roar legal rubber tires and inserts?
which rubber tires and inserts are roar legal?
take off cs-27?? what does cs-27 stands for? 24mm or 26mm rims? what about inserts? |
Roar doesn't have a "legal" tire, other than if you goto a Spec Tire race. In which you will be running the same tire as everyone else.
The 27 in the take-off is their temp. recommendation for that tire. Like a cs-22, cs-27, cs-32 and so on. Same with Sorex and RP. Each company list a tire for different Track temps. As for inserts same thing. There are no "ROAR LEGAL" insert. At most BIG races you will be required to use a pre-mounted tire. (one that the manufactuer has mounted) That makes the racingthe same for everyone. Hope this helps. |
thanks for making it clear to me.
where can i look up temperature ratings for tires? |
the manufatuers web pages may have them.
For take off try Schumachers web page. |
thanks
