Old 07-26-2005, 05:06 AM   #1
Mark G's Avatar
Send a message via AIM to Mark G
Default barings
hey .. what is the best way to clean barings ..? or is it just worth buying a new set
Mark G is offline   Reply With Quote
Old 07-26-2005, 05:10 AM   #2
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
RPM Bearing Blaster.
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 07-26-2005, 05:10 AM   #3
1fastdude's Avatar
Trader Rating: 15 (100%+)
What do you use "barings" in? Most racers use "bearings" You can clean them with motor spray, lighter fluid, just about anything. Re-lube them with thin oil like Zubak's or Finish Line oil. Both are very good. Sometimes it is better to replace them too.
Team Horizon-Team Spektrum-Tekno-Kyosho*B-FAST R/C Performance*TQ Racing Wire Products-TNT-FX.COM-Avid RC-Dynamite-*AKA*92Zero Design*
1fastdude is offline   Reply With Quote
Old 07-26-2005, 05:17 AM   #4
DIMO's Avatar
Default Let em soak
You should let em soak in 2-stroke lawnmower fuel or nitro fuel give em i day i always do, then when your down clean em out i like to air blow them gently making sure you dont spin the bearing alot when its got no lube on it. THen i soak em up in trinity royal oil. and give them a drop or 2 after every meet.
DIMO is offline   Reply With Quote
Old 07-26-2005, 05:39 AM   #5
Burlap's Avatar
Send a message via MSN to Burlap
I've found electric motor spray to be the best to clean them. Leaves not residue, and the high pressure blast through the small plastic bit from the can gets the crap out of the bearings. A quick dousing with Trinity Royal oil, and they are as good as new.
Burlap is offline   Reply With Quote
HPI RS4 Nitro(Ball Diff Kit)W/39t alum Pulley & barings 2 johnny55 R/C Items: For Sale/Trade 0 05-05-2003 08:54 PM
SEO by vBSEO 3.5.0
