Old 06-15-2014, 05:31 PM   #406
Josh-n-ya's Avatar
Trader Rating: 72 (100%+)
Got the chance to finally use my setup app yesterday at the track. It helped a lot. Track was loose and I was loosing the rear end in the corner. First had to figure if it was loose on throttle or off. It was on off throttle. Went down the 1. steps and came to a conclusion. I reduced front camber from 2* to 1.5* and kept rear at 2*. Lowered rear roll center and added 2mm shims to inside upper link and changed to a softer rear spring. That solved 90 percent of loosing rear traction. Which in result I TQ and took first in main. Thanks again Martin for doing what you do.
Josh-n-ya is offline   Reply With Quote
Old 06-16-2014, 08:30 AM   #407
Trader Rating: 18 (100%+)
Hey Martin,
If there is a free space on the wheel, is it better to add shims (0.1 ~ 0.4mm) before getting the first bearing on the CVA or after the last bearing (before installing the clamp kex pin) ?
thejo3 is offline   Reply With Quote
Old 08-10-2014, 11:24 AM   #408
SpidarX's Avatar
Default Confused
Hi Martin,
I have been working under the assumption that lowering the roll center will produce more traction on that end of the car, due to more roll. For instance, the Xray setup book states that "more chassis roll equals more grip."
However, I've been reading through your comments, and it seems that you suggest higher roll centers for the end of the car that you want to create more grip through a turn. For instance, "A higher rear roll center will give the rear more grip."
Could you help me understand what's going on and whether raising or lowering a roll center produces more grip through a turn.
Thank you
RC America - XRAY USA - Hudy
Maclan Racing
Alamo City Racing Club - San Antonio, TX
SpidarX is offline   Reply With Quote
Old 08-11-2014, 09:29 PM   #409
Default Rear toe in
I've asked this question before; however, I cannot find where so I apologize if my question is a duplicate.
Is there any difference in handling by getting 3 degree rear toe in (for example) with one degree in the rear hub and 2 degrees in the suspension arm or getting all 3 degrees from the just arm?
John Wallace2 is offline   Reply With Quote
Old 08-12-2014, 12:59 AM   #410
snailman's Avatar
Default pulling to the right under acceleration and braking
Hey Martin, I'm running a Sprint 2 sport which i've upgraded to a vector pro and vapor 5900 motor.
Under heavy acceleration and braking the car is pulling to the right and if i attempt to turn right with any kind of throttle the car is just spinning out. I don't have anywhere near the same issues when turning left however. Any ideas on what i may need to look at?
Thanks, Dale.
snailman is offline   Reply With Quote
Old 08-12-2014, 07:57 AM   #411
theproffesor's Avatar
Trader Rating: 55 (100%+)
Check your drivetrain for any binding issues or bad bearings. Also check you diff; it may be bad due that kind of power being put through it. If itnhas a spool up front, check to make sure its not broken. Check your suspention for broken or binding parts. All of these things could cause these issues.
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 08-12-2014, 05:30 PM   #412
snailman's Avatar
there seems to be a fair amount of backlash in the rear diff. Would that cause it to pull to one side only though?
Old 08-12-2014, 06:02 PM   #413
What do you mean back lash? If youbare refering to rocking back and forth, is it the diff gear on the belt, the dog bones in the outdrives being worn, or play in the diff itself. If its the latter, your diff is blown out
Old 08-12-2014, 06:15 PM   #414
nf_ekt's Avatar
Trader Rating: 113 (100%+)
You need to strip that car down and rebuild it completely. Check everything for wear, bent parts, ect. We could go round and round on the topic but honestly I would do what I'm suggesting then see where you stand. Sometimes it's a combination of small things.
Up the Irons \m/
Powered by Hotwings, Rolling Rock, and the urge to race toy cars...
nf_ekt is offline   Reply With Quote
Old 09-12-2014, 10:30 AM   #415
Originally Posted by Martin Crisp View Post
For sure an outdoor asphalt track changes during the day based on air temp, the amount of sun etc. Mid day when the sun is out is when you get the least amount of grip. Raising the roll center slightly can help, but the car will not transition as smoothly, so you will need to find the balance that works for your driving. I would actually soften the swaybars or remove them, as a thicker swaybar will actually remove grip. If you are getting more steering then I would raise the rear roll center and soften the rear swaybar.
I have found that a spool is tight on entry and loose on power exit. So I will assume you are talking about loosening up the car on corner entry off power.
You can do a number of things to loosen a car up on corner entry off power.
1) increase rear up travel / droop
2) reduce rear toe-in
3) soften front springs & oil
4) add more front camber or reduce rear camber
If you are looking for more mid corner rotation then here are some things to try in addition to the list above
1) laydown rear shocks
2) lower rear roll center
3) raise fron roll center
someone just sent me the same question via email Maybe that was you?
Here is the response I sent...
The age old question…how to keep the steering but make it stable
You can try making changes to add more rear grip, but this will likely end up with a balance that has too much push in it if you go too far.
Things you can do to add more rear grip are numerous and depend on your current setup.
some of the more common things to try are…
more rear toe in
more rear camber
stand up the rear shocks a little more.
lmao!
Hi Martin,
Sorry for the dumb question. When you say raise the roll center, do you add or remove shim>
www.ActivRc.com ARC
fx35rc is offline   Reply With Quote
Old 09-12-2014, 07:38 PM   #416
fullout's Avatar
Send a message via MSN to fullout
Originally Posted by fx35rc View Post
Hi Martin,
You can either lower your inner camber link pivot or raise the outer. Either will raise the roll center.
Daniel Weinstein
Xray T4 15, Xray XB8 14, Xray XB4 14, Kyosho TKI 3, Kyosho RB6, Sanwa M12
rcamerica.com
performancehobbies.ca
orcarc.com
fullout is offline   Reply With Quote
Old 09-15-2014, 09:21 AM   #417
I see now..thanks alot
www.ActivRc.com ARC
Old 09-20-2014, 07:45 PM   #418
b20btec's Avatar
Martin, I know you don't support your app anymore. It's unfortunate because the new Apple os for the iPhone killed the app.
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 09-20-2014, 08:08 PM   #419
LasagnaCat's Avatar
Trader Rating: 137 (100%+)
Send a message via AIM to LasagnaCat
Martin hasn't supported this thread since June
Well if it seems to be real, it's illusion
For every moment of truth, there's confusion in life...
LasagnaCat is offline   Reply With Quote
Old 09-23-2014, 08:12 PM   #420
nolo148's Avatar
Darn
Owen Ren
ll ORCA ll Pro-Spec ll
Overgeared Racing BOD (Facebook - Overgeared Racing)
nolo148 is offline   Reply With Quote
