Old 07-27-2005, 06:16 PM   #1
Default Battery Question
i run nitro, so dont know much about batteries. i have a gp3300 6 cell pack for my starter box, it is not matched. i charge it at 4.5 amps on my novak millenium charger and the pack gets very hot. i read on this forum that everyone charges their packs between 4 and 6 amps. is that because the pack is not matched? or is it because the cells are cheap? thanks for your help.
Joe Chaplow is offline   Reply With Quote
Old 07-27-2005, 07:25 PM   #2
Big Rigg's Avatar
[url=http://www.corallyusa.com/][color=Red]- Corraly USA -[/color][/url]
[url=http://www.corallyusa.com/specializedrc/index.htm/][color=Red]- Specialized R/C -[/color][/url]
[url=http://www.thunderrc.com/eshop/][color=DarkRed]- Team Thunder RC -[/color][/url]
[url=http://www.cfxpaintworks.com/][color=DarkOrange]- CFX Paintworks -[/color][/url]
[COLOR=DarkSlateGray]- Team Ertrachter Factor - [/COLOR]
If my last name were Oxlong, I would name my kid Mike... yup Mike Oxlong
-Heywood Jablome
I don't want to pay for my sig, so yawl figure it out...
Big Rigg is offline   Reply With Quote
Old 07-27-2005, 07:41 PM   #3
ALBERTO's Avatar
Trader Rating: 23 (96%+)
Send a message via AIM to ALBERTO Send a message via Yahoo to ALBERTO
the lower the charge rate the longer they will last.. the higher the charge rate the more puncher they will be. since you are using it in a starter box, charge at a lower rate.. If at that lower rate they are getting too hot. Lower the delta peak /mv setting. at 4 amps 30 to 40 mv should be alright...
still fishing
ALBERTO is offline   Reply With Quote
Old 07-27-2005, 08:49 PM   #4
For me I'll charge it at less then the amt your are charging it at.
I'll drop it to 1 to 2 amps charge for the battery to last the whole day.
I use to run 1/8 on road...
Ben.C is offline   Reply With Quote
Old 07-28-2005, 05:46 AM   #5
thanks for all your help. the reason i asked if they were cheap batteries is because i need another set now for another box, and was wondering if i should buy the same ones??? if they are cheap then i will go with a different set. thanks in advance.
Got a new battery. Have a question. fastpede Radio and Electronics 0 12-31-2007 07:31 PM
battery question esdjc Electric On-Road 6 10-30-2007 08:31 AM
battery question hgoody77 Electric Off-Road 5 02-04-2006 03:05 PM
This is gonna sound stupid question but I have a battery Question. Smoke21 Electric On-Road 7 04-25-2004 08:10 PM
indi charger question/3300mhz battery question TT_Vert Electric Off-Road 4 12-27-2003 11:46 AM
SEO by vBSEO 3.5.0
