servo, better one. No binding or anything.
Old 10-20-2014, 11:59 AM   #479
patorz31's Avatar
Martin I had a question, on my real race car (2010 GTR with Ohlins Suspension) I have tried and liked the "soft spring, big swaybar setups Actually Moderate Spring, bigger bar)". I haven't tried it yet on my RC, do you think it would work? Is there enough mass there in a RC car to get it to work? Any thoughts.
Northern Alberta Scale Car Auto Racers Pres. and Promotions
TEAM POWERS, RACE-OPT, SCHUMACHER RACING,R-Factor, Bezerk RC
patorz31 is offline   Reply With Quote
Old 10-21-2014, 05:53 PM   #480
Hi,
Nice car btw!
Certainly the big sway bar / softer spring approach will afford you more longitudinal weight transfer under braking and acceleration, which may be what is requried for your GTR.
However, although swaybars will make the car roll less and thus make the car feel more controlled, swaybars also reduce lateral grip. i.e. the stiffer the swaybar, the less lateral grip you have.
Martin Crisp
