Old 06-04-2014, 03:55 AM   #61
ViperZ's Avatar
Originally Posted by machgo5go View Post
Thanks for the info.
Now I am going to add this to my collection of Inferno GT2 and Serpent GTE
and see how this holds ups up on track.
Just have to find a realistic scale body then this Batmobile looking thing.
Ha, Ha, it is sort of ugly and chunky looking isn't it?
I now have 3 of these bodies
Who races a Mazda Sedan...? Honestly...? :D
ViperZ is offline   Reply With Quote
Old 06-04-2014, 10:03 AM   #62
-R2-'s Avatar
Originally Posted by C@T View Post
Got hands on a Xe GT kit today and some of the tuning parts.
First ispection of the kit and the parts did create two questions somebody might be able to answer.
First surprise was that the tires are not belted. Has anybody used them ? Do they tend to blow up at higer speeds ?
The Suspension Bracket R/R 7075 CNC, part No. 504285 (Hongnor) does not fit. The part sliding underneath the diff case is 3.3 mm obove the bottom surface, same as the holes to mount it to the diff. Mistake in manufacturing or wrong part ?
Anny suggestions apreciated.
There are option parts coming soon for the C and D plates, the buggy ones on the rear do not fit, you can make it fit but you would need to mod it by cutting the tab off and installing it upside down, the option one will have the correct seating to the gearbox.
SOAR SEIKI 998,Truggy, Buggy and Electric
Flashpoint Fuel/Savox/
-R2- PAINTS/PRO-LINE RACING/AIRTRONICS
-R2- is offline   Reply With Quote
Old 06-04-2014, 11:40 AM   #63
C@T
C@T's Avatar
Do you have any information for the timeshedule and who will make them ?
Hongnor ?
I´m based in Germany making it costy and time consuming to buy them from the US.
C@T is offline   Reply With Quote
Old 06-07-2014, 12:14 PM   #64
biggdogg1972's Avatar
Tower hobbies has the x3-gte rtr listed for 391.99 on order. No details on electronics yet. We're getting closer
Wife says i have too many rc cars!!!! I DISAGREE
biggdogg1972 is offline   Reply With Quote
Old 06-07-2014, 03:49 PM   #65
ViperZ's Avatar
That's a great price for the RTR!
I got the 80% kit for $299.95 = $92.04 for the running gear, not a bad proposition at all!
Old 06-10-2014, 06:08 PM   #66
ViperZ's Avatar
Test fitting of the motor, ESC and general layout. Darn battery tray is too short for my collection of 4500-5000mah/70C/4s lipos
Old 06-10-2014, 11:59 PM   #67
C@T
C@T's Avatar
You can cut off the rear end of the battery tray to make it fit. Just need to install a 90° peace at the end as a stop.
I would cut off the remaining part you do not need and mount the ESC directly on the chassis. That´s what I have done with mine.
The other thing to consider is to cut off like 7.5 mm of the mounting posts underneath the battery tray to get the whole battery down.
Question from my side: Are those orange chassis stiffners from the buggy and do they fit ?
Old 06-11-2014, 03:59 AM   #68
ViperZ's Avatar
Good suggestion on lowering the whole tray. As for cutting the back off, I'll consider it if I don't find any lipos that fit.
Yes those stiffeners are the X3 Sabre units. They fit well. They do not have the two point mount to the chassis like the plastic ones they replace, however I assume this is not required as they are aluminum, thus stiffer.
Two Point OEM ones
Old 06-12-2014, 07:00 PM   #69
eg
Hello. I'm new to 1/8 scale. Can anyone recommend a good servo for this car?
eg is offline   Reply With Quote
Old 06-12-2014, 07:49 PM   #70
ViperZ's Avatar
For my kit I installed a Hitec HS-8360TH. It has great specs.
•High Resolution Ultra Response Non-Programmable Digital Circuit
•Efficient Coreless Motor
•Durable Titanium Gears
•7.4v 2-Cell LiPo Capability
•Industry Standard 25 Tooth Spline (Fut. Compatible)
•Motor Type: Coreless
•Bearing Type: Dual Ball Bearing
•Speed (6.0V/7.4V): 0.07 / 0.06 seconds
•Torque oz./in. (6.0V/7.4V): 181 / 222 oz-in Torque kg./cm. (6.0V/7.4V): 13 / 16 kg-cm
•Size in Inches: 1.57 x 0.79 x 1.5 Size in Millimeters: 40 x 20 x 38
•Weight oz.: 2.4 oz. Weight g.: 68 g.
Old 06-12-2014, 09:54 PM   #71
ViperZ's Avatar
I got the car wired up tonight. The servo is blistering fast!! I'm looking forward to the test run soon as I know this is going to be one fun machine to control
I didn't lower the radio tray yet as suggested C@2. I thought I should build it up first as designed then mess with it after a bit.
Now, just need some lipos to fit the tray. Any suggestions to what fits? I'll still go looking, but I was just wondering what everyone else uses with this kit.
Old 06-14-2014, 05:11 AM   #72
ViperZ's Avatar
I ended up ordering a few of the Gens Ace 5000mah 40C, 4s hard packs that are 138 x 46 x 49mm (L x W x H) to fit the 145 x 53mm tray
Thinking about it afterward, I should have went 2x2s packs. That's way I could have got a higher C as well I would have packs for my re-entry into 1/10 TC racing... Oh well, more packs to buy I guess
Old 06-14-2014, 03:21 PM   #73
C@T
C@T's Avatar
Are you shure the motor is coreless ?
There is no comments about this on Tekin´s website.
Old 06-15-2014, 04:08 AM   #74
ViperZ's Avatar
I cut and pasted directly form Hitec's site, not Tekin's...
http://hitecrcd.com/products/servos/...-servo/product1
Old 06-15-2014, 03:39 PM   #75
ViperZ's Avatar
Saw this on Ebay
Based on the info it seems the RTR motor is 2100kv with 120A ESC. The auction price is quite a bit more than the listed price at Tower or Amain, however, I find that is generally the case on full kits.
