Old 01-07-2014, 02:33 AM   #16
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Originally Posted by tdu verney View Post
Sg1,
Did change the outside height of the damper tubes?
1 .03" shim per side.
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 01-07-2014, 04:36 PM   #17
sg1
sg1's Avatar
I added info to the set up sheet.
The shims between the chassis and graphite front plate were .047"
Old 01-08-2014, 07:57 AM   #18
rpoage's Avatar
Originally Posted by sg1 View Post
Set up sheet:
Attachment 1152465
Compliments to Am0 at Petitrc.com
Thanks for the info and the help at the US champs. I noticed you are using the New CRC Red spring and when I try that spring it is way softer than the old CRC red. The spring chart I'm working with shows the new spring equivalent of the old CRC red is right in between the New CRC Gold and the New CRC Copper? I ran the new red at Horsham in one qualifier and with 3.4mm rear ride height and loaded level pod and the chassis was covered in black track gook.
Ashford Hobby
Real time inventory for the things you need.
rpoage is offline   Reply With Quote
Old 01-08-2014, 08:24 AM   #19
sg1
sg1's Avatar
If I run into a situation like that, I'd try going to 4mm clearance.
That's providing the car felt good and stearing wasn't an issue.
If the spring was just too soft for your track/layout and you had a push, then 1 spring stiffer would be my next thing to change with the clearance still at 3.4mm
Old 01-12-2014, 06:06 AM   #20
tdu verney's Avatar
Thumbs up Altered Ego
SG1,
Hey I tried this, it works, it's a great set up! The car was so much fun. Skills or lack of had me go to a different tire, team purple, and blues. The new red spring , and pod droop perfect balance to the car. I had no tweak in the car all day.
TomD
tdu verney is offline   Reply With Quote
Old 01-12-2014, 06:39 AM   #21
hi hi,
is it necessary to cut one of the horn away for jr 3650? i noticed there is another mounting on the chassis.
My blog: http://ongbenghui.blogspot.com
ongbenghui is offline   Reply With Quote
Old 01-12-2014, 06:56 AM   #22
tdu verney's Avatar
Default Servo mount
Yes, if you run it between the arms.
No, if you run it like SG1 has it in his photo.
Old 01-13-2014, 02:25 AM   #23
sg1
sg1's Avatar
SG1,
TomD
Glad it worked!
Do you have a pic of your car you can share?
Old 01-13-2014, 03:38 AM   #24
Default New to pan.
Hi, just searching for some advise. I'm looking at starting 12th scale racing and came across the CRC ae. Car looks awesome with great tune-ability. Only problem I live in Australia and can't seem to find anywhere online where I can get spares. Amainhobbies has the car but very limited spares. I'm happy to buy from japan or hk if required. Any advise would be much appreciated. Thx.
Kyosho RRR /futaba 3Pk/OS TG/Novarossi S12/ Savox/Soon 2B R4..
CRC xti / Orion R10 /Trinty D3.5 17.5t
TLR XXX-TCR basher...
Friday night, fight night....rc racing, that is
Team FTR.
volumex is offline   Reply With Quote
Old 01-13-2014, 06:53 AM   #25
If you don't mind ordering from the US, Stormer always has a huge CRC selection.
JamesL_71 is offline   Reply With Quote
Old 01-13-2014, 02:04 PM   #26
Default traction rolling
sg1,
Ran the altered ego for the first time this weekend and having a traction roll issue. Carpet is extremely high traction ozite and had the following setup:
front
black tires cut to 1.62" SXT compound 1/5th inner then nothing
.45 springs
-.5 camber
caster all the way forward
30k lube on kingpin
3mm ride height
rear
white side springs just touching
30k lube in dampers
gold center spring/35wt oil
blue tires cut 1.68" full SXT
3mm ride height
battery rear
Mohawk body
Had the chassis low enough that it drug the front, and turned the dual rate on transmitter down so much it became hard to get through chicanes etc. but that was the only way to stop the traction rolling.
Open for ideas.
Thx
dyoung is offline   Reply With Quote
Old 01-13-2014, 02:39 PM   #27
tim fry's Avatar
Originally Posted by dyoung View Post
sg1,
front
.45 springs
-.5 camber
30k lube on kingpin
3mm ride height
rear
30k lube in dampers
3mm ride height
battery rear
Mohawk body
Open for ideas.
Thx
Cant see much wrong there but I would try .50 front springs and gold centre spring does seem a little stiff giving lots of steering.
tim fry is offline   Reply With Quote
Old 01-13-2014, 05:02 PM   #28
sg1
sg1's Avatar
sg1,
front
.45 springs
-.5 camber
30k lube on kingpin
3mm ride height
rear
30k lube in dampers
3mm ride height
battery rear
Mohawk body
Open for ideas.
Thx
Things to try:
-chromes at 1.60"
-The blacks at 1.62" are too big, you'll need those at 1.59"
-.50mm front springs with minimum gap between stearing block and lower pivot ball under weight.
- softer side springs (blue)
- softer center spring
- much smaller rear tires (1.64")
- battery forward
A few questions:
What castor blocks did you run?
How much rear pod droop?
How long did the traction sit on?
Did you try other rear tires (graylow or gray?)
How much droop was in the front?
When traction gets high I go stiffer front springs, much smaller diameter tires, traction on for a shorter time, and much less droop in the front.
Old 01-13-2014, 05:52 PM   #29
Things to try:
-chromes at 1.60"
- battery forward
A few questions:
rear pod droop less than 1mm front basically none. I will have to check caster blocks but whatever came in the kit. sxt applied for 5 minutes and wiped then air dried for about fifteen. I never tried other rears as I thought something softer would make the problem worse. on the center spring wouldn't a softer spring allow more weight transfer to the front when cornering?
thx for the quick response and ideas.
Old 01-14-2014, 02:35 AM   #30
sg1
sg1's Avatar
The softer center spring and a bit more droop in the rear shouldn't transfer as much weight to the front. It may react different on your carpet, but it's something you may try.
If you have 10* castor blocks you may want to try 5*
I'm not a fan of letting the tires air dry, they just become more sticky.
When I tried Blue rears I had more traction with those then I did with yellows, graylow, or grays. The grays felt like the car was on top of the carpet, not bogged in it, if that makes sence.
