Old 01-14-2014, 06:13 PM   #1
bigcracing's Avatar
Trader Rating: 32 (100%+)
Default Novak GTB 2 help
This past weekend my Novak GTB 2 went solid red and no throttle response after a good hit while racing USGT
Any help would be great thanks
Thanks chris
bigcracing is offline   Reply With Quote
Old 01-14-2014, 06:54 PM   #2
LasagnaCat's Avatar
Trader Rating: 134 (100%+)
Send a message via AIM to LasagnaCat
Check the sensor wire, reprogram, solder joints, all the obvious suspects?
Well if it seems to be real, it's illusion
For every moment of truth, there's confusion in life...
LasagnaCat is offline   Reply With Quote
Old 01-14-2014, 07:00 PM   #3
Switch esc Off, and disconnect with battery, then reconnect and turn esc on..... Make sure you double the servo tape under the esc to cushion the blows better....
bertrandsv87 is offline   Reply With Quote
Old 01-15-2014, 12:25 PM   #4
Johnny Wishbone's Avatar
If your running a glitch buster as well, try removing it, disonnect your battery, hook it back up and do a couple power cycles, then try to do a setup to the transmitter.
Gary Lanzer
SEO by vBSEO 3.5.0
