Old 01-20-2014, 09:40 AM   #1
wwddww34's Avatar
Trader Rating: 9 (91%+)
Default USLMP Racing Rules - 1/10 Le Mans Prototype
*** Rules below are copied from http://www.usvintagetransam.com/rules/ ***
What do you guys think about this race class?
USLMP Rules
Min ride height 3mm
Max width 205mm
Min wheelbase 255mm
Max wheelbase 275mm
Min weight 1200g
Motor limit indoor tracks 21.5, outdoor tracks 17.5
Esc ROAR approved blinky only
Battery 2S regular or shorty
Single nut wheel attachment
Rubber tires
Max wheel width front TBA
Max wheel width rear TBA
Min wheel width front TBA
Min wheel width rear TBA
Max wheel diameter 50mm
Max tire diameter TBA
Min tire diameter TBA
Only LMP, Group C, GTP, GT1, Can Am, Sports Prototype bodies are allowed
  • If body comes with molded in kick up at rear, must be cut out to resemble separate wing as on full scale car.
  • If body come with separate wing, must be mounted in same location as full scale car.
  • No oval or TC style wings allowed.
  • Scale liveries encouraged and recommended, we will make fun of you if you paint a tribal flamejob-no exceptions.
Qualifying format to be USSRCRA style, 3 min single qualifier using 5 fastest avg laps to seed your position for mains.
3 x 10 min mains for points to determine overall winner
  • Option to use standard IFMAR qualifying and single main event (club choice)
Commercially available LMP chassis (SpeedPassion LM-1) or converted 1/10 pan chassis (WGT, Pro-10) pan chassis fitting the dimensions are allowed.
Body recommendations-
  • Speed Passion LMA
  • Royce RM-1
  • Toyota GT-1 TS020
  • Rivall LMP1
  • Porsche 962
  • Nissan R91CP
  • Toyota Group C 88CV
  • Mercedes Group C CLR
  • Porsche 962C
  • Toyota GT1 TS020
  • Porsche 911 GT1
https://www.facebook.com/groups/BananaRaceway/
wwddww34 is offline   Reply With Quote
Old 01-20-2014, 10:40 AM   #2
Trader Rating: 24 (100%+)
Love the idea. Hope it goes well.
Evoracer is offline   Reply With Quote
Old 01-21-2014, 11:59 AM   #3
wwddww34's Avatar
How many people (on RCtech) have a car that fits the description for USLMP?
Old 01-21-2014, 12:08 PM   #4
howardcano's Avatar
Trader Rating: 35 (100%+)
Full thread here:
LeMans LMP1: 200mm Pan Class Discussion
That thread was an extension of this previous thread:
RCHSR: Radio Controlled Historic Sportscar Racing
I'm very glad to see a return to racing cars that look like real racing cars!
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 01-21-2014, 12:49 PM   #5
scootr117's Avatar
Does there really need to be another class? Seems like most races have loads of classes these days with 4 people in each one...and why does every new class get slower?
Scooter EXperimental
RK Designs
CD SuperPro Motors
Mike Pulfer is my HERO....
scootr117 is offline   Reply With Quote
Old 01-21-2014, 01:01 PM   #6
snoopyrc's Avatar
This should be faster than VTA or USGT. I would expect anyway. If anyone is running something like this, how does it compare to laptimes for other classes?
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 01-21-2014, 01:59 PM   #7
Sorry, already discussed elsewhere
rctrackman is offline   Reply With Quote
Old 01-21-2014, 02:13 PM   #8
snoopyrc's Avatar
I was planning on either converting an F109 or a GenX 10. Am I missing something. You sound like thats not possible.
Old 01-21-2014, 02:23 PM   #9
Wrong place. Sorry
Old 01-21-2014, 02:35 PM   #10
howardcano's Avatar
It's quite easy to use a standard F1 rear axle on a WGT chassis. You'll need the axle (with hubs) and a pair of 6x10mm flanged bearings. Just drill or ream out the rear axle adjusters to 10mm to accept the bearings.
The F109 should be ready to go; just change the body.
All of this is already discussed in the other thread:
Howard Cano
Old 01-21-2014, 02:53 PM   #11
Never mind. Sorry
Old 01-22-2014, 07:01 AM   #12
JLock's Avatar
There needs to be a bit more clarity of the rules as far as rubber tires are concerned. What type of rubber tires are to be used? The only reason why I ask is that there was a F103GT kit in which you could run touring sedan rubber tires. This could open up another can of worms as far as the type of tires then start the brand "spec-ing" of tires talk to this class.
USLMP Racing Rules - 1/10 Le Mans Prototype-tamiya_58367_002.jpg
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 01-22-2014, 07:34 AM   #13
Lap times are a few tenths quicker than USGT and about 1 sec faster than USVTA, closing speeds are considerably faster for the 21.5 LM1 versus USGT.
Team Novak,Gravity RC,
ercwhtsd is offline   Reply With Quote
Old 01-22-2014, 08:04 AM   #14
howardcano's Avatar
I have measured several different brands of TC rims, and none meet the 50mm maximum diameter rule.
Howard Cano
Old 01-22-2014, 08:12 AM   #15
firefoxussr's Avatar
thank you!
This is a LMGTP car from 1999, better known as the 'flying' CLR prototype.
I really want one!
I have the 1996 Tamiya 911 GT1 and want about 5 cars off that list.
Parking lot heroes: M06, TA05sw, XV01, XRay T1, SC10B
Partially disassembled: HPI Cup Racer, FGX, M04, TA02, TA05 IFS
Newest acquisitions: A210SS Exige, HPI MX-5, Tamiya F40
firefoxussr is offline   Reply With Quote
