Old 01-03-2014, 04:56 AM   #1
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Default CRC Altered Ego set-ups
I haven't seen a thread dedicated to the CRC Altered Ego chassis, so I decided to start one
I just ran one at NORCAR's 3rd annual Hangover classic in 17.5 and loved it!
Here's a pic of what I ran:
If you have any questions or set ups feel free to post them here!
-Wayne
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 01-03-2014, 05:26 AM   #2
Wayne,
if you don't mind........what front springs, side springs, tube lube and tires did you decide upon for the hangover classic?
vafactor is offline   Reply With Quote
Old 01-03-2014, 05:39 AM   #3
sg1
sg1's Avatar
Front:
1.565" gray, 1/4" SXT inside
.45mm front springs, .5mm droop
5* blocks, 2 shims forward and 1 back
graphite high roll center, thicker ones.
barely 3/4* camber
1-.015" shim on axles (didn't try to widen front)
barely 3mm ride height at nose of chassis
Rear:
1.64" gray, full SXT
20k in 1 tube, 30k in other
35wt. center shock with new red spring
new .50mm taperd side springs, just touching
2mm droop
3.25mm ride height
Other info:
Power Push white lightening battery positioned forward
Team Scream (D3.5) motor, HT 12.5 rotor
CRC body (Mohawk)
SXT set just 5 minutes
Hobbywing 1s esc
Old 01-03-2014, 07:48 AM   #4
sg1
sg1's Avatar
I started the tires at 1.595" front and 1.665" rears.
The layout was rough on gray tires..lol...
Old 01-03-2014, 09:18 AM   #5
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Thanks for sharing Wayne.
Old 01-03-2014, 09:43 AM   #6
sg1
sg1's Avatar
No Problem!
That's why I started the thread... so we can "share"
Old 01-03-2014, 11:25 AM   #7
Send a message via AIM to racer034life
Why have 20k in one tube and 30k in the other?
Access Hobbies,CRC, Detc410, Xray T4 15,
The Ian Ruggles Negative Reinforcement Driving School
racer034life is offline   Reply With Quote
Old 01-03-2014, 11:29 AM   #8
sg1
sg1's Avatar
I didn't have 25K
I had 20K in to start, tried 30K, was too much.
Old 01-03-2014, 10:26 PM   #9
I've been working on my XTiAE lately. Its always nice to see other set ups for comparisons sake. I usually end up running between 20 and 30k as well in the tubes.
I get a little lost once in a while with all of the "nameless" possible configurations with the current CRC lineup. For clarity, you are running the AE rear pod and main chassis, but simply chose to use the standard Xti cross brace / battery locator, correct? I assume you are using double sided tape under the battery to locate it then, right? I found double sided duct tape that holds really well, and still releases cleanly when needed. Its no thicker than regular duct tape either so the battery stays low.
Old 01-03-2014, 10:26 PM   #10
Do I see a modified hole in your castor block for the use of a stiffening bar? I did the same thing as sometimes the CF top brace tweaks my front end...
Peace and 12th's!
Old 01-04-2014, 01:28 AM   #11
I)arkness's Avatar
is it possible to run servo backward in xti transverse chassis? or will it only fit in between front arms
B.Portelli
Hyper RC - RAB Hobbies - Wild Turbo Fans
Race Opt - Team Powers
I)arkness is offline   Reply With Quote
Old 01-04-2014, 01:53 AM   #12
Looks possible to me.
Old 01-04-2014, 04:18 AM   #13
sg1
sg1's Avatar
Peace and 12th's!
I do have the Altered Ego main chassis and top and bottom pod plates.
I didn't have the XTi transverse cross brace, but the XTi inline cross brace dropped in and held the battery where I wanted it (forward). I did just get it the XTi transverse cross brace to install to give me the option of moving the battery back.
You are correct, I just use servo tape to hold the battery
Not the best thing to do, but it works
The castor blocks were some very old ones, so the hole was in them.
I think CRC had them like that for the one aluminum brace with o-rings they used to make that went between them.
Old 01-06-2014, 05:57 AM   #14
sg1
sg1's Avatar
Set up sheet:
setup.pdf
Compliments to Am0 at Petitrc.com
Old 01-06-2014, 01:44 PM   #15
tdu verney's Avatar
Sg1,
Did change the outside height of the damper tubes?
tdu verney is offline   Reply With Quote
