Old 01-14-2014, 01:15 PM   #31
Originally Posted by sg1 View Post
The softer center spring and a bit more droop in the rear shouldn't transfer as much weight to the front. It may react different on your carpet, but it's something you may try.
If you have 10* castor blocks you may want to try 5*
I'm not a fan of letting the tires air dry, they just become more sticky.
When I tried Blue rears I had more traction with those then I did with yellows, graylow, or grays. The grays felt like the car was on top of the carpet, not bogged in it, if that makes sence.
Thx, I will give it a try.
dyoung is offline   Reply With Quote
Old 01-15-2014, 04:07 PM   #32
ghoppa's Avatar
Trader Rating: 53 (98%+)
Default servo??
Hey Guys,
building my altered ego chassis and I currently have a Savox SH-1275MG and I think i am going to have issues making it fit without taking some carbon fiber off (which I totally don't wanna do!!!)
any suggestions on a servo that fits perfectly would be greatly appreciated!!!
R1 Wurks - ActivRC - ApexRC - P1 Brands
ghoppa is offline   Reply With Quote
Old 01-15-2014, 06:08 PM   #33
Originally Posted by ghoppa View Post
Hey Guys,
JR 3650 http://www.jrradios.com/Products/Tec...odID=JRPSZ3650
Spektrum a5040 http://www.spektrumrc.com/Products/D...odID=SPMSA5040
Spektrum 5020g http://www.spektrumrc.com/Products/D...dID=SPMSH5020G
Sanwa SRG-HR
http://sanwa-denshi.com/rc/car/servo/srg-hr.html
Airtronics 94761Z
http://www.airtronics.net/index.php/...orq-servo.html
avink007 is offline   Reply With Quote
Old 01-15-2014, 09:31 PM   #34
I)arkness's Avatar
FYI the spektrum 5020 does not fit easilly, had to cut the carbon brace that the front end bolts to.
B.Portelli
Hyper RC - RAB Hobbies - Wild Turbo Fans
Race Opt - Team Powers
I)arkness is offline   Reply With Quote
Old 01-15-2014, 09:51 PM   #35
Did you mount it between the front suspension or behind it like Wayne mounted his?
Old 01-15-2014, 10:04 PM   #36
I)arkness's Avatar
between the front,
but even with the transverse conversion, i though of putting it on opposite side. But the chassis hole where the servo would mount was in the incorrect position thus making the servo spline offset.. not sure if its different on the alterego main chassis. so just left if up front
B.Portelli
Old 01-16-2014, 06:26 AM   #37
ghoppa's Avatar
thx Avink007!
I went ahead and purchased a Spektrum 5020 for a great price from TQ...
appreciate the help!
Old 01-16-2014, 07:12 AM   #38
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
thx Avink007!
Let us know how it fits.
I have the JRZ3650 in mine.
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 01-16-2014, 09:17 AM   #39
ghoppa's Avatar
will do, hopefully I can get her all done and try to make the Region 5, I live in Cincy now...
Old 01-16-2014, 09:38 AM   #40
masterhit's Avatar
Trader Rating: 15 (100%+)
If it doesn't show in time I will have a couple of JRs with me at the regionals we can throw in there!
Mike Slaughter
masterhit is offline   Reply With Quote
Old 01-16-2014, 10:07 AM   #41
ghoppa's Avatar
Mike Slaughter
wow, thx for the offer Mike!!!!
keeping my fingers crossed.. looking forward to wheeling again, its been to long since I moved out this way...
Old 01-22-2014, 02:03 PM   #42
tdu verney's Avatar
Default Altered Ego
My car with an SG1 setup. It works!
Car was stable an comfortable to drive. Unfortunately skills are not included, dang it!
tdu verney is offline   Reply With Quote
Old 01-22-2014, 03:20 PM   #43
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
Hey gang, just wanted to let you know this got the job done in Sidney (Victoria) BC the weekend before! Alter Ego chassis, Xti rr plate. It was a great 50+ car field of 13.5.
Brian
Stay dialed my friends!
www.slapmastertools.com
Team Roche USA
Team Orca orcharc.com
Slapmaster6000 is offline   Reply With Quote
Old 01-26-2014, 07:04 PM   #44
Finally had a chance to try all the setup changes and they worked great! No hint of rolling and i waseven able to add some compound to the front. New personal best lap time and 8 minute run. Thx sg1!
Dennis
Old 01-27-2014, 02:02 AM   #45
sg1
sg1's Avatar
Dennis
Nice job Dennis!
Glad the set up worked for you!
I was testing over the weekend on a new layout and the only thing I tried was stiffer rear side springs and increased dampening. The carpet is pretty new and the layout went over areas we haven't run on yet. So there was a very small amount of fuzzies if you went out of the groove. You would loose a slight bit of stearing during the race. The increased dampening and stiffer side springs worker well. I tried a stiffer center shock spring, but that didn't feel as good.
